Old 02-05-2009, 06:33 PM   #1
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
s13 what causes wheel hop?
i have an s13 I have good (not cheap quality) coilovers, nismo motor mounts, and tranny mounts, tomei 2way lsd and subframe spacers, 17" wheels with 225 tread width, but when i dump the clutch i get wheel hope. why is that, and what do i need to do to prevent it?
handinpants is offline   Reply With Quote
Old 02-05-2009, 06:37 PM   #2
PoorMans180SX
PoorMans180SX's Avatar
Wheel hope? What's that?
Wheel hop is caused by play in your suspension bushings.
If you get energy suspension bushings, it will help a lot.
If you get heim joints/pillow balls to replace your bushings, then it will go away.
The grippier your tires, the more wheel hop you will have and the more it will damage your drivetrain.
Old 02-06-2009, 01:01 AM   #3
handinpants
FreshColdBeer.com
Trader Rating: (48)
what kind of drive train damamge are we talking about?
Old 02-06-2009, 01:03 AM   #4
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
It's funny, when my rear subframe was all stock, I never had wheel hop.
Then I changed the bushings and put in collars, and now I have wheel hop as well whenever I dump the clutch. Oh wells I guess...
Old 02-06-2009, 01:26 AM   #5
articdragon192
articdragon192's Avatar
Work out bushings in the diff area will also cause wheel hop.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 02-06-2009, 03:11 AM   #6
kalypso123
(ノಠ益ಠ)ノ彡
what is wheel hop.
...talk to me like im 5 years old
Old 02-06-2009, 10:17 AM   #7
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
Imagine you're launching the car and the rear tires are hopping off the pavement ever so slightly and coming back down, over and over again.
You will know when it is happening as it's usually very loud and very rough. It feels like the rear end is bouncing. You'll only get this with tire spin.
Monooxide is offline   Reply With Quote
Old 02-06-2009, 10:21 AM   #8
Firestorm
Firestorm's Avatar
Firestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond repute
Send a message via ICQ to Firestorm
i have a solid mounted subframe and LSD, pillow ball stuff, energy suspension bushings in the uprights and bridgestone coilovers and i still get wheel hop. maybe it's because of the 255s in the back, i don't know.
Firestorm is offline   Reply With Quote
Old 02-06-2009, 11:57 AM   #9
kalypso123
(ノಠ益ಠ)ノ彡
oh... hm
weird
Old 02-07-2009, 12:08 AM   #10
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Didnt know bridgstone made coilovers. WIered
Anyways too soft of dampning in the rear can cause it easially. When the spring is allowed to move up and down too freely due to less feedback from the shock valving the wheels will go up as the car squats untill they break loose and return back down, thus causing more traction again and the repeating cycle. This is bad on every drive train componet from your axles, to your diff, to your drive shaft, to your transmission, all the way to your crank shaft and connecting rods. Any one of them componets are subject to breaking if you let the jaring continue.
4x4le is offline   Reply With Quote
Old 02-07-2009, 12:19 AM   #11
handinpants
FreshColdBeer.com
Trader Rating: (48)
so what causes that damn swaying motion? i know you know what i am talking about, click clunk, on gas and off, is it the subframe, i know its not the diff, i know the diff sounds different... (no pun)
Old 02-07-2009, 12:23 AM   #12
4x4le
4x4le's Avatar
not sure what you mean by swaying motion, but the click and clunk when you get on and off the gas is most likely slack you have in the joints in the drive shaft that were worsened by the forces (pounding) introduced to them by the wheel hop.
Old 02-07-2009, 08:44 AM   #13
kalypso123
(ノಠ益ಠ)ノ彡
I think when the car hooks the pavement the rear dips from the torque, and then lifts back up as the coilovers return to natual compression... then it slams back down to the normal height.
this could happen multiple times and hence it bounces.
Old 02-10-2009, 01:34 AM   #14
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
1. you got shitty coilovers, the dapeners aren't tuned for the springs ( i have had first had expirence with this, and the exact same symptoms you describe)
2. you need to either replace/add collers to your subframe bushings ( similar symptoms, also have first hand expirence)
redsx13 is offline   Reply With Quote
