#4801 |
I want to weld a spherical onto my FLCA but have no idea which one to buy. Do you guys have any links or preferences? I have no experience with sphericals/rod ends.
Thanks. |
#4807 |
Yes i raised front crossmember 35mm and also the tierods 35mm inboard mounting points. Iam gonna try 17.5mm in the middle next
![]() Ive only had 10 laps with it. It is soooo easy to drift ![]()
[SIGPIC][/SIGPIC] |
#4808 |
I'll try make the pics smaller
![]() EDIT: I thought I would add that when I say easy to drift I mean really really easy. I had never driven this car before. My first laps were top 32 qualifying of the UK open drift championship. I qualified 3rd, then knocked out the driftworks s15 in the top 16 battles and I ended up finishing in 3rd place overall ![]()
[SIGPIC][/SIGPIC] |
#4810 |
![]() Join Date: Sep 2008
That looks like a nice kit, but sadly I dont think it will work on my Q45. It uses the same knuckle as a r32/z32 but the LCA is different and so is the 3rd member/uproght.
-Mike |
#4812 | ||
![]() Join Date: May 2008
Those definetely look promising. I wish i could see more pics, I tried searching Tdp on FB and nothing popped up. I just dont like how it widens my track so much. Could I shorten the LCA and keep my current wheels or would defeating the purpose... |
#4813 | |
You would be defeating the purpose of the adapter, if you were to shorten your LCA.
-Mike |
#4814 | |
you need that angle, roll center, and bump steer correction in your life even if it means eating top-ramen every day until you reach your goal = )
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#4815 |
![]() Join Date: Dec 2006
Dan you know i'm getting knuckles at some point lol, but i'm going in stages, My Ikea rods are toast and i already have some LCA to extend. So figured i could do the rack bushing i have new tie rods and extended LCA. i dont mind the stock angle b/c i just dick around on the streets. But i might be buying knuckles soon regardless so i can fix the f**king bumpsteer and killing of tie rods/ends / ball joints
#4816 |
understood, if you do push to get them, even if you never use full lock unless you are in the rain, the car will handle like a go cart & be stable in turns with the roll center / bump steer elimination knux and the quicker steering character is fun even around town and changing lanes on the freeway.
This is why many people choose the pro mod for their DD
#4817 |
ya, not to mention i've brian washed my self with the desire to be Haruguchi low(tho i doubt ill ever be that low), build proper slammed cars and have fun !
#4818 | |
Or could i just get ur pro knuckle and use oem s14 LCA? the car will be used for grassroots drift events |
#4819 |
![]() Join Date: Jun 2010
read almost all 160 pages, but still have some q's
extending lca is best option for gaining inboard clearance at full lock? wheel offset seemes to be more important for tc rod clearance. how far to extend s13 lca? 15-30mm? also which are the best companies in north america modifying knuckles for angle only? MA, garage autohero, drift speed, kpr? will PBM modify knuckles for angle only? (no roll center correction) need moar angle for next season. been running stock and a godspeed angle spacer was a major headache that would not work with my setup. |
#4822 |
that bolt on knuckle mod has got me confused.
It looks to me like they would increase scrub radius by a large amount and also reduce the kpi a large amount also. i wonder if they adjust the top mounting point at all
[SIGPIC][/SIGPIC] |
#4823 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
^ yes, that's definitely my biggest concern. offsetting the old ball joint pickup so far out from the new pickup just made for a big scrub radius. can't see that being particularly advantageous over a drop-spindle like PBM's or GKTech's.
#4824 | ||
so my question remains, which is the best company that is modifiying these knuckles? my biggest concern is the strength once modified. everyone here knows how difficult cast iron is to weld. my local fabricator could cut and weld but it would be the first pair hes done and i sure as hell wouldnt be comfortable throwing my car into a drift at 60+mph and having the tie rod snap off. ideally new castings such as era1, welded plates like driftworks or billet like that company from ireland would give best strength, but those are the most expensive options, for me to gain a little angle. |
#4825 |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
The rollcenter imbalance doesn't seem to cause much problems with my car. I had drop knuckles in the rear and destroyed one hitting a kwall. I went back to stock knuckles in the rear and managed to get back on the podium for round 3 of my local proam. I feel you should just save and do it right the first time.
#4826 | |
![]() Join Date: Jul 2005
Trader Rating: (354)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 354 reviews
#4829 |
![]() Join Date: Feb 2012
![]() Yes, more info on this please!!! For $600 the Abercrombie kit looks amazing.
ACE マジック HEART |
#4830 | |
actually to make a casting copy of a plate design is not ideal because you are combining low density steel with a thin wall design. It bends. No one has ever broken our S chassis welded knuckle mod, no matter how hard the crash, its the only thing to survive in some cases, very good steel.
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
