Old 08-05-2008, 07:57 PM   #1
sidwaysparty
sidwaysparty is an unknown quantity at this point
s13 idling/running like crap in general
well the other night my gf filled up our s13 with some gas from a gas station that isnt really well known. now about 3 hours later the car started to loose some power. i would shift a gear and put my foot into it and i the car would hesitate for a second then it would speed up. later that night it got to the point where the car was on the verge of stalling out and eventually did. now i know that the bad gas is probably part of the reason, but i was wondering if anyone else has had that same sort of problem and how did they fix it. granted we are getting a bigger fuel pump, fuel filter and a whole bunch of other stuff that the car needs anyway but i figured if someone has had this happen before they would know something we haven't thought of yet
sidwaysparty is offline   Reply With Quote
Old 08-06-2008, 12:09 AM   #2
FRISBEE
FRISBEE is an unknown quantity at this point
get rid of the gas save it for your lawnmower, Put gas at only good name brand stations such a Chevron/Texaco, Shell, Sunoco those are my three pics.
FRISBEE is offline   Reply With Quote
Old 08-06-2008, 07:49 PM   #3
sidwaysparty
ya i use shell all the time in my WRX too. she just didn't realize there was much of a difference when she filled it up.
Old 08-09-2008, 01:13 PM   #4
jdm510
jdm510 has made poor choicesjdm510 has made poor choicesjdm510 has made poor choicesjdm510 has made poor choicesjdm510 has made poor choicesjdm510 has made poor choicesjdm510 has made poor choices
or maybe a injector???? quick way to check to while its running unplug each one at a time should have a change like you unpluged the spark plug wire
i been having the same kind of running problem it was the bottom O-ring on my injector going out.....weird
jdm510 is offline   Reply With Quote
Old 08-10-2008, 06:29 PM   #5
sidwaysparty
ok i will try that as well
Old 08-21-2008, 03:12 PM   #6
KC20DET
KC20DET is a well-known jackass
Yeah i feel i cant fill anything beside 91 or the idel will be all whack.. and if i do fill up its eitehr cheveron or Shell. 76 n mobil sometimes. but NEVER ARCO....
KC20DET is offline   Reply With Quote
Old 08-22-2008, 08:09 AM   #7
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
Might want to check your plugs too. Bad gas can foul one or more plugs.
alzahakar is offline   Reply With Quote
