#63 |
![]() Join Date: Apr 2003
I like seeing home built cars like this. Best build up ever! Can you please give more information on the powdercoating gun please (brand and where you got it).
Thanks Amir
![]() UGR.....SOMETHING WICKED THIS WAY COMES.... |
#64 |
Nice build up man good luck with it.
+rep |
#65 |
I do have one other thing, a small sandblast cabinet. for proper adhesion of the powdercoat, you need to apply it to preped bare metal from what I understand. I got the gun and SB cab from Harbor Freight and salvage, and the powder from rosey's powder coat on ebay. They sell cool colors in small quantities.
#68 | |
Assembly... Had to modify the Downpipe slightly by removing some of the divider so that it would fit with the S15-R T28. |
#70 | |
I'm not sure, the new ones are different. I llok at my paperwork when I get home. One question. Those of you that have done SR swaps, what did you do with the igniter?. I removed it from the mounting bracket, but I'm looking for a sanitary way to mount it to the strut tower. I'm trying to keep it out of the way of the fuel lines/filter. Any Pics of the way you have yours mounted would be appreciated. |
#74 | |
![]() Join Date: Dec 2006
just swap everything to the s13 subframe and you wont have to fabricate anything. |
#75 |
![]() Join Date: Jun 2004
Not sure if this helps but I just mounted mine with two sheet-metal screws right onto the shock tower. It was easy and keeps it out of the way. I don't have any pics though.
LS1 FD |
#76 |
Ive got it mounted with some doublesided tape right now, I'm thinking that I will extend the harness and move it around the back of the strut tower for a fixed location. I dont like the idea of it sitting there right under the fuel filter.
#77 |
![]() Join Date: Dec 2003
nice build, way to do things the right way!
#78 |
So tonight I did some wiring so that I could have a boost guage. The setup Ive got is from PLX. I wanted to keep the dash area simple, so I went with the column pods, and eventually have another display. The two sensors I have currently are boost/vac, and wideband AFR. In the video you can see that AFR reading 14.6, thats because I dont have the O2 sensor and harness hooked up yet. Also tonight I fabricated a throttle cable bracket.
Edit... the sound is horrible in the video. [ame]http://www.youtube.com/watch?v=WKevPRuBZcM[/ame] |
