Old 11-11-2008, 01:49 PM   #1
21Nemesis
21Nemesis's Avatar
21Nemesis has a spectacular aura about21Nemesis has a spectacular aura about21Nemesis has a spectacular aura about21Nemesis has a spectacular aura about21Nemesis has a spectacular aura about21Nemesis has a spectacular aura about21Nemesis has a spectacular aura about
Send a message via AIM to 21Nemesis Send a message via MSN to 21Nemesis Send a message via Yahoo to 21Nemesis
s13 Improving Brake Response
I've been trying to imrpove my brake response. I've got slotted rotors, Hawk SS pads, and SS brake lines. The problem is not with brake components themselves, but rather the response time that it takes from when I press the pedal to when the brakes enage. Right now, nothing happens until about half the distnace between the pedal and the floor. I would like to have the brakes engage when I press the pedal. Is there anything that can be done? I am contemplating buying EBC's Ultimax BlackDash USR Slotted Rotors and Redstuff pads. But, I really don't see how that would help. I would probably improve the overall performance, but I don't think it would help with the response time. Any ideas?
21Nemesis is offline   Reply With Quote
Old 11-11-2008, 02:02 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
maybe bleed the brake system or get a bigger master cylinder. z31 which 15/16 bore.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-11-2008, 02:46 PM   #3
aznpoopy
aznpoopy's Avatar
aznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond repute
Send a message via AIM to aznpoopy
try adjusting pin on booster that contacts rear of master
#/f/archive-faqs...ake-pedal.html
aznpoopy is offline   Reply With Quote
Old 11-16-2008, 08:50 AM   #4
Gorilla Unit 33
Gorilla Unit 33 is an unknown quantity at this point
Have you ever replaced your tension rods? It sounds like you have the same problem i had when i first got my s13. I replaced the brakes, rotors, and changed to braided stainless lines and i still couldnt figure it out. What i thought would fix the problem of shitty braking (changing the brake setup to something far more aggresssive, like your thinking), did not infact fix it at all but did improve some what. I had to jam on the brake to get any sort of somewhat good braking. Igt was all because my Tension rods were blown to shit. the rubber was almost falling out. I replaced mine with the SPL tension rods, which by far are the best mod i have done to my 240 to date. I emphasize that you use a good product for a tension rod and steer clear of the close to stock looking ones. SPL's are beefy, even have an option to run a brake duct along with them which is really cool. After i installed them i noticed that my brake pedal became firmer, and braking was now reliable at all speeds.
I know it sounds weird to some people that a tension rod can effect the braking ability of your car but it does, and i think in your case it is the problem your looking to fix.
Gorilla Unit 33 is offline   Reply With Quote
Old 11-16-2008, 09:18 AM   #5
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Adjust the brake pedal and booster output rod as per the FSM. Then bleed.
You can also upgrade the rubber flex hoses to braided hoses. The fluid pressure will not be wasted in expanding the rubber hoses, and instead can go straight to the caliper pistons.
g6civcx is offline   Reply With Quote
Old 11-16-2008, 05:16 PM   #6
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
bleed the brakes again, and use a high quality fluid.Plus whats been said about adj the booster.
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 11-19-2008, 03:59 PM   #7
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
there also mbc stopper that could help
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
