![]() Join Date: Nov 2009
My Constant Sleepy Eye mod.
Im going to start my own permanent "sleepy eye" modification for my 91 coupe.. I had to decide which headlight to go with that would fit nicely and have the correct height and width. I started thinking of car with thin headlights and of course the 88-96 pontiac grand prix coupes came into mind and also the mid 90's camaro's. They looked like this:
Im going to have to use the normal headlights for this, but ill post up later about how it goes. For now this is my mock-up. It seems as it will work very well, but I guess we'll see... Sorry Guys: heres some progress, computer has been actin horrible lately and its hard to do this mod since i cant drive at night with one headlight only as im working on the other headlight... Baked the headlamps for 6-7 mins at 325ish degrees (glass lense comes off easier when glue holding it is heated), and that was perfect timing cause a tiny bit of reflective material started bubbling inside...phwww. also removed projector peice (obviously) took this shiz off: MOCK UP: I cut the corners of the old headlight housing (near the top) ans siliconed it. It will probably need to be epoxyed... (due to little vibration) and i mount a bolt/washer at the bottom with use of a hose clamp, very strong mounting system. A DIE GRINDER WORKS WONDERS FOR THIS JOB......!!!!!!!!!!!!! Once again a die grinder is your best friend if you wana do this like I did: Bolt mechanism: Buncha grinding: Here it is in normal headlight rest position, i also made an acrilic plastic cover (held by tape for mock up). It was the hardest part about doing this conversion... very hard to grind it correctly for nice fitment. I used a bench grinder and it worked wonders! Sleepin: Looks terrific in person (lights up the road very well with the halogen that came in it, its better than the stock headlight.) Last edited by ghudson; 02-19-2010 at 09:40 PM.. Reason: finally got progress done... |
![]() Join Date: Mar 2003
I was also on the hunt for some slim oem headlights for my supermade buckets. I bought the ones from the old camaro too lol. I gave up on it though. Good luck with your mod. Looking forward to the finished product.
Still have those camaro slim lights if anyone is interested /threadjack |
nsx is sexy:] i vote those. can you still have them down with this mod? or do yu have to keep them up like this? just curious
WTB: 1/24 scale chuki s13 model. |
Bandwagon.
^^^^ yes yes, NSX are smeexy as FUCK!
&& they forever stay at where you place them ![]() |
![]() Join Date: Jan 2008
i did that with my head lights on my old car.. the head light cover was fixed and i made some brackets for the fog light housing and threw hid in them. i also had s14 yellow beside them..
Exclusive Auto Garage |
![]() Join Date: Dec 2007
#17 | |
![]() Join Date: Jan 2004
there are a million threads on this shit.
the reason in not buying any of the kits for this is that none of them just had a square reflector only headlight, there was always some projector type thing or something. I a reflector only type guy usually so thats my reason for doing this. And also these sylvania's are slightly smoked which I thought looked great. here's a link:
Amazon.com: Sylvania H4351 Standard 12.8v 55-Watt Rectangular Halogen Headlight: Automotive |
#19 | |
have you ever owned these? ever side by side compared them to a stock halogen 6054 garbage output spec stock s13 headlight? go ahead ill wait for you to prove to me it puts out more/better/clearer light. |
#20 | |
whatever setup you choose to do, update your car and steer away from halogen housings (especially if your going to run such a physically small housing) |
#24 | |
Nsx
Thanks and sorry for posting this on your thread man.
#25 |
im suggesting just the super made housings. not the headlights that come with it which are corner store foglights with no projector lenses. also there is nothing wrong with the projector style NSX lenses other than the astronomical cost for them at the moment.
#29 | |
![]() Join Date: Jun 2004
you really understand how. headlights work? as opposed to driving lights? clearcorners.com |
