Old 11-12-2001, 11:53 AM   #1
Guest
Posts: n/a
is there a way to increase power without adding any parts.... like chaging timing things or something im un-sure about tweaking an engine without parts... so what can be done.... be specific please.
Old 11-12-2001, 11:55 AM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Take off power steering belt
Remove all heavy objects (passenger seat, spare-car's easier to push)
I don't know of anything else, it doesnt' come to mind right now.
S13Grl is offline   Reply With Quote
Old 11-12-2001, 12:03 PM   #3
Guest
Posts: n/a
not physical stuff i mean doing something like hooking up a timing gun or changing something that will  add power.... im lost i dont know what im talking about but i know there is something u can do like that im pretty sure....
Old 11-12-2001, 12:25 PM   #4
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
i don't think you can add power or go faster without physically altering 'something' on your car <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> &nbsp;
whateverjames is offline   Reply With Quote
Old 11-12-2001, 12:29 PM   #5
Guest
Posts: n/a
are u sure? any mechs out there? arent there things u can do to make some power? without adding parts? just adjusting certain things
Old 11-12-2001, 01:00 PM   #6
ZeroGS14
ZeroGS14 is an unknown quantity at this point
nismo...you can advance your timing and run higher octane fuel
ZeroGS14 is offline   Reply With Quote
Old 11-12-2001, 01:01 PM   #7
Guest
Posts: n/a
how would one go about advancing timing? what kind of octane, i e how high of an octane would i have to run, and how much power would i gain?
Old 11-12-2001, 01:34 PM   #8
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
usually u don't have to advance ur timing w/ a newer car like urs though, ur timing should be just as it should be right now.
BlankFlip is offline   Reply With Quote
Old 11-12-2001, 01:37 PM   #9
Guest
Posts: n/a
would advancing it create any horsepower gains?
Old 11-12-2001, 02:11 PM   #10
Guest
Posts: n/a
n e ideas?
Old 11-12-2001, 02:14 PM   #11
BlankFlip
BlankFlip's Avatar
i'm not 2 sure, i only had my timing advanced on my camaro when it wasn't running smooth or consistent.
Old 11-12-2001, 02:39 PM   #12
chickenmanq
chickenmanq is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from nismos14 on 11:53 am on Nov. 12, 2001
is there a way to increase power without adding any parts.... like chaging timing things or something im un-sure about tweaking an engine without parts... so what can be done.... be specific please.</td></tr></table><span id='postcolor'>
If you haven't gutted your stock intake to allow more air, that'd do it. &nbsp;Other than that, start modifying. &nbsp;Parasitic horsepower loss &nbsp;is one thing you can always do. &nbsp;Stock intake, ehxaust suck. &nbsp;You're not adding any internal parts to gain power. &nbsp;You'e letting the engine breathe better. &nbsp;Electric fan is always good. &nbsp;Takes out the 12 pound clutch fan. &nbsp;Goes back to the old adage, though. &nbsp;You can't get something for nothing.
chickenmanq is offline   Reply With Quote
Old 11-12-2001, 04:03 PM   #13
DSC
New Title
DSC is an unknown quantity at this point
heh, nismo14, sounds like your broke and about to go race somebody <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Oh and BTw, I wouldn't give up powersteering or AC ever.
DSC is offline   Reply With Quote
Old 11-12-2001, 04:18 PM   #14
BlankFlip
BlankFlip's Avatar
same here, it's really not worth it, unless u just race it n got another daily driver.
Old 11-12-2001, 05:09 PM   #15
Guest
Posts: n/a
no, i heard about the advanced timing thing and have been wondering about it never understood it or new how to get it done
Old 11-12-2001, 05:15 PM   #16
BlankFlip
BlankFlip's Avatar
i meant it's not worth it for the a/c n powersteering thing. advancing ur timing isn't a a performance type thing really. i mean, if ur car is idling bad or not running consistent, then u can advance ur timing n yeah it will run like it should. i really don't c what ur talking about.
Old 11-12-2001, 05:25 PM   #17
Guest
Posts: n/a
hmmmm someone i know was working on an engine and did something and was talkin about degrees.... is this the timing??
Old 11-12-2001, 05:27 PM   #18
BlankFlip
BlankFlip's Avatar
i'm not sure, its more of a maintenance type deal than performance, i don't know how to personally do it myself though, my friend did it for me, took him 5-10 minutes to get it just right.
Old 11-12-2001, 05:28 PM   #19
Guest
Posts: n/a
you sure thats not the idle speed? i think these two are un-related....... but i dunno *shrugs*
Old 11-12-2001, 05:31 PM   #20
BlankFlip
BlankFlip's Avatar
*shrugs* <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 11-12-2001, 05:40 PM   #21
Guest
Posts: n/a
i think we need a genius for this question LoL
Old 11-12-2001, 05:43 PM   #22
konkman
konkman is an unknown quantity at this point
You will get some noticable hp gains if you remove your resonator from your intake air box. &nbsp;Under &nbsp;your air box you can remove the large black plastic box and run a piece of aluminum flex tubing straight into your air box. &nbsp;This should give a horse or two.
But after you will notice a louder intake sound and better throttle response.
konkman is offline   Reply With Quote
Old 11-12-2001, 06:01 PM   #23
Guest
Posts: n/a
read the original question konkman
Old 11-12-2001, 06:45 PM   #24
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
you can turn your heater on to take heat away from the engine bay.. if you advance the timing and make your car run rich you will need high octance like 92+.. you will need octance booster or get racing fuel..
to advance the timing you have to play with your CAM GEARS.. if you arent comfortable with playing around with your engine .. you shouldnt... just get some bolt ons or some do it yourself mods..
but i would really consider the power steering/ AC / cruise control ... relocation of the battery to add weight to the rear [ is this good for 240SX's?... my mentality comes from honda tuning world? ]
91CRXsiR is offline   Reply With Quote
Old 11-12-2001, 08:16 PM   #25
MazingerS14
MazingerS14's Avatar
MazingerS14 is an unknown quantity at this point
Send a message via AIM to MazingerS14
You can advance your base timing by 3 degrees or so as long as you run 91 Octane gas. &nbsp;It usually gives you a noticible gain in throttle response, increase in torque (3-4 ft-lbs) and maybe a pony or two. &nbsp;You don't need adjustable cam gears for this since this is a base timing adjustment. &nbsp;Just need a timing gun and adjust your distributor accordingly. &nbsp;The numbers I gave are from SR20DE engines but Nissan engines work pretty much the same. &nbsp;Almost all the SE-R/B platform Nissan guys do this as a freebie performance mod.
Don't know where you live but if it dosn't get extremely hot in the summer just get rid of your mechanical clutch fan. &nbsp;There is a secondary electric fan that turns on around 205 degrees so that should be adequate as long as your cooling system is in good shape. &nbsp;You could also add some water wetter just to be on the safe side if you remove the clutch fan.
MazingerS14 is offline   Reply With Quote
Old 11-12-2001, 10:07 PM   #26
whateverjames
is the car not in your name? leasing it? sharing the car with someone in the family? selling it soon? just curious why you don't won't alter anything.
Old 11-13-2001, 12:07 AM   #27
Guest
Posts: n/a
i've already got an intake and exhaust can't afford anything more expensive so i wanted to know how to get soem cheap stuff done i think i know a guy who can do the timing for me so yah <img src="#/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=':D'>
Old 11-13-2001, 12:09 AM   #28
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from MazingerS14 on 8:16 pm on Nov. 12, 2001
Yadjust your distributor accordingly.
how do u do this?
Old 11-13-2001, 12:45 AM   #29
konkman
Lets stomp on others for trying to help. &nbsp;Maybe next time you should advance an email with your car's current stats before chopping.
If you were running a stock intake system and wanted more power this is a good idea. &nbsp;Besides when did the intake protion of your car stop being part of where your &quot;engine&quot; gets power? &nbsp;Or did I miss that post?
Old 11-13-2001, 08:14 AM   #30
S13Grl
Married to the Mob
S13Grl's Avatar
Oh, what love...
Nismo, there's no such thing as free power. Gotta spend some $<span style='font-size:10pt;line-height:100%'>$</span>$<span style='font-size:10pt;line-height:100%'>$</span> to get a little faster.
Advancing your timing would be a maintenance item, as everyone else has said. Get rid of as much un-needed weight as possible. You're fine with intake &amp; exhaust for now, we all start somewhere. As a matter of fact, most of us here will only have intake and exhaust.
People, chill a little bit, what's with all the hostility?
