ignitor chip testing?
i looked around some and couldnt find a definitive test to check if an ignitor chip is working. So i just dove in with logic and a multimeter. So when the car is on i touch the multi meter to any one of the four pins coming from the ecu, all four have 11.5-12v of power. Then i plugged my q45 ignitor chip into that and touched the pins coming from the chip to the coilpacks. All read .01 Im no mechanic but im going to assume this definitely means its the ignitor chip.
The only reason im hesitant to assume is because 3 weeks ago i left a light on over night and it drained my battery down. When we went to jump it off it wasnt getting spark to coilpacks and the reason was in the ecu, something had shorted, we soldered it and all was well. now It has started and ran since then until i swapped out my old nasty engine harness for a nice clean new one with q45 plugs. So either its the chip, or the soldering job on the ecu has shorted out once again. What do you guys think? |
The coilpack pins are switched to ground so they won't read any voltage unless plugged into the coils and the coils are powered.
NismotronicSA - Speed-Density Tuning for Nissans |
What? I think you misunderstood me, Why would I be touching the coil pack plug? I meant after checking the plug that goes in the ignitor chip I tested the pins on the other side of the ignitor chip once I plugged it in.does that make anymore sense? I need pictures I'll take some tomorrow if this isn't resolved
Like you know how both ends of the ignitor chip has spots for plugs? After testing the 4 pin plug from the ecu I plugged in the ignitor chip itself and tested the opposite end that would be plugged into the 5 pin side.
Right, I understand what you're saying. On the 5 wire side, 4 go to the coil packs and the 5th goes to ground. The ECU triggers transistors that switch to ground completing the primary coil winding side circuit. Without the coil packs plugged in, you won't see any voltage on those pins.
There is a power transistor (ignitor chip) diagnostic procedure in the S14 SR20DET FSM on pdf page 337 (EC-202).
#9 | |
You should test all of the pins in order to test all of the transistors in the ignitor chip. It contains 4 power transistors that are turned on individually by the signals from the ECU to complete the individual primary coil winding circuits.
if the circuit is only completed by ecu input how is it possible to test the resistance if the chip is not plugged into the harness? The ecu has no way to tell the chip to close the gap right? Maybe my understanding of what your saying is wrong, do you get what i'm saying?
Follow the diagnostic procedure in the FSM, which is a simple continuity test.
