Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA > South Western States
South Western States Arizona, California, Hawaii, and Nevada.
Old 03-04-2006, 06:03 PM   #1
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
Davis/Sacramento: Need URGENT help to press in stud on front hub
My friend, OptionZero, broke a damn stud trying to take off a stubborn Kyokugen lug nut.
He needs immediate help replacing it. Can anyone in the Davis or Sacramento area help him out?
His cell phone # is (415) 609-0735
edit: Didn't mean to double post (this is the 1st time), such a noob mistake...sorry!
TurDz is offline   Reply With Quote
Old 03-04-2006, 07:51 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Help as far wut? Take the old stud out or put the new one in??? If it doesnt seem to fit, you prolly got the wrong stud. S14 front studs are different from the rears so make sure u got the right one. You dont have to press it in, put a washer and use the lug to pull it in.
CLICK HERE!!!
Old 03-04-2006, 07:55 PM   #3
TurDz
TurDz's Avatar
Thanks, neither of us has done this before. I'll let Jon know...
we'll probably try it out tomorrow morning. In the meantime...
1) Do we just pound out the old/broken stud with a hammer?
2) Is the back of the stud accessible without removing anything but the wheel?
Old 03-04-2006, 09:21 PM   #4
RightWheelDrive
RightWheelDrive is on a distinguished road
Is this in the front or back?
RightWheelDrive is offline   Reply With Quote
Old 03-04-2006, 10:08 PM   #5
jaae86
jaae86's Avatar
jaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enoughjaae86 will become famous soon enough
Send a message via AIM to jaae86
Chris,
If this is for the front, you need to remove the caliper by unbolting the 2 19mm bolts just behind the rotor. The rotor should be easily be pulled out after removing the caliper. Hammer out broken stud and insert new stud and use a spacer or some sort big enough to fit onto the stud. Make sure you have room to screw in a lug nut so you can use it to pull the new stud tightly into the hole. Once you have done that, check to see if the whole stud had made it all the way in. If so, just put everything back. Good luck.
Jeff Andrade
myspace.com/jeffandcrisandrade
jaae86 is offline   Reply With Quote
Old 03-04-2006, 10:56 PM   #6
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
+1 to jeff..
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 03-04-2006, 11:44 PM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
NemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfection
Send a message via AIM to NemeGuero
Yah dude, I actually put the rotor on and pulled it through like that.
Works best if you have an open ended lug nut (so the stud can extend properly).. and then just grab a lug wrench and go at it.
Do it by hand or you'll regret it later. Impacting them is normally why they break.
NemeGuero is offline   Reply With Quote
Old 03-05-2006, 12:30 AM   #8
Ritz S14
Ritz S14's Avatar
Ritz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud of
"Ghetto" way.
Hammer old stud out.
*I have Z32 brakes up front, don't know if there is room with stock calipers.*
Slide new stud behind rotor(with caliper on), and grease up a few large washers, and use an impact to "press" it back in.
Done.
Ritz S14 is offline   Reply With Quote
Old 03-05-2006, 04:14 AM   #9
TurDz
TurDz's Avatar
Thanks to all of you! I hope this job will go as simple as possible tomorrow.
I appreciate the help, this is what the west coast is all about!
Old 03-05-2006, 04:56 AM   #10
krzy
krzy is making a name for him/her selfkrzy is making a name for him/her self
TurDz... from maxima.org?
krzy is offline   Reply With Quote
Old 03-05-2006, 05:04 AM   #11
TurDz
TurDz's Avatar
Yup! hehe... who are you? Krzymax w/ the SE Limited green 4th Gen? (random guess)
Old 03-05-2006, 08:12 AM   #12
jaae86
jaae86's Avatar
Yeay!!! +1 for me.
Oh yeah, if this is for the rears, same scenario but I forgot if the caliper bolts are 17mm or 14mm. And also, make sure the ebrake is down.
Jeff Andrade
Old 03-05-2006, 10:15 AM   #13
krzy
yup! do you still have your maxima? I'm looking for a '90 - '93 hatchback now. The maxima is going to my brother.
Old 03-05-2006, 10:51 AM   #14
OptionZero
OptionZero's Avatar
OptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfection
Send a message via AIM to OptionZero
yo, thisi s the guy with the actual problem, my internet was down so TUrdz was gracious enough to help me post...and use his comfy garage
I had been using Kyokugen lug nuts and overtorqued them apparently (~80lbs, should be closer to 70ish I guess? maybe 65? i gotta check the box)
I got 4 lug nuts off, the 5th one wouldnt' come off at all because thew eight of the wheel created arseloads of tension. Forcing it is what resulted in a stud snapping.
One lugnut has the stud still in it, so i'll have to drill the remnants out or something. FOr the time being I"ll go back to stock lug nuts to avoid problems.
OptionZero is offline   Reply With Quote
Old 03-06-2006, 10:41 PM   #15
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
air chisel it out if u could... i know that les schwab sells open ended lug nuts for a good price.. i use them alot...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 03-07-2006, 12:30 AM   #16
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
i got a bunch of extra front studs at home home if u need one... but u can get them easily at like kragen or autozone. just make sure its the right thread
Sfourteen
dct223 is offline   Reply With Quote
Old 03-07-2006, 12:31 AM   #17
Irukandji
Irukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfection
Send a message via AIM to Irukandji
No need to air chisel. Just grab the wheel with the rest of the lug nuts off, and tug on your wheel until the lug nut breaks off. It only took me about 4-5 good tugs... just do a shake test on your car to make sure its not going to fall off the jackstands.
it's super easy. just do it.
Irukandji is offline   Reply With Quote
Old 03-07-2006, 01:20 AM   #18
fliprayzin240sx
Like I said...once you get the broken stud off, make sure you got the RIGHT STUD. S14 FRONTS are different from the S14 REARs and all S13s. When i broke a stud, they gave me rears and bitch wouldnt fit. IIRC rears are fatter than the fronts. Actually hey Jon, hit me up if you need studs, im pretty sure i got front studs cuz i swapped my front stocks for longer nismo studs.
CLICK HERE!!!
Old 03-07-2006, 01:45 AM   #19
dct223
dct223's Avatar
i think the frnts are fatter than the rears... i remember i bought fronts on accident to replace my rears.. and they would not fit...
Sfourteen
Old 03-07-2006, 02:09 AM   #20
NemeGuero
No more nissan.
NemeGuero's Avatar
They're like $2 a pop at kragens.
Old 03-08-2006, 05:23 PM   #21
OptionZero
OptionZero's Avatar
got one at kragen
hammered out the broken one
hammer partially the new one, then pull through with open ended lug nut
Kyokugen lugnuts = the SUCK
Old 03-08-2006, 05:51 PM   #22
Irukandji
that's why you use washers in between the lug nut and hub
Old 03-08-2006, 07:38 PM   #23
infinitexsound
oh well its fixed problem solved..
