#6152 |
![]() Join Date: Sep 2008
![]() Feedback Score: 20 reviews
hey everybody! I got tein tie rods inner/outer with gktech high tensile offset steering rack extenders and extenders 15mm lower control arms. what do you recommend use knuckles? i use oem knuckles, do i need modification knuckles?
#6153 | |
![]() ![]() ![]() Fairly bumpy course with some hard hits. Stuff seems to have held up without issue. Appears to be fairly light as well. ![]() |
#6155 |
Those pics come from DG Motorsports in France, they use to work on my car and made my Z33 gearbox adapter plate for my SR20, they sell those keisler here. They made this comparison between the wisefab and the keisler for a customer that changed the wisefab to go with the keisler. Even if it's lighter, I'm still not convinced by those keisler stuff. I saw a post where someone (Def iirc) said they are not so well designed and I think they seem weak compared to other brands like PSM or TDP. I have driftworks stuff in front and would rather go with PSM or GKtech next year as I'll have to replace all of those. Any info to share as to what makes them inferior to the top contenders around (TDP/PSM/GKtech/Driftworks)?
#6158 |
![]() Join Date: Apr 2004
The thin cross section of the knuckle is not good when you load the tire up laterally. It makes the knuckle bend in a U shape.
#6160 |
I figured this would be the best place to post here.
I am in a Junior Mechanical Engineering Design class and for my project proposal I chose to design a modified knuckle to achieve more steering angle and achieve corrected roll center when the car is lowered. What I am looking for are the dimensions for a stock s13 knuckle that I can base the geometry off of. If anyone can help me out that would be great or have any input for my design project. |
#6162 |
![]() Join Date: Nov 2005
Check this out, GKtech has a great idea here. Their new rear knuckle is compatible with stock arms, but has revised kinematics, sphericals, and actual Z32 drum brake compatibility. Pretty cool.
#6165 |
I hope those are 300ZX rear caliper brackets!
Gee Spot Garage, doing things you don't. |
#6167 |
Yes I mean both of them are.
#6169 |
They should figure out a way to add all the adjustment bits to the knuckle. Perhaps by using a shim system, similar to their RLCA. That way the knuckle would become the end-all rear suspension part, so there would be no need for any other aftermarket arms.
#6170 |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
There is no perfect solution to adjusting alignment, they all mess with kinematics. A shimmed system would require total redesign, increase weight and complexity significantly and the upper arm loads are small anyway so if you are really on a budget the ebay arms are fine as long as the welds hold and rod ends have no play
#6171 |
![]() Join Date: Jun 2004
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
What is everyone doing to get more travel from the rack? Right now I'm running pbm inners with an added spacer on the passenger side and then recenter the rack. I have clearance for a lot more angle if I could get more travel but I think the rack will hit the inner seal if I add any more spacer.
#6174 |
![]() Join Date: Apr 2010
Once you get you extra 7mm om the driver side and 12 mm om the passanger side you done. You want get more from the rack. Honestly most people don't even need it when what they really need is to continue practicing to be a better driver.
Sent from my SGH-T999 using Tapatalk |
#6175 |
Trader Rating: (18)
Oh I should be a better driver. Got you. I'll work on that. Lol
All I needed to know was if anyone was getting more travel. Clearly I've done by homework. I'll just cut more off the knuckle. My knuckles are 1" shorter because it used to be the max rules would allow but I see from pics that wisefab is a lot shorter. |
#6176 |
![]() Join Date: Jun 2010
So... been searching for awhile for TDP angle kit as I would like to try it out but I keep finding it for about $2,800 shipped...
Anyone know where to find it cheaper?
S14 KA NA two cylinders, 75whp limper |
#6178 | ||
This is the roll center, suspension pickup, and steering angle modification t...
They are only available through TDP, there are no U.S. distributors. Quote:
Don't forget to reduce your ackerman for max angle. |
#6179 | |
All the sites that I find that do sell them are mostly in Europe and the cost is about $2800 shipped. So assumed that is the price for these? Which is fine, I will just continue to go with wisefab, was just wondering if they were any cheaper than that anywhere else?
#6180 | |
![]() Join Date: Mar 2009
I run 2 rack extensions with pbm spacer on both sides, no problems. |
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
