300zx rears while still being 4-lug?
Anyone seeing a problem with just swapping the rotors(redrilled), calipers, and the emergency brake assembly... without chaging the rear to a 5-lug?
Rich |
yea, get the rotors re-driled to 4lug
#3 | |
![]() Join Date: Sep 2002
but keep in mind that swapping to 5-lug will sincerely open up your options for wheels as well
![]() Join Date: Oct 2002
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
Yep, can be done with redrilled rotors. my Z Brake setup will be all four corners (30mm Alum.) with the e-brake assembly...
Bryan
now all i hope is that nobody snagged them in the last hour they were open.
Rich Which backing plates should/can I use... the stockers cut, the z32 plates? the reason i ask is because one of the backing plates it trashed on the parts car. Last edited by RichthePoser; 04-24-2005 at 01:18 AM.. |
![]() Join Date: Dec 2002
You need to use the Z32 backing plate for the ebrake.
