![]() Join Date: Oct 2007
Overheating Issue
Alright editing this so the new problem is at the top...
When I drive in gas saver mode or let the car idle, it will start to spike and over heat. If I throw some spirited driving in there and rail it, the temp goes down to normal and stays there. Any ideas?
![]() Join Date: Dec 2006
Replace thermo, get a Nismo Thermo.
http://www.thenismoshop.com/ikorb.ph...product_id=266 water pumps dont really go bad just the seals (leaks) be sure to properly bleed the system too
Fuck Nizmo Thermo's, There over Priced garbage. Don't waste your money when you can go to the local parts store and get one for around 12-20$ Vs Nismo 80$+.
When running with the radiator cap off and it warms up, Can you see any flow in the radiator at all? If not then its either the thermo is stuck open or the water pump is not pumping. I would start with a thermo stat first and if that doesn/t fix it then move on to the more expensive part. Water pump. You shouldn't have to drive the car for it to get hot. If its going to get hot it will do it at idle. Also don't let it get above 215 degree's or else your going to warp that head and get a blowed head gasket. |
I love mine, Before my temp would be around 86-92*C on a hot day Now with my Nismo Thermo it never goes above 67*C unless I have the A/C running Anyway.. If the Thermo is stuck open then his engine would not over heat and you would see the water flowing. If it was stuck closed, (which it probably is or just not opening when it should) then his engine would over heat. A water pump never stops pushing the coolant unless there is FOD inside the system and some how breaks the shaft or the bades, and the Blades on our water pumps are pretty damn beefy so i doubt that is what happend. Remove and replace Thermostat flush coolant Fill purge air Enjoy
#6 | |
I meant stuck closed. My bad, As for the thermo, My Rb one is 80$+ I was just throwing it out there. Either way 30-50$ is WAY TOO much. Why is Nismo garbage? I just don't like any of there products. They seem to have a mis led rep with me. I was going to buy a clutch slave from them a while back for my Rb trans since I couldn't find a good one. Found out the SAME clutch slave they were selling I could buy at Napa for 16$ Nismo's price 250$ IMO B.S and I will Never Ever Ever give them my business nor recommend them to anyone. I agree with the water pump also, its not likely its bad, but I have seen a few that is. Thats why I suggested looking for the radiator flowing. Also the car will overheat if the Thermo is stuck open. Should take a long time for the car to warm up and once it does its possible the radiator can't keep up and will cause it to overheat. But if this is the case you can check it by popping the cap while its cold. There should be NO coolant flowing while cold. |
I agree with screw a nismo thermostat. If it works correctly, then your car will never get up to the proper operating temps. At least thats the way I see it.
And you say it has a "clicky gurgling sound". When exactly do you hear this? Are you sure you dont have any leaks? Does it build up good pressure? You shouldnt be able to squeeze the top radiator hose shut when its warmed up. If so, there is air in there, or you have a leak. And the water pump is bad about leaking around the seal too.
'91 240sx hatch: ka-t t3/t04e '93 240sx coupe: stock dd |
#8 | |||
your RB Thermo- $40 here http://www.thenismoshop.com/ikorb.ph...oduct_id=12076 Quote:
I use the Z32 slave from Napa on my SR and had 2 of them crap out already and im only using a stock clutch, im waiting to buy a Nismo when i get a chance. I'll pay more for reliabilty. Quote:
The reason why the engine over heats when the thermo is stuck closed is cuz the water in the engine is not flowing enough so it just chills there and get hotter thats why lots of ppl pull the thermo out so there engine will run cooler
#10 | |
![]() Join Date: May 2005
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
I'm guessing you're at work and can't use the spacebar?
Anyway, if your engine runs too cool, it can cause premature wear from what I've been told. As the engine gets hot, the metal expands and such, and no expansion equals more wear on certain pieces such as rings. This is all just what I've been told, and I don't have any hard evidence or experience.
#/f/sale-items/24807...-stuff-fs.html |
Nah its one of those: You know you drive a 240SX when, your space bar breaks and cant afford a new one cuz all your money goes to your car. J/K Mikey
#12 | |
http://phase2motorsports.stores.yahoo.net/nith.html I have a twin plate Cusco Exedy Stage 4 clutch. I don't think a crappy Slave is going to cut it with this clutch. I have SS lines also. been using it for 6 months No problems, I do ALOT of drag racing also. So if it was going to break I think it would have. Ill save 234$ and buy another one if it decides to take a poop. It would over heat b/c the water in the radiator would eventually get as hot as the engine block due too constant flow and cause over heating. I know b/c I use to run Without a thermo in my Rb, It was fine for a while but eventually would heat up, Especially after a few hard pulls. |
#13 | |
I'm pretty sure there are no leaks since I don't see any fluid and pressure seems to be good, it just seems coolant isn't flowing properly. I'm gonna go get a new thermo tomorrow when I have some free time. Crossing fingers that's it haha.
![]() Join Date: Apr 2008
dont get an autozone thermo..
just get a nissan OEM thermo, those autozone/advance thermos are pieces of shit, and shit out for no reason.... you can hold a nissan OEM thermo next to a crappy one and the difference is easily visible... as for the nismo being too cold and hurting your engine, if you look at a cooling diagram the thermo is placed at the end of the circuit, and only opens 10 degrees C earlier than an OEM, by the time that coolant gets back around its not "under temperature" |
Trader Rating: (-1)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: -1 reviews
I.have.a.new.nismo.thermostat.and.it.still.overhea ts.It.has.to.be.air.bubbles.in.the.system
I.ran.around.the.block(giant.parking.lot).a.few.ha rd.times.guage.was.way.past.hot.opened.hood.didn't .seem.to.hot.upper.hose.was.hot.lower.wasn't.No.bo iling.in.overflow.like.a.normal.overheat...so.mayb e.just./air.bubbles? (Spacebar.is.broken,can't.even.play.starcraft.righ t!) (lap.top.is.ok.but.gurl.is.always.on.it) (and.yes.all.my.money.is.going.to.my.sexy.hatchi) |
#16 | |
Also, replace your radiator cap since its cheap. I think they sell them with a built in pressure gauge at Advance. Or get a greddy one that bumps up the pressure a bit. It can be very hard to get all the air out of the system too. That bleeder screw is you best friend here. Loosen it 'til its just barely in there and let the car idle for a while. I even took mine completly out and just let coolant/bubbles pour out some. Make sure your heater is open too.
#17 |
Trader Rating: (-1)
I didn't try to fix it today (bought a sexy bumper) i am tomarrow. Everything but my water pump is changed. I'm pretty sure there's just air in the system i just like freaking out and posting =0P. I'll jack the front of my car up with my bleeder and rad cap off and add more coolant/water till bubbles are gone and see if that was it.
![]() Join Date: Sep 2003
why dont u do it the right way when u fill ur radiator.....to bleed it the system from the screw on the mani........ or fill it with the radiator cap off and fill it when the thermostat pops open... and cap it.... i dont feel the need to spend more then 5 bucks for a thermostat... had my autozone one running for 5 years hasnt given me a problem... running no thermostat basically involves more time for your engine to warm up..... i prefer method #2 this basically tell me everything is working properly... might want to change ur waterpump... since you've replaced just about everything else in the cooling system...
if u get temp spikes.. that basically describes having air in ur coolant lines...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#21 |
this works pretty well for me when bleeding my system
Once you flush the system Turn on heater in second gear go WOT till 6K then engine slow you down do this 2 or 3 times and that should purge the air out
#22 |
thats alot of work..... to bleed air... ill just wait for the thermo to pop open... u can tell when it does, because suddenly the level will drop down and bubble...fill and cap....
#23 |
Alright I replaced my water pump. Now it will overheat for like 20 seconds and when I rail it, it goes back down to normal and will stay there for the rest of the time...
#24 |
replace temp sensor...... then ur golden..... sweet ur so zilvia elite now...
#25 | |
Last few times I've run it there have been no temp fluctuations though. hmmm
#28 |
Im going thru this once again in my car...replaced coolant temp sensor, thermo (twice), water pump, radiator and even installed an aftermarket gauge to keep a more specific eye on the temp.
ANYWAY, after a few hours of reading on this topic, I have noticed a few people trying these spill free funnels that attach to the radiator opening http://www.twistingwrenches.com/inde...ducts_id=17407 for $20, I think ill give it a try! I have also noticed a lot of people installing cheap ass thermostats from napa kregan autozone etc etc.....these thermostats are GARBAGE and tend to prematurely fail and/or stick. for comparison, i got a new oem thermo and replaced a 4 month old cheap autozone thermostat. You can CLEARLY tell the difference, oem one has a rubber seal and appears to be made a lot better with higher quality components. |
#29 |
Unhook the thermo it will not overheat in idle anymore but it will still indecate if you over heat. i dont know why it does it but a freind tought me that. there is something about a 240 that is prone to over heat.
#30 |
![]() Join Date: Sep 2006
I Was having the same proplem as you...werd over heating and with brand new thermo - water pump - sensor and i was still over heating....
So i Removed/deleted The T-stat and every thing is A-OK...now.. keep in mind that i live in a VERY HOT part of the world..EVERY day the out side temp goes up to 50*C = ~120*F.... And After Deleting the T-Stat...my car never over heat..but it take some time time to go to the normal operting temp...(only 1-2 min later).... Setup : 2x E-fans (puller) (Auto ON @80*C) And Auto Off @75*C. 2x E-Fans (Pusher's From A Merceds-Benz S500) (not hooked up yet) STOCK KA Rad. STOCK EVERY thing else.... So Try And ! The T-stat and see what happen... Hope This Help, Regards, Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
