Sr20det over heat help!!!
Ok so I'm having an issue swapped my s13 with an sr a few weeks back, had a problem with heater hoses leaking so I recirculated them and bled the system with one of those radiator cones. Now I don't know how to explain it but my car warms up at a normal rate but always runs a little under the middle, sometimes but not all the time when I get on it the needle keeps up and I cut it off before it get hot but at the same moment that I cut it off I click it back to acc mode the step before starting the car and the meddle drops way under the middle like it was never hot.
