Old 06-05-2013, 02:05 AM   #5461
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
^^^ that whole setup looks like it will be prone to failure.....
Drift_FX is offline   Reply With Quote
Old 06-05-2013, 02:43 AM   #5462
BOROSUN
BOROSUN's Avatar
Looks like the LCA's are about 40mm longer in their shortest position.
It's hard to take pictures that show the differences accurately, lens distortion and the angle you take the picture at definitely effect how it looks.
what's the weight on those?
Old 06-05-2013, 07:36 AM   #5463
icantdrift
icantdrift is an unknown quantity at this point
Care to elaborate?
icantdrift is offline   Reply With Quote
Old 06-05-2013, 07:47 AM   #5464
icantdrift
Originally Posted by Croustibat View Post
Isnt he the guy that was thrashed some time ago for using rod ends on FLCA knuckle mount ? I think i recognize the knuckle.
It seems he changed his design... may be interested too depending on features, design quality and price. The traction rod mount to LCA is kind of creeping me out though (but i am no mechanical engineer so i could be wrong)
edit: yes, that was him. So he DID account for remarks. I'll be gripping so i dont care about bumpstops ... and i cant see his setup weaker than oem arms. Maybe on the knuckle ?
Same guy. His original calcs showed that the rod end he was using was plenty strong but is most definitely willing to make changes to the design for the sake of improved design and safety/reliability.
The TC rod mount is a bit odd to me as well, but if necessary I can always drill and tap a hole for a U bracket and run two rod ends like my current setup uses. I do a lot more track days than drifting so I will be installing and taking measurements without the rack spacers then giving them some track time on big sticky rubber.
Old 06-06-2013, 02:45 AM   #5465
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
I wonder why they don't use a 2 bolt design on the lower control arms
Old 06-06-2013, 03:44 AM   #5466
Croustibat
Croustibat is an unknown quantity at this point
Just a guess:
1/ 2 bolts design means you have to make the bolts loose enough to adjust caster without binding;
2/ 1 is enough;
3/ there is no room for 2.
Croustibat is offline   Reply With Quote
Old 06-06-2013, 05:59 AM   #5467
PoorMans180SX
PoorMans180SX's Avatar
I'll try and weigh them tomorrow.
Because the guy doesn't really know anything about designing a suspension component.
Old 06-06-2013, 07:59 AM   #5468
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
You guys are pretty quick to condemn stuff that you have not used or seen used, those uprights look similar that to modern Lexus IS/GS ones
Motary is offline   Reply With Quote
Old 06-06-2013, 08:14 AM   #5469
PoorMans180SX
Unfortunately the design of a McPherson strut upright is far different in requirements than that to a double-wishbone setup. I was hesitant to say anything at first, but upon Def confirming what I thought, my gut feelings were right.
from NRR:
Originally Posted by Def View Post
The upright is very thin compared to say GKTech's aluminum upright. Stiffness in bending is purely a function of material and geometry, in this case, you get much more stiffness by making it thicker in the perpendicular to the plane of bending (i.e. a 1/8" bar is much easier to bend than a 1/4" thick bar).
The fact that he recessed everything in an already thin cross section means stresses just went up that much more, and the hub boss is in complete bending.
The fact that he used a half height jam nut in tension shows me a general lack of knowledge of mechanical design, as that is a nut that should be loaded in shear only. Shear being like the bolt going into your sway bar end. Bending loads one side in lots of compression, way more than you would think if it were just "pulling away" because it's using the bolt as a lever arm to magnify the forces. Exactly the same concept of using a long breaker bar to get more torque on a bolt, except in this case you're having that breaker bar yank on your half height jam nut that is specifically designed NOT to be loaded that way.
There's more, but those are the big things that jump out at me. But this was also the same guy who was arguing that a rod end in bending is not incorrect mechanical design. So it's like he's basically going through and making almost every bad design decision possible (it really is that bad, I'm not exaggerating, any of these screw ups can cause complete suspension failure on that corner).
Old 06-06-2013, 10:37 AM   #5470
Croustibat
We can easily see it wont be as strong as GKtech or tdp. The question that we should ask ourselves is "is it strong enough". I mean its ok to overbuild like the 2 i mentioned, but there has to be a threshold were it is strong enough.
I am not saying the design rock, it clearly has flaws. The question is: is it going to break ? If it is strong enough to compensate for design flaw, i cant see it as a bad thing really. I do remember OEM LCA is stamped steel and tension rod diameter around 1/2" . Is it REALLY weaker than oem ?
As far as the 1 bolt instead of 2 design goes, i remember some high end stuff that had the same 1 bolt tension rod to LCA too (except it had a ball joint on the tension rod end).
Old 06-06-2013, 01:33 PM   #5471
koukistylejdm
koukistylejdm's Avatar
koukistylejdm is an unknown quantity at this point
so the car handles great after the second wheel alignement this is max or close to max angle
koukistylejdm is offline   Reply With Quote
Old 06-07-2013, 02:08 AM   #5472
Motary
Motary's Avatar
Front tyres looks nicely planted!
Old 06-07-2013, 08:22 AM   #5473
icantdrift
from NRR:
He is planning some fatigue/stress testing now in light of the doubts raised on NRR. They've been running a test set on a car for a couple of months but only drifting to my knowledge, which was the main design consideration anyway. How weak could over an inch thick piece of 7075 really be?
Old 06-07-2013, 08:30 AM   #5474
icantdrift
I think the main issue raised with the single bolt tension rod mount is that it is placed in bending by the force of the sway bar end link that is incorporated into the design. While I agree it is the first I've seen an end link of that style, as long as you're not binding the joints in the end link I wouldn't think there's that much bending force on it.
Old 06-08-2013, 05:48 PM   #5475
PoorMans180SX
More in my build thread:
Old 06-08-2013, 06:32 PM   #5476
Silvi
Silvi is an unknown quantity at this point
Cool! I can see that there is no problem with 16's and this kit.
Is it possible to purchase just the top plates?
Silvi is offline   Reply With Quote
Old 06-08-2013, 06:50 PM   #5477
PoorMans180SX
Not as far as I know.
Old 06-08-2013, 08:02 PM   #5478
Silvi
Is there enough clearance between the tire and the chassis rails at full lock?
I would like to know what the length of the kit's LCA compared to the stock one
Old 06-09-2013, 09:53 AM   #5479
PoorMans180SX
Yes there is. The arms starts at 40mm longer than the stock S13 one, and I have it probably 60mm longer at the moment. I'm going to try and tweak things to run them at their shortest setting.
Old 06-10-2013, 04:43 AM   #5480
Motary
Motary's Avatar
He saved it
Old 06-10-2013, 05:43 AM   #5481
Croustibat
Reverse entry FTW XD
Old 06-10-2013, 12:29 PM   #5482
PoorMans180SX
http://www.youtube.com/watch?v=JdSvBeY3_YI
Old 06-10-2013, 01:03 PM   #5483
SoCalDrifter
SoCalDrifter's Avatar
SoCalDrifter is an unknown quantity at this point
quick question if anyone can help me out here i just bought the SPL solid subframe bushings kit and it also came with spacers for it what the best positioning way to put them on for drifting? ive never used both before
SoCalDrifter is offline   Reply With Quote
Old 06-10-2013, 01:12 PM   #5484
Motary
Motary's Avatar
It depends how low your car is, Id put them in the back, anti-squat can get negative on these cars when extremely lowered.
Vertical axis is suspension travel
Old 06-10-2013, 01:46 PM   #5485
SoCalDrifter
cool thanks
my cars not to low but its not slammed either its just barely tucking in the first 1inch of the tire wall if anything.... if that makes sense
also now my other question is to where to put them...on the bottom to raise it or on the top to lower it?
Old 06-10-2013, 01:50 PM   #5486
drifter92
drifter92's Avatar
drifter92 is an unknown quantity at this point
I have read through 60-70 pages of this thread and searched but I can't find ant definitive information on about how long I should extend my LCA's.
I have a V8 S14 that isnt going to be very low, I ran 8.0 front caster -4.0 front camber and -0.5 rear camber on my s13 with the stock KA, high and hard in the front, low and soft in the back, I call it the "drift scoop" setup, it drove effortless, I had stock spindles with Tein tie rod spacers and 17x7" +40 wheels with a 38m spacer up front with a 215/45, 15x6" stocks in the rear with 195's. I plan on doing about the same setup in my S14, but adding extended lowers and cut knuckles.
So, my knowledgeable friend says extend it no less than 50mm/2"...
LMK what you guys think, and please quote my post if you have good information on my question. Thanks in advance!!!
Instagram: chinowith
https://www.youtube.com/user/untouchable361/videos
drifter92 is offline   Reply With Quote
Old 06-10-2013, 02:28 PM   #5487
Motary
Motary's Avatar
Make it long enough to have clearence at full lock, simple as that.
Cut it in half, tack weld together and see if there is enough clearence, if not, hammer it off and make it longer and so on
SoCalDrifter - In the top! Also, try experimenting with different settings
Old 06-10-2013, 05:01 PM   #5488
Jonnie Fraz
Jonnie Fraz's Avatar
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
I can say this about the Keisler Automation set up. The angle stops will smash into a million pieces one time at hard full lock.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 06-10-2013, 06:02 PM   #5489
drifter92
drifter92's Avatar
Thank you for the information!!! I plan on compensating for steering angle clearance by running a 17x7 up front with a 215/45 so i guess we'll see what works. Thanks man!
Old 06-10-2013, 08:43 PM   #5490
SoCalDrifter
thanks man im gunna try different setups at my next track day but just goin to a small track this week to test the new parts out
