Old 12-11-2010, 11:14 AM   #1
kyro1282
kyro1282 is an unknown quantity at this point
KA No Acceleration...
i have a 93 240sx and a few days ago i noticed that when i gave the car gas the rpm's would go up but the car wouldnt go any faster. i dont have a check engine light on at all and today when driving when the car warmed up it just lost all power. ive read that it could be the egr valve or just a vacuum leak but i dont even know where to start. does anyone have any clue what and where i should start?
kyro1282 is offline   Reply With Quote
Old 12-11-2010, 11:28 AM   #2
ayororo
ayororo's Avatar
Trader Rating: (25)
ayororo is an unknown quantity at this point
Feedback Score: 25 reviews
We need more info , was it runnning good before that drive? Do you maintain your car well?
ayororo is offline   Reply With Quote
Old 12-11-2010, 12:03 PM   #3
Sileighty_85
Sileighty_85's Avatar
Sounds like the clutch
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-11-2010, 12:41 PM   #4
kyro1282
the car is stock with 5speed and very well taken care, it has a new clutch, it ran just fine before this. it only does it when the car is cold. what other info might you need?
Old 12-11-2010, 09:03 PM   #5
nismoman
nismoman is an unknown quantity at this point
Really does sound like a slipping clutch. Are you losing any trans oil? Maybe trans oil seal is leaking onto the clutch. Does it rev normally in neutral?
nismoman is offline   Reply With Quote
Old 12-11-2010, 09:29 PM   #6
kyro1282
i really dont know if its leaking, honestly i dont know where to start... any and all help, ill be very greatful for
Old 12-12-2010, 03:29 PM   #7
nismoman
Well if it's leaking bad enough to slip the clutch you should see some dripping. Jack up the car and underneath the trans where it bolts to the engine there is a small hole. See if anything is seeping out.
Old 12-13-2010, 12:06 PM   #8
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
What kind of clutch do you have?
jacobs13 is offline   Reply With Quote
Old 12-13-2010, 07:13 PM   #9
kyro1282
It's a stock clutch and was put in less then a month ago. If it's leaking trans oil what can I do to stop it and is it something easy enough to so in an evening as I'm ready to take it to a shop in the morning to have it done, I'd just rather do it myself.
Old 12-13-2010, 07:15 PM   #10
nismoman
You have to pull the trans to replace the seal.
Old 12-13-2010, 07:28 PM   #11
kyro1282
From all mentioned above does that sound like what might be the problem I'm having? Also I've never pulled an tranny on one of these, is it something that is easily done?
