Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Misc & Accessories
Old 06-20-2011, 12:58 PM   #1
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Chase Bays Power Steering Kit
Introducing our Power Steering Kit. Aluminum Reservoir and full replacement AN fittings and line.
Please view our site for more info:
Chase Bays Power Steering Kit - Nissan 240sx w/ KA|SR|RB - Nissan 240sx - ChaseBays.com
Optional Power Steering Cooler for +$100
There is two ways to mount this. Zipties, or on the PS cooler there is a spot where you can slide in square headed bolts in and bolt it to your chassis (drilling required)
Also provided is a link to the install guide
http://www.chasebays.com/content/dow... Guide.pdf.zip
Thanks for viewing!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Chase Bays is offline   Reply With Quote
Old 06-20-2011, 01:03 PM   #2
Chase Bays
Chase Bays's Avatar
NEVER USE TEFLON TAPE ON ANY POWER STEERING CONNECTION
Let me elaborate on how exactly to bleed your system.
First of all double, and triple check that everything is tight. Loose connections might not leak but could allow air into the system. Do not over tighten o-ring hoses as the o-ring might be crushed.
Step 1: switch ignition OFF
Step 2: raise front wheels off ground (or all 4)
Step 3: turn steering wheel full left
Step 4:fill fluid resevoir to full cold mark.
Step 5: turn steering lock to lock at least 20 times, up to 40 times. If you're using our cooler it may be in excess of 40 times. DO NOT turn the wheel fast, slow is better for the bleeding process and it could likely cause fluid overflow.
Step 6: while turning wheel, check fluid level, a 2nd person is almost required. If you see any signs of bubbles/foaming, recheck all connections for leaks then repeat the steps above.
Step 7: NOW we start the engine. If fluid foams while cranking, wait 10 minutes or more until dispersed air has time to accumulate and purge through the reservoir.
Step 8: Return wheels to center and lower car.
Step 9: run engine at 2000 rpm for two minutes.
Step 10: turn wheel in both directions and check for smoothness and quiet operation.
Old 06-20-2011, 01:04 PM   #3
vas570sx
vas570sx's Avatar
vas570sx is an unknown quantity at this point
wow, that is really nice! bump for you guys!!
vas570sx is offline   Reply With Quote
Old 06-20-2011, 01:29 PM   #4
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
so what did you revise on THIS kit? I'm definitely interested.
Any shots of the reservoir baffling?
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 06-20-2011, 01:44 PM   #5
Chase Bays
Chase Bays's Avatar
We took out the COPPER crush washers on the STEERING RACK FITTINGS ONLY they were causing the O-ring fittings to not get a proper seal. The PUMP fitting still needs the crush washer/o-ring as its always been. Replaced one AN fitting with a 90 deg fitting on the reservoir and gave detailed instructions on how to properly bleed the power steering pump.
The reservoirs were changed too, pictures in a few
Old 06-20-2011, 03:21 PM   #6
yabeet
yabeet's Avatar
yabeet is an unknown quantity at this point
People who have the crush washers, should we cut them off before installing?
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’
Jeremy Clarkson on Automatics
yabeet is offline   Reply With Quote
Old 06-20-2011, 03:25 PM   #7
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
I have small leak AN fitting with a 90 deg fitting on the reservoir. i did not use teflon tape and tighen less than 15 lbs. so help me solve it issue
PIN GIO 2 is offline   Reply With Quote
Old 06-20-2011, 03:38 PM   #8
Chase Bays
Chase Bays's Avatar
Email us or give us a call.
Old 06-20-2011, 03:42 PM   #9
NickIsAZero
Trader Rating: (41)
NickIsAZero is an unknown quantity at this point
Feedback Score: 41 reviews
Taken from the website:
Features: Aluminum Baffled Reservoir with -6AN and -10AN Outlets
FAQ: Is this can baffled?
No, both outlets are on the bottom of the can, eliminating the need for a baffle.
NickIsAZero is offline   Reply With Quote
Old 06-20-2011, 03:43 PM   #10
Chase Bays
Chase Bays's Avatar
Old 06-20-2011, 03:45 PM   #11
Chase Bays
Chase Bays's Avatar
OOPS, thanks for the heads up. We recently went in and modified that. Fixed now
Old 06-20-2011, 07:43 PM   #12
speedgod^s13
So, are the lines black, or silver? In the first picture, there is a silver line, but in the install picture, they are all black.
speedgod^s13 is offline   Reply With Quote
Old 06-20-2011, 07:47 PM   #13
h815 240sx
h815 240sx is an unknown quantity at this point
high pressure is silver, low pressure and ps reservoir to pump are black
h815 240sx is offline   Reply With Quote
Old 06-20-2011, 08:45 PM   #14
chiboy002
that picture wtih all black lines is also from the old set up. different reservoir
street dancer.
Old 06-20-2011, 10:57 PM   #15
speedgod^s13
Thanks for the fast replies, i'll be picking up one of these kits in the future. First kit kind of had bad reviews. It sounds like the kinks have been worked out though.
Old 06-21-2011, 09:01 AM   #16
Exas Spec D
Exas Spec D's Avatar
Exas Spec D is on a distinguished road
I will purchase. Would this work on a VH45DE swapped S13? Should be the same right?
#/f/image.php?type=sigpic&userid=71648&dateline=123643  0746
Exas Spec D is offline   Reply With Quote
Old 06-21-2011, 09:05 AM   #17
NismoTuner21
NismoTuner21's Avatar
NismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enough
I really want to get this for my 1JZ Z32 swap, just gotta make sure S-chassis racks and Z32 racks have the same size bolt/thread pitch.
NismoTuner21 is offline   Reply With Quote
Old 06-21-2011, 03:33 PM   #18
Chase Bays
Chase Bays's Avatar
All Pm's Sent!!
Bump to the Top!!
Old 06-23-2011, 11:21 AM   #19
Chase Bays
Chase Bays's Avatar
Bump to the Top!!
Old 06-27-2011, 11:50 AM   #20
s14unimog
s14unimog's Avatar
Originally Posted by Chase Bays View Post
(reservoir picture)
Thanks! I'll be ordering a kit once I get my tubs finished. Free Bump!
Funny guy! Why do you think I capitalized "THIS"?
Old 06-29-2011, 09:07 AM   #21
Chase Bays
Chase Bays's Avatar
Morning Bump to the Top!!
Old 06-30-2011, 12:06 PM   #22
Chase Bays
Chase Bays's Avatar
All Pm's Sent!!
Bump to the Top!!
Old 07-06-2011, 11:17 AM   #23
mdlesk
mdlesk is an unknown quantity at this point
I have the same problem. Chase Bays advised me to remove the crush washers on the rack for those leaks, but never suggested anything regarding the large fitting at the reservoir.
mdlesk is offline   Reply With Quote
Old 07-06-2011, 12:46 PM   #24
Rally240sx.com
Rally240sx.com is an unknown quantity at this point
mine leaks alittle from the res, and I cant get the pump to stop whining
Rally240sx.com is offline   Reply With Quote
Old 07-06-2011, 03:55 PM   #25
jdm2191
jdm2191's Avatar
Trader Rating: (79)
jdm2191 is an unknown quantity at this point
Feedback Score: 79 reviews
How shipped for a S13 w/ 1JZ shipped to 92551?
My Build: The "Coupe De Ville" 1JZ Build!!
jdm2191 is offline   Reply With Quote
Old 07-06-2011, 04:16 PM   #26
PIN GIO 2
PIN GIO 2's Avatar
do you guys have problem with idle when turn right or left will make engine go almost dead and whining?
Old 07-06-2011, 05:35 PM   #27
Chase Bays
Chase Bays's Avatar
If you guys are having issues please call us or email! Don't just complain about it! We're here to help.
This is related to the power steering sensor that gets deleted like on our kit and ISIS's, Sikky, any other high pressure hose replacement thats out there. Its there to raise idle if turning left to right while parked, but I find it annoying. Also, theres no need to turn your wheel left to right when idling
Old 07-06-2011, 06:01 PM   #28
PIN GIO 2
PIN GIO 2's Avatar
I know ps sensor deleted, it didn't to raise idle.. it go down like dead engine... sometime when i turn wheel left or right then my engine went to dead then i have to engine start. Before installed, there no problem... could be this kit or else?...
Old 07-07-2011, 10:24 AM   #29
Chase Bays
Chase Bays's Avatar
The power steering pump of course uses the engines drive belt and like an AC compressor it's going to put "load" on the engine. You might also notice on your other cars (usually 10+ year old ones) when you turn your headlights on, crank the radio up, anything that puts load on the electrical system and/or engine...the idle will drop and/or lights will become slightly dim.
There is a few things that can cause this. Your IACV/AAC is supposed to regulate your idle to compensate but sometimes it can't fight with our weathered components. The first thing is going to be the alternator. Depending on your engine the alternator amp rating is 70 to 135+ amps. You want 100+ amps. Every decent sized city has a shop that can repair and rebuild an alternator or at least test it. Those auto parts store replacement alternators are awful so beware.
Equally important is replacing your battery/alternator/fusebox power wires & grounds. Stock they're usually 10 or 8 gauge which is sufficient depending on your starter and alternator amp ratings but the wires are OLD. I recommend 6-8 gauge for alternator and 0-4 gauge for starter. Engine/Trans ground's 8 gauge and Battery Ground 0-4 gauge.
These items from us will help you:
CUSTOM LENGTH Battery Cable's
Electronics/Wiring - ChaseBays.com
Chase Bays Engine Ground Kit
Chase Bays Engine Ground Kit - Nissan 240sx - ChaseBays.com
Old 07-19-2011, 05:52 AM   #30
hotkarl
hotkarl is an unknown quantity at this point
So I can buy a full ls1/s13 ps line setup from you guys?
hotkarl is offline   Reply With Quote
