#121 |
![]() Join Date: Oct 2005
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
Front, sideskirts are rattled. Looks like ass.
www.realize-jp.net |
#123 |
from this
To this, but i still gotta wet sand and redo the hood and top. Im probably gonna clear it with a spray gun over the weekend too. I went with gunmetal
#124 |
the whole car was rattled canned and came out even. you just cant let a section dry before the rest and you have to paint it in sections.im happy with it.
duplicolor gloss white. semi gloss black. duplicolor FTW. please xcuse the wheels. |
#128 |
![]() Join Date: Jun 2003
Trader Rating: (129)
240esux moar pixors plz of white car.
#129 |
decided to do the fenders yesterday and today...came out ok i guess...much better than they were before though..lol
before: ![]() after: only downside is that now that the fenders are nice and shiny i can see exactly how f*cked up it is in terms of dents... ...oh well
"There is no fail when there is no win!" -Break Win Garage |
#130 | |
![]() Join Date: Apr 2003
what rear wheels are those?
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
#134 |
![]() Join Date: May 2007
my question is, if say the roof is spray painted and then wetsanded etc. but there are some uneven lines, like you can see a patch here and there, will rubbing compound hide this and just make it one solid shiny color or will you still notice the patches when glossy
#135 |
i think, it should be gone after u wet sand it down
when i did my roof, after clear coat, there is some area where its "heavier coat" and so on, after polishing, no patches or anything |
#136 |
spray canned the rear bumper..
from a full origin kit was saving to put on the car.. since my GP rear bumper was fucked and in the middle of moving, i decided to throw the origin rear bumper on.. Luckily it matches the rest of the car lol.. i believe the car was sprayed witha gun flat black.. ![]()
Keep it Classy |
#138 |
![]() Join Date: Nov 2008
Location: NORCAL - SAC NOT Bayarea NOT So Cal NOT Anywhere Else! JUST SACRAMENTO
dam yutas car gave me a reason to paint my shit pink heh
![]() My WHITE WHEELS are 15x11 -46 STOP ASKING! |
#141 | |
I will personally never paint the outside of my car with spray paint, however, I had some slight surface rust, in my spare tire well, in the trunk of my coupe.
Here's how it started: I bought this from pep boys: I figured that I could remedy this problem myself, even though I don't know what I'm doing, I just figured I'd use some common sense. I sanded it down, hit it w/a wire brush and sprayed the rust spray: Finished product: Personally, I think it looks good, and it accomplished what I wanted it to.
#142 |
![]() Join Date: Sep 2006
here is my old car... i dont know if this helps... but this is how i had her before the accident
Photos coquines gratuites |
#143 |
![]() Join Date: Sep 2007
i rattle canned my rear trim piece a while ago, came out pretty good:
![]() ![]() i sprayed a thin layer first, let it dry for a couple of minutes and then sprayed a very thick, wet layer, just so much that the paint wont run. i didn't use clear coat by the way. the most important thing is prep work of course, i primered it beforehand, sanded the primer with 600 grit and then painted it red. got another one: friends car. whole kit was rattle canned als well, no clearcoat. |
#144 |
Bandwagon.
my custom 2 tone
front bumper, sides and rear, walmart flat black can 96 cents total for one can? no clear coat nor prep. |
#145 |
I bought the car satin black, and rattle-can'd the aero with duplicolor's dark primer - didn't paint this set of 25mm fenders cause I'm not planning on keeping them (too small). Just add baller wheels, no one even notices the paint
![]() I rattle-can'd my engine bay and the engine (engine with high temp silver block paint, bay with metallic black + duplicolor holographic flake). Sanded everything down, two coats of primer (one light, one thick), sanded with 320, then hit it with 3 layers of base, wet sanded with 600, 800, 1200, then cleared. 3 coats of clear, wet sand again, then a couple coats of flake. It looks good, but never again - the rest of the car is too baller for rattle can. ![]() ![]() ![]() ![]()
#146 |
![]() Join Date: Aug 2007
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
dam some impressive results out of these rattle can jobs.... personally me i wouldnt use rattle can paint. If your patient you can have good results but if not it will look like crap. I guess for the ones that cant afford a good paint job is a good idea or for those who just abuse their car. 2 things that are really bad about using rattle can 1. paint does not adhere good so when you take it to the car wash with enough pressure paint will just fly off. 2. its not protected from the sun damage which means it will fade pretty fast unlike a 2 stage urethane paint. If anything instead of using rattle can a 1 stage acrylic enamel paint from the paint shop would be better since youll be able to automize the paint better with a spray gun.... thats just what i think.
#150 |
just a few questions to those who have rattle can their cars. do you have pictures of the freshly painted and the recent pix of it? curious to how good its been holding up from weather beat downs. thanks
