Old 01-05-2010, 04:34 PM   #1
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
SR Apexi optional boost control kit..HELP!!!
Alright, after like 5, maybe 6 months having having this thing (optional boost controll kit with power fc), i still can't figure it out!!! I've been running on the wastegate for a while and trying to figure it out.
Here is how i have my kit connected:
Map Sensor
[Power FC]----[Map Sensor]----[Filter]----[tee to fuel pressure vac]
Valve (power and grounded already of course)
[Valve]--[COM]--[wastegate]
[NO]--[tee with bov]--[vac/nipple on tb]
Thing i dont understrand is, why isn't there anything connecting the map sensor to the valve, or something so that something can actually know how to controll the boost? am i suppose to use the other hole on the valve for something else, maybe connecting it to the map sensor?
Is the really just suppose to be power and ground? If so, how will it get a signal from the power fc to controll the boost then? Does it require the use of the stock boost valve (or whatever its called) that suppose to come stock on sr's?
Please help me out!!!!
bl3ujay07 is offline   Reply With Quote
Old 01-05-2010, 04:52 PM   #2
slider2828
slider2828's Avatar
On the side of the Power FC, there is a port for the boost controller right? There should be a electrical line between the PowerFC and EBC itself.
Turn and Burn!
Old 01-05-2010, 05:16 PM   #3
slider2828
slider2828's Avatar
Apexi PowerFC FAQ
Its also on my POWERFC FAQ here
Turn and Burn!
Old 01-05-2010, 06:00 PM   #4
bl3ujay07
bl3ujay07's Avatar
^^^I have been going and reading through that post. The port is for the map sensor. All the boost controll valve has is a power and ground wire.
Old 01-05-2010, 06:07 PM   #5
slider2828
slider2828's Avatar
Nooo... you gotta splice it together.... isn't that what it says?
" The solenoid piggybacks off the Pressure Sensor wiring harness which leads to the PowerFC connector port"
Turn and Burn!
Old 01-05-2010, 06:27 PM   #6
bl3ujay07
bl3ujay07's Avatar
So you have to splice the map sensors power and ground wire, and connect it with the boost valves power and ground?
Old 01-05-2010, 06:35 PM   #7
slider2828
slider2828's Avatar
yup /................................. Also don't forget to enable boost controller kit after you done with the install which is in the menu of the powerfc....
Turn and Burn!
Old 01-05-2010, 06:54 PM   #8
bl3ujay07
bl3ujay07's Avatar
^^^Yup...THANKS A WHOLE BUNCH!!! Ill go home after work to try and out and let you know.
Old 01-05-2010, 06:58 PM   #9
S14DB
AFC #1
S14DB's Avatar
This the MAF or MAP PowerFC?
MAF one the MAP should plug into the port on the side for the BCK and the solenoid into the stock solinoid plug.
Old 01-05-2010, 07:08 PM   #10
bl3ujay07
bl3ujay07's Avatar
MAF, L-jetro.
The stock solinoid plug, that was what i was refering to on the first post. What if i dont have that, can i still just piggy back it to the map sensor harness slider282?
Old 01-05-2010, 07:14 PM   #11
S14DB
AFC #1
S14DB's Avatar
Get a solenoid plug off someone that cut it off during the swap and wire it back upto the main harness.
MAP harness plugs into the side of the powerFC.
Old 01-05-2010, 07:19 PM   #12
bl3ujay07
bl3ujay07's Avatar
So the stock boost solenoid is a must have in order for the boost controller to work then? hm... Other boost controllers like hks ez and greddy profec spec II dont require the stock solenoid does it?
Old 01-05-2010, 07:31 PM   #13
S14DB
AFC #1
S14DB's Avatar
They assume that you already have the solenoid connector stock. As this was made for JDM. Unfortunately most people that make harnesses in the US snip it off.
It uses the same sensors and logic as the apexi avcr. But, is integrated into the PowerFC.
Old 01-05-2010, 11:14 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Stock boost solenoid is not needed for stand alone electronic boost controllers. They come with everything you need to work and they have nothing to do with the stock harness or ECU.
The boost control kit for the PFC works in conjunction with the PFC. It needs the stock wiring for the PFC to control the actuator valve.
CLICK HERE!!!
Old 01-05-2010, 11:26 PM   #15
bl3ujay07
bl3ujay07's Avatar
Well, for future references (if needed), i went with slider2828's solution first bc i dont have the stock boost solenoid. Cut and solder power and ground from the control valve onto the map sensor harness that connects to Power FC and it worked out good.
Boost seems to kick in faster and smoother although i still have to adjust the boost setting a tad.
Thanks again slider2828
Old 01-06-2010, 10:52 AM   #16
slider2828
slider2828's Avatar
Just double check everything I think s14DB has a good point, but I think you have the 5 wire plug for the PFC, which is kit type 2 which works ok.
So I think it depends which Boost Controller Kit Type # your using, which depends on which plug you have that runs to the PowerFC (3 wire plug or 5 wire plug)....
Turn and Burn!
Old 01-06-2010, 11:07 AM   #17
bl3ujay07
bl3ujay07's Avatar
Yeah, i have been reading about other people using the stock boost solenoid with the boost kit. I have the three wire plug. Untill i find a stock boost solenoid, ill run it this way for a while.
Old 01-06-2010, 08:32 PM   #18
S14DB
AFC #1
S14DB's Avatar
You DO NOT run the stock solenoid. You connect the solenoid in the kit to the stock plug on the engine harness.
I didn't know the 5 wire harness worked on the SR20DET Power FC. I thought it ran the 3 wire and the RB ran the 5. My PowerFC has 3 pins on the side.
Old 01-06-2010, 08:51 PM   #19
RYAN_S-14
RYAN_S-14's Avatar
RYAN_S-14 is an unknown quantity at this point
Send a message via AIM to RYAN_S-14
Map Sensor
I dont use the vac line off the FPR for saftey reasons.
honestly the install shoud be easy, when i did the install a long time ago i had a blown fuse in the fuse compartment so the controller did not work...
Also the set up is easy and the boost contreoller should be faster because it holds the valve shut untill the last optimal time thats what the numbers are for on the power FC i forget if larger is open faster or slower you should be able to figure it out on a good street run. Play with it a little i loved my Power FC controller, i heard bad reviews but i liked it.
Also if you want to go the cheaper route you can get the parts and piece them together i.e. get a sylinod from a apexi boost controller or used and i think the pressure sensor is the same from a RX7 or there is som OEM car with it.
I think i paid like 35$ for mine i was i Japan too but still i pieced it together
RYAN_S-14 is offline   Reply With Quote
Old 01-06-2010, 10:03 PM   #20
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
the intake air temp sensor for the d-jetro is a fd rx7 IAT , the d-jetro map sensor is not the same as an fd rx7 map sensor, however you can calibrate the map settings and use it but i do believe it's a 2 bar irrc which kinda sux. it'd be better to use a 3 bar gm map sensor...but what's the point? if you're gonna spend the money on the d-jetro....get the rest of the d-jetro stuff too.
OPer did you get your boost adjustability working properly or no?
Dave
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
Old 01-06-2010, 10:04 PM   #21
Sileighty_85
Sileighty_85's Avatar
For the solenoid wiring
#/f/tech-talk/223428...-question.html
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-06-2010, 10:18 PM   #22
RYAN_S-14
RYAN_S-14's Avatar
Dave
Thanks for clarrifying
Old 01-06-2010, 11:57 PM   #23
fliprayzin240sx
IIRC, they have different part numbers for different years SR20DETs. Its not a 1 kit fit all setup.
CLICK HERE!!!
Old 01-07-2010, 01:58 AM   #24
bl3ujay07
bl3ujay07's Avatar
Dave
Yeah, after i piggybacked the sensor to to map sensor harness, its working now. now is just a matter of adjusting the boost duty cycle. I was thinking about getting the d-jetro, but i spoke with steve, and decided to go l-jetro. Was going to go with the apexi avcr or the new hks boost controller, but i decided to just go the route and controll all with commander. Plus, i want things hidden as much as possible and didnt want the extra attention with extra gauges or the avcr controllers.
NVM
Old 01-07-2010, 02:00 AM   #25
RYAN_S-14
RYAN_S-14's Avatar
Yeah, after i piggybacked the sensor to to map sensor harness, its working now. now is just a matter of adjusting the boost duty cycle. I was thinking about getting the d-jetro, but i spoke with steve, and decided to go l-jetro. Was going to go with the apexi avcr or the new hks one, but i decided to just go the route and controll all with commander. Plus, i want things hidden as much as possible and didnt want the extra attention with extra gauges or the avcr controllers.
NVM
Im 85% sure you need the apexi one
Old 01-07-2010, 02:02 AM   #26
bl3ujay07
bl3ujay07's Avatar
I bought the apexi one so i can controll it using the controller yes. At first though, i was thinking of getting a separate boost controll unit, like the apexi avcr.
Old 01-07-2010, 02:09 AM   #27
RYAN_S-14
RYAN_S-14's Avatar
i used the power fc controller for over 2 years and did not have over boost issues after the initial install, it worked great, i used 2 setting one low one high boost and there are 4 total. I used the same parts listed in the kit, i had a S-14 with a power FC D-Jetro with boost controller, and a wideband AFR, apexi turbo timer, etc. etc.
Old 01-07-2010, 07:00 AM   #28
Z U L8R
Z U L8R's Avatar
sweet
i think all the confusion could have been avoided if the damn instructions weren't in japanese :P
bluejay, for all intensive purposes, when you get the time, it would help others if you made a how to DIY thread.
Dave
Old 01-07-2010, 07:59 AM   #29
RYAN_S-14
RYAN_S-14's Avatar
sweet
Dave
here is a link that might help a DIY would definitally help
Apexi PowerFC FAQ
Old 01-07-2010, 10:33 AM   #30
slider2828
slider2828's Avatar
sweet
Dave
Hey ZU, just want to make sure.... most people make this mistake, but its "for all intents and purposes"....
Turn and Burn!
