Old 02-18-2009, 11:24 PM   #1
bees
bees is on a distinguished road
HELP! stock alarm keeps going off!
jw if anyone knows anything about the factory alarm. i have 95 se and it appears to have a factory alarm. when i bought the car, it came with an aftermarket alarm. after replacing the main harness, the aftermarket alarm was removed. the factory alarm has been ok till now. the factory alarm now goes off for no known reasons. i still have the original alarm key fob but dont know how to sync them together. does anyone know how to resolve this issue? or have a wire diagram? thanks for all the help and support
bees is offline   Reply With Quote
Old 02-18-2009, 11:51 PM   #2
projectRDM
projectRDM's Avatar
The FSM has a wiring diagram.
The OE alarm system triggers from either the key cylinders receiving an intrusion, the doors being opened, or the trunk/hood being opened. When anything is open on the car and the system and ignition are both off, you'll get a constant flash of the LED, so it's easy to diagnose. Get in the car and close the doors. If the LED continues to flash, either the trunk or hood switch is triggered (open), more than likely it's the hood since the rubber bumper on the hood that depresses the switch usually wears or breaks off. Unplug it temporarily to see if the LED goes out. If it does, buy a new hood bumper or rig something to the hood to depress the switch fully when closed. If it does not, the trunk trigger could be bad, unplug it as well to test.
You don't need the remote, it will arm through locking either door with the key, and disarm via unlock.
FORMERLY R240NA
Old 02-19-2009, 01:08 AM   #3
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
lmfao,
that reminds me of my car, i just tore it all out.
redsx13 is offline   Reply With Quote
Old 02-19-2009, 08:09 AM   #4
projectRDM
projectRDM's Avatar
Originally Posted by redsx13 View Post
lmfao,
You can't remove the OE alarm, it's integrated into the smart entrance control unit. Not unless you don't want power door locks, rear defogger, key warning chime, or a domelight too.
FORMERLY R240NA
Old 02-19-2009, 09:00 AM   #5
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
I know this is a shot in the dark, but would you happen to know if 94 Camry's have factory alarms built into the ecu?
Sometimes you can go into the car and put the key in, and the CEl stays lit constantly and the OD/OFF light will start flashing.
I know that sometimes the door switch is a little slow to turn on the dome light. Perhaps the car thinks it's being stolen?
Drives perfectly. Freeze frame data comes up empty. No code. Just constant CEL and OD/OFF light flashing.
Thanks.
g6civcx is offline   Reply With Quote
Old 02-19-2009, 11:02 AM   #6
projectRDM
projectRDM's Avatar
CEL and OD lights together are a transmission problem. Toyota parallels them to indicate a code is stored, pull the codes and diagnose.
FORMERLY R240NA
Old 02-19-2009, 12:26 PM   #7
g6civcx
g6civcx's Avatar
Like I said above, we tried to pull the code but it came up empty. The freeze frame data also came up empty.
I don't know what else except that the auto ECU is faulty.
Old 02-19-2009, 02:28 PM   #8
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
reminds me of my car. It would go off at random times. I just took the relay out to the headlights and horn on the alarm fuse box.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 02-20-2009, 03:44 PM   #9
bees
turns out, it was the hood trigger! thanks again projectRDM! seroiusly, is there anything u dont know about the s chassis?!
Old 02-20-2009, 05:25 PM   #10
projectRDM
projectRDM's Avatar
Maybe. But it's nothing anyone has ever discussed.
FORMERLY R240NA
Old 02-28-2009, 04:49 PM   #11
d-magic
d-magic is an unknown quantity at this point
Ok, I have the same problem....alarm goes off randomly. I haven't checked those switches yet, but I have a short between my dome light and alarm. My fuse for interior light keeps blowing. I took out the relay and the lights work without blowing fuse, but can't start the car obviously. Does anyone have a clue of what the cause is? My wiring diagram doesn't show me a link between the interior lighting and alarm. It's done this 3-4 months after putting on my body kit with blister fenders. I had a body shop put it on for me. thought that would help.
d-magic is offline   Reply With Quote
Old 03-01-2009, 11:00 AM   #12
projectRDM
projectRDM's Avatar
You took out what relay? There is no relay for the interior lighting circuit. Just randomly pulling shit out of the car isn't the answer.
Apparently the body shop did some wiring damage so start tracing their work.
FORMERLY R240NA
Old 03-05-2009, 08:29 PM   #13
d-magic
let's try alarm relay...you know the small relay box that says "ALARM" that everyone else above has been talking about. Like i said before, when i pulled the relay "ALARM RELAY", the lights will turn on and off without blowing fuse.
I did go through the exterior lighting harness around the bumper area, and did not find any chaffing, frayed, or cut wires when the problem started.
Old 03-05-2009, 10:57 PM   #14
projectRDM
projectRDM's Avatar
No one has been talking about relays, we've been discussing the hood switch. Relay does not equal switch.
But since you're going to try and be a smart ass, I'm done with helping in this thread. Fix it yourself smart guy.
FORMERLY R240NA
Old 06-05-2011, 08:30 PM   #15
Brentbohn
Brentbohn's Avatar
Brentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choices
does having a smart enterence module automatically mean I should have keyless and an alarm? I was under the impression I didnt have either. I do have power locks.
Wanted: Good well mannered athletic woman with her own classic or sports car.... send photo of car
Brentbohn is offline   Reply With Quote
