![]() Join Date: Apr 2005
Upgrading parts. MANY QUESTIONS!!!
So I am upgrading my turbo setup. Many questions.
Its a sr20det blacktop. Its been sitting in the garage for 10 months or so. Plan before starting it. 1. Change oil. 2. Check tubes. 3. Check the rest of the fluids. 4. Turn off fuel pump and let it crank before powering fuel pump(More questions about starting below) Before. Stock sr20det, boosted at 14 psi Now Upgrades Peak boost manifold DW 650 injectors Power Fc z32 maf Tial 38 mm wastegate Dousans old turbo Questions. 1.Since my car has been sitting for 10 months. a.What else should I do before I start it? b. Any thing I should check, double check and check again before starting? 2.Will it start? a.Since I upgraded with all different parts, will it even start? b.Will the power fc need anything to run a rough idle? 3.Torque specs.(I have s13 sr20det) a.I have a FSM for a s14 sr20det, is it the same? b.It says 27-35 ft/lbs torqe for manifold. Is that too much or too little? 4.Oil line on sr20det s13 wise. I thought it was the line off the back of the block. Which one is it? 5.My peak boost manifold wont let me use all of my old washers off my stock cast manifold. Should I change all of them over to lock washers? (Lock washers will fit all the studs)(some of the welds hug the studs) 6.Blocking up coolant lines. a.Block plugs? b. will shorter bolts with thread sealer(like thread tape but goopy shit form work?)
It is better to keep your mouth shut and let them think you are a fool, than open your mouth and remove all doubt. |
#2 | |||||||||||
![]() Join Date: Dec 2006
Questions.
MAYBE, IF the PFC is not tuned/set up, for what is installed it will run crappy/ pig rich, if it runs at all. YOU NEED A TUNE if you had stock ECU/ Injectors it would run after a start up or two, and it will run crappy for a bit until all the crap that its collected burns off inside NOTICE: Do not freak out if you see smoke comming off the manifold, its just all the oil burring off the top of it from you touching it with your greasy little hands *Check for leaks when idleing* Quote:
But Ive always used the German Tourqe Spec "Good en Tight" :P Quote:
the oil feed is the smaller one of the two bolts (cant remember location right now) BE SURE YOU ARE RUNNING AN OIL RESTRICTOR, so you dont blow the seals on your turbo Quote:
http://enjukuracing.com/upgraded-exh...ml?cPath=24_45 Quote:
