![]() Join Date: Nov 2010
![]() ![]() Feedback Score: 12 reviews
sr arp main studs cracked oil pan, wtf? pics
so i realized why my upper pan wasnt sitting right, and thats cause it was hitting the main studs. what the fuck? this is dumb and now im kinda stumped. anyone got an upper pan laying around? im giving arp a call tomorrow
![]() Join Date: Dec 2006
Did you modify the pan to clear the studs?
If not you have to. Is it not written in the instructions?
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
hahah fuck! Mine was hitting so just grinded some material off of the oil pan. You should of noticed when you were bolting on the oil pan. I know there had to be a gap and it was harder and harder to tighten
i know i wasnt paying attention, i noticed one side wasnt sitting flush with the block but i thought it was maybe the little dowel pin not fitting right. so wacked it with a mallet to seat it and that did it haha
Yep, clearancing is a must on the RWD SRs... FWD SRs don't have too.
My SR20VET |
![]() Join Date: Dec 2003
^Wow.... so I just made a frantic call to my machine shop because of this thread; although you would think they'd catch this. I literately had them hold up on progress so my studs would come in; and I dropped them off last week. Luckily they hadn't gotten to that far this week.
Does ARP warn you about this? What's the preferred method; shorten the back 4 studs? Anyone know how much interference there is?
no there were no instructions about this, nothing said to modify the pan. arp even told me they have nothing about it in the kit. im glad i was able to help you instead of it happening to you too. they say to hand tighten the studs in but im thinking if you turn them two more or so times youll be able to avoid this. ill try to represent which studs they are
this is with the motor upside down, the studs are on the "exhaust" side if you think of it that way _____. . . . back . . . . front of motor ____^^ those are the 2 that hit and the closet to the front is the one that cracked it Last edited by boost addict; 07-25-2011 at 04:48 PM.. |
Right on, I'll advise the shop; props on the diagram, it's clear enough for me. Luckily I've got a second one but I'd like to keep that for the other motor. Can't you just weld yours back up?
![]() Join Date: Dec 2004
Trader Rating: (58)
You'll only need to grind the last too. Shame it's not marked in the ARP instructions, nor is it really full on common knowledge (I mean who ever really thinks to search for 'pan clearence'. There have been some guys who have lucked out, others have had the exact thing above happen. If you're not looking to trim the studs, you can always cut a hole in the pan there, and have a welder modify the pan to clear it too.
Trader Rating: (58)
Some FWD do, some don't. I think it really depends on DE vs DET, as I've had some friends with DE have no issue, and some with DET that have also had to grind them.
Uni- go to nico and do a search for threads started under my name. I have a thread all about this and the modifications I did to make them work without cutting/grinding my studs.
My SR20VET |
Well, I was referring to the FWD DE blocks...
My SR20VET |
#17 |
And uni take a look at my diagram again, I think it was a little messed up. It's the back two on that side. Like I said arp is sending me a few shorter studs so I'll see how that goes an I'll let you know. Maybe you can just do the same if it works out. Seems like it'll be the cleanest solution
#19 | |
Trader Rating: (58)
Mazworx makes nice stuff, but to say their main studs are THAT much better is a big claim.
#20 | |||
yeah, I don't know about that now... bold statement.
#21 |
AFC #1
![]() Join Date: Oct 2003
Mazworx kit is made from ARP2000 not the 8740 chrome moly that the regular ARP kit is made from.
#23 |
Trader Rating: (58)
I knew what ARP still made them, however I was looking for quantitive data on how they were worth the price, especially considering DET main bolts are plenty strong.
#24 | |
Trader Rating: (58)
EDIT: Not trying to be a technical asshole, but there are countless/many/hundreds of cars running big power on stock stuff without any signs of failure. If anything the SR mains are pretty stout, unlike the rod bearings.
#25 |
![]() Join Date: Nov 2007
Trader Rating: (36)
![]() ![]() ![]() Feedback Score: 36 reviews
I never said arp or stock stuff was prone to failure. I think you misinterpreted my original statement. I have stock main studs on my SR and have even re-used stock head and main studs on other engines. However pre-cut studs that are made from a stronger material is an easy solution the the cracked oil pan problem. Yes I realize you can modify arp fasteners to fit and correct the problem but not everyone wants to cut a main stud when there is a kit that is modified and ready for installation readily available. The fact that they are made from arp2000 material is a bonus. I'm sure you can see that. If you really wanted to pursue the difference in tensile strength between the two fasteners I'm sure mazworx could provide you with a ton of information and real world application that suggest that arp2000 material is stronger than the 8704 Chrome moly used in the other fasteners. There must be a reason for them requesting that arp produce the bolts and I'm fairly certain they use them in their crate motors and drag car. Let's not argue semantics.
#26 |
AFC #1
I have never stretched main bolts. The only ARP head studs I have stretched were on a Turbo Diesel where the cyl pressures are a lot higher. This was the only situation where the ARP2000's were needed. Like you said the ARP2000 is a bonus. Not necessary but when you want the best... The only thing I would use ARP2000 on our motors is the rod bolts.
I'm not a big fan of main studs. Have to check the main bore because the clamping load is different. The Nissan OEM units are a high grade steel(4130 IIRC) and up to the job. Sure some of the old domestic stuff used bolts that weren't as high grade as today. But, just because they need them doesn't make it a necessary upgrade on modern engines.
#28 | |
Trader Rating: (58)
Nothing against Mazworx, they make nice stuff, but don't fall into the consumer trap of 'because XXX does it, that means it's the only way' Which was exacty the point I was trying to make. Upgrading for the sake of ugprading is a waste.
#29 |
so back on topic, how much interference is it? Shit I'm only swapping to these b/c its a "while I'm in here, I can afford it, it can't hurt" upgrade; lol.
S14DB, the difference in clamping forces is that different between the two?
#30 | |
AFC #1
The benefit of the ARP2000 is that it's more ductile. Which makes it ideal for head studs and rod bolts. Less likely to have the head lift or a rod cap break loose. Mains are more set and forget. They don't have the stretch loads that the others do.
