Old 09-30-2001, 09:13 PM   #1
AUtyger
AUtyger is an unknown quantity at this point
My '91 240SX 5-speed suddenly began to miss fire and hesitate. After new cap, rotor, plugs, and wires, I found that #4 piston seemed to have no life. You could disconnect the wire or the injector, and notice no change in the extremely bad idle. I swapped the #4 injector with the #1 injector, and the problem now is on the #1 piston. So, I ordered a new injector, installed it, and still have a really bad idle. Must I remove the fuel rail, clean it out, and reinstall everything? Am I barking up the wrong tree? I bought the car, as a toy, a few months ago, and I am a Nissan newbie. Any help is greatly appreciated!
'91 240SX SE 5-speed[br]War #### Eagle!
AUtyger is offline   Reply With Quote
Old 10-01-2001, 08:02 AM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Yeah, I would suggest checking the fuel rail. P.S. Since, it's broken, upgrade it at the same time: Get a better fuel pump! <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Post back with results!
Irena
S13Grl is offline   Reply With Quote
Old 10-01-2001, 09:01 AM   #3
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
did u order your injectors already?
i ahve some used ones....... i wanna sell them...... let me know....
drifterx is offline   Reply With Quote
Old 10-01-2001, 09:46 AM   #4
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Okay, it sounds like you may have isolated the problem to the injector. &nbsp;After you replaced it, did you notice any improvement? &nbsp;What I am thinking is that the ECU might have learned to adjust for this and is continuing to do so. &nbsp;IIRC, resetting the ECU is a PITA (involves disconnecting the battery for 2 days or something). &nbsp;Anyone know more about this? &nbsp;
HippoSleek is offline   Reply With Quote
Old 10-01-2001, 09:54 AM   #5
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
to reset the ECU, disconnect the battery for 1/2 an hour.
ca18guy is offline   Reply With Quote
