05-22-2013, 06:01 PM | #31 |
I did not say it blew, you like assuming shit don't you. I put 25k on it in 2years, add the 25-40k it came with, well there you have it, 50-65k miles.
So inferior to your RB20 that they made it over the course of 15years, what happened to your beloved after what 5yr production times? The KA is an inferior motor from the factory performance wise. It doesn't rev, doesn't make power north of 6k and serves its purpose as a truck motor. Turbo it, and yea, it's a decent motor, but not better than the SR in factory trim, sorry it's not happening.
My SR20VET |
05-22-2013, 06:15 PM | #32 | |
the RB30's are truck engines too since they came in trucks in aus. the RB25/26 must be a truck motor too since it was used in a nissan stagea correct? truck motor or not means shit. VG30ET revs only to 6,250 in factory trim power drops after 5,500rpms. it's all about the cams and tune. hey hey hey hey you hey, does that mean the VK56's are shitty motors too because they came in trucks? hey what about the VQ40 are they shitty because they came in pathfinders? in factory trim your comparing apples to oranges. go get a SR20DE and a KA24DE and see what makes more power. im betting the KA does. lmao at VG30ET truck motor making 1,000hp in full race trim with a 9,500rpm redline. truck motors FTW if thats the case, I'd take any truck motor over any SR. |
05-22-2013, 06:27 PM | #33 |
So a 170hp NA motor is going to rape a lighter faster and higher revving motor 2.0l turbo motor, yeah, that'll be the day. I have a VG30E motor, it's great, but not fast. Once again you turn to the more cylinders, motor literate arguement. You just compared a V6 to the I4, congratulations, you suck again...
Have you forgotten the SR20DET IS a factory motor? It was engineered that way. I call bullshit on your DE argument as well. The NA SR still produces more power in stock trim than the KA.
My SR20VET |
05-22-2013, 06:34 PM | #34 | |
i can link you to a 1,500hp chevy 2.3l the SR20 is not godsend Fj was the best engine nissan made to date. the day a SR20 can make 270hp in stock factory N/A trim will be the day I suck your cock and buy a SR. |
05-22-2013, 06:41 PM | #35 | |
05-22-2013, 06:50 PM | #36 | |
05-22-2013, 06:54 PM | #37 |
I think you misunderstood me. I have by no means claimed the SR is the be all, end all engines. I will however defend the motor as being a venerable option, which upgrades nicely and puts out 400whp all day long with bolt ons.
The FJ24, that you refer to was a race motor... Nissan built 200units so they could participate in rally. It was not a mass produced motor like the SR, so once again this isn't a apples to apples comparison. With that said, I can show you multiple NA SR race motors that make well over the 270 mark. Should I even bother tossing out the SR20VET motor? Lets take a VE head and swap it on to a DE block and viola 500whp at low boost and all stock internals.
My SR20VET |
05-22-2013, 06:55 PM | #38 |
He's fucking crazy man. He'll run of the top about vg30e's and ka's and say how much hp they can hold alongside some magical Fj then ramble how horrible a sr20 is without a turbo on it is.
He just hates sr20's so much he'll say a prius motor is a better option for power. I've done a few sr20's and had one myself never more than replace minor things (water pump, tstat, clutch and few gaskets externally) and Not seen ONE pop and most we're put at 13psi+ for years till they where sold off. Yet sen 2 ka-t's pop over 1 summer with half the milage this kid is talking about. So stfu and die and the BEST nissan motor is the TB48DE imo |
05-22-2013, 06:57 PM | #39 | |
05-22-2013, 06:59 PM | #40 |
Unless you want him too suck your cock you may wana leave this out
05-22-2013, 07:06 PM | #42 | |
My SR20VET |
05-22-2013, 07:08 PM | #43 | |
my point was the SR is not god send like you just said, everyone and their mother treat it like's it's gods answer to everything... it would not be hard to stroke a fj20 and brig it to specs. like you said, it made 270rwhp but this was are crappy carbs im sure if you converted it to EFI cop and so and so it would making just as much power if not more then a SR20VE |
05-22-2013, 07:12 PM | #44 | |
franks Z31 from WWR it was a junkyard VG30E from a nissan quest, stock bottom internals. massive work on cylinder heads though. motor lasted the entire season till it blew a rod through the block. did i mention it's a 700+rwhp vg30E NA2 turbo with stock internals? |
05-22-2013, 07:15 PM | #46 |
nah I just know when to spot a shitty engine.
05-22-2013, 07:19 PM | #47 | |
Even the field? If we talk VE heads, it's a whole different field where the archaic FJ has no foot holds or ground to walk on. If you know when to spot a shitty engine, you really were smoking some good stuff when you picked up your RB.
My SR20VET |
05-22-2013, 08:04 PM | #48 |
honestly s12drifter. why the hell do you hate the sr so damn much? we dont raise the motor like god here. YOU say we do. we all just know its an easy swap to do and its an easy engine to make power from.all the motors you list off probably are a bish to install in a car. and yes im relevant because thats what the OP will end up doing if he chooses to not keep his ka. SWAP A MOTOR IN! dollar for dollar and bang for your buck the sr20 is a good motor. it an take a good beating they have drag cars pumping 1000hp on them (although its not exactly street build nor is this recommended), and its a good start motor . you seriously need to chill out on the sr hate here and compare equivilent motors.. as in I4 vs I4 not v6/v8/race motor vs I4, its stupid and doesnt prove anything.
05-22-2013, 08:09 PM | #49 |
Why are you showing me youtube videos? Too what ? Ohh wait I get it, we should all go to the junk yard.. pull vg30e's with 230k on em cause they had frequent oil changes and slap a knock off turbo on it? That's all it takes for 700whp? AWESOME! So pissed its that easy
05-22-2013, 08:14 PM | #51 | |
bang for buck there are a lot better options out there that can get you more power. it would literally cost a great deal to build a fj20 i understand that their not easy to get parts for either. the SR20 is a trailer trash motor that drifters like to use to slide because they saw it in fast and furious tokyo drift. the SR is cheap in japan LITERALLY pennys on the dollar people ship them over here tax the fuck out of a garbage engine public buys into it and they make their money. for the price of a SR you can have a fully forged KA24DET forged pistons - 500 forged rods - 500 (not that you need them since their already factory forged) in just those two you're already a few steps ahead of a SR for the price you pay for an ENTIRE swap including install. |
05-22-2013, 08:15 PM | #52 | |
Trader Rating: (129)
Feedback Score: 129 reviews
My vg30e is absolutely gutless, even after doing the z31 cams its still slow. Even the most basic upgrades to the SR (down pipe, exhaust, elbow, intake filter) turned it into a fun, peppy, free revving motor. I'd happily throw an SR in my xterra when the time comes. Matter of fact, we already replaced the KA in my brothers frontier with an s13 blacktop SR and it was a massive improvement all around. |
05-22-2013, 08:19 PM | #53 | |
it's a fucking VG30E they make 140 or less hp to the wheels. VG's love boost N/A their pretty shitty. i know a guy with a 11.5:1 VG30DE he makes around 350hp with basic stuff but a N/A Vg is pretty hard to pull power out of. I only have about 1k in engine stuff. HX35, 450CC injectors, used nistune, etc etc on 9/10 pounds i push 300rwhp on a crappy shittastic base tune. (cant find someone to tune it.) your doing shit wrong. |
05-22-2013, 08:21 PM | #54 | |
No Fucking shit! The average kid doesnt have the mentality to tear an engine down and tune it you jackass a sr20 is one of the most simple swaps to do WHY everyone does it. Before I went through all that b.s with a ka-t setup id drive and lsx into a 240 and ram it up your ass |
05-22-2013, 08:37 PM | #56 | |
espcially swapping LSD's in your cars and shimming them properly getting ring gear and pinion tolerance right or transmission work either seeing as a transmission/diff is way more complicated then tearing a engine apart. |
05-22-2013, 08:44 PM | #57 | |
05-22-2013, 08:48 PM | #58 |
S15 SR20 has made nealy 1500hp and run a 6.70 1/4 at over 200mph.
Just saying. Calling it cheap trash is silly. 4g63 is probably the cheapest motor to make fast and IMO the best 4 cylinder out there. If the SR20 had bigger ports in the head it would be a very close second.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
05-22-2013, 08:59 PM | #59 |
Trader Rating: (36)
Feedback Score: 36 reviews
SR and KA are the same goddamn thing. One makes more torque and marginally more hp than the other. The both have the same shit cast pistons. SR is better out of the box. Stronger connecting rods, lighter, fully counter weighted crankshaft, and larger head bolts. There are pro's and cons to each. KA's make boat loads of torque, but they are very sensitive to tune in stock form. Built neither engine is really going to edge the other out in performance. 500whp in an S-chassis isn't practical on the street anyway. Pick what you like and stick with it. You can have a built bottom end ka for what you spend on a stock SR swap. (Not that it matters with the modest power goals most set forth on this forum.) I've owned, beaten and broken both past 350whp. There isn't any advantage to either. SR is much more expensive in every respect though.
05-22-2013, 09:01 PM | #60 | |
forged weisco pistons - $435 forged weisco 4340 rods - $424 holset HX35 - $290 (too big for you?) holset HE351 (hx40 comp housing and wheel with a hy35 turbine) $200-300 620CC injectors sard - 250$ ACL rod bearings - $25.00 ACl alumglide main bearings - $40.00 turbo manifold - $80 woah we're already setup for serious power and only 1,544 into it. hone = 10x4 = $40 balance = 250 walbro fual pump 420lph - $140 cometic head gasket - $90 brain cower stage 2 turbo cams - 400 nistune - 550 total in it about 3,010 vs a completely stock 200hp sr20? yea it's a no brainer. I even threw hone and a balanced assembly in for you. |
