Old 08-21-2008, 12:44 AM   #1
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
Brake Problem 300zx upgrade on an s13
Ok so I installed my 300zx ebrakes all the way around on my 91 s13. All calipers work and no leaks in any of the lines. The e-brake I think I need custom rebuilt because of a rusted piece. Anyway my problem is everytime I pump the pedal there is no pressure. Any idea what this could be? I tried a new master cylinder and that didn't work and I took mine out of my other car that worked and still no luck. Thanks in advance.
rocksteady_racer is offline   Reply With Quote
Old 08-21-2008, 12:52 AM   #2
Sileighty_85
Sileighty_85's Avatar
Make sure bleeder valves on calipers are installed facing "UP"
and Throughly bleed the system
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-21-2008, 01:23 AM   #3
rocksteady_racer
O
Maybe I put them on backwards that makes sense. But there's foam that gets into the master cylinder it seems. It gets foamy after couple of pumps? So I thought maybe there was a leak but it could be just the calipers are upside down because I think I put them on the bottom on the front end of the car. HMM I'll check taht tomorrow. Does that explain the foam though?
Old 08-21-2008, 02:18 AM   #4
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
yeah check if your calipers are on the right way, did you bleed it completly on all 4 brakes? and did you bench bleed the master cilinder?
bejota180sx is offline   Reply With Quote
Old 08-21-2008, 04:12 AM   #5
rocksteady_racer
hmmm
I bled all the brakes properly. I never bench bled before and never had any problems so I don't think that's it.
Old 08-21-2008, 08:22 AM   #6
projectRDM
projectRDM's Avatar
Foam = air. You have a leak.
FORMERLY R240NA
Old 08-21-2008, 09:56 AM   #7
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
If you're seeing foam you have a leak or didn't bleed everything properly, double check and re-bleed. It maybe coming from the master cyl not being bled.......never heard of not bleeding it and it working properly
s15specR is offline   Reply With Quote
Old 08-21-2008, 10:22 AM   #8
xkamikazestormx
xkamikazestormx's Avatar
xkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfection
when i did my brake upgrade, it took me forever to bleed the system. try it multiple times.
xkamikazestormx is offline   Reply With Quote
Old 08-21-2008, 10:35 AM   #9
SixSpeedSleuth
SixSpeedSleuth's Avatar
SixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to beholdSixSpeedSleuth is a splendid one to behold
I just installed 300zx brakes on my car and had the exact symptoms you describe. I then re-bled the system and the pedal got hard as a rock. There is no doubt, you have air in the system.
SixSpeedSleuth is offline   Reply With Quote
Old 08-21-2008, 10:58 AM   #10
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
i was a dumbass the last time i bleeded my brakes i would sit there forever pushing the brake pedal and wasnt getting any pressure. and my buddy that was helping me couldnt figure it out either. i was like last time i did this is bled supper fast.
so any how we switch places me opperating the bleeders and him pumping the pedal and instanly we start getting pressure. i was like WTH and look at his feet. and i had been puching the clutch pedal lol.....
simple mistake lol that if you not thinking could easily be a problem lol. and with the bleeder open i was gettting foam and stuff to just from pushing the clutch petal.
idahotuner is offline   Reply With Quote
Old 08-21-2008, 01:45 PM   #11
rocksteady_racer
I realized I put all the bleeders on the bottom by accident. So I'm going to try to swap them all and see if that works. Could it be that simple?
Old 08-21-2008, 01:47 PM   #12
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
Yes, amazing isn't it.
slidingsky is offline   Reply With Quote
Old 08-21-2008, 01:52 PM   #13
rocksteady_racer
LoL that is the first time I ever did that too LoL. Does that explain the foamy cylinder though?
Old 08-21-2008, 01:53 PM   #14
rocksteady_racer
e-brake question
O and one more 300z brake question. I put my e-brake drums on but my block where the e-brake connects is rusted and junky. Is there anyway to get a new one of them? Also is it direct bolt on or is there some sort of welding required? Do the lines run the same path as the stock lines or they need to be rerouted? This is on a 91 s13 240sx by the way.
Old 08-21-2008, 02:54 PM   #15
Ca_Silvia
Ca_Silvia is an unknown quantity at this point
With the bleeders facing down you won't be able to get all the air out thus leave air in the system which = foam in the master.
Switch the calipers and re bleed the system, gravity bleed is by far the easiest method of bleeding the brake try that.
Drift cars have no business being practical, fast, or functional.
Ca_Silvia is offline   Reply With Quote
Old 08-21-2008, 04:11 PM   #16
jrbump
jrbump's Avatar
jrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond repute
Bench bleed your master and buy some speed bleeders.
You will be done in no time.
jrbump is offline   Reply With Quote
Old 08-21-2008, 05:02 PM   #17
rocksteady_racer
Hmmm
Question on last post: Where can I get some speed bleeders from? I was thinking about getting a set anyway. It'll make my life a lot easier. Now only if they had speed bleeders for the clutch cylinder LoL.
Old 08-21-2008, 05:08 PM   #18
!Zar!
!Zar!'s Avatar
Ugh speed bleeders. I hate those things.
If you can bleed brakes propperly it would be much more effective/consistant.
Old 08-21-2008, 05:12 PM   #19
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
I can't believe people post and repost this same shit. It's been covered multiple times. What a waste of time...and to think that people know how to put shit together they rush through the process only to find out what is wrong and not know how to fix it. simple errors that shouldn't have been made.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 08-21-2008, 05:26 PM   #20
jrbump
jrbump's Avatar
I got some at the auto parts store.
Otherwise check the vendors.
Old 08-21-2008, 05:32 PM   #21
onehundredoctane
onehundredoctane's Avatar
^yup, i even followed up my post a while back with the problem I found, granted mine were Q45 brakes, but it's common mistake on any car.
Old 08-23-2008, 02:34 AM   #22
rocksteady_racer
s13 The point of the forums
That's the point of the forums - to help people out. I've done 20 brake jobs before and this is the first time I've done this. It was a stupid mistake but it was a lot faster for me to ask the community for help than for me to try and figure it out. Plus no one has covered the 300zx e-brake swap except on import nut and they are very vague about the install on an s13(they just say that the lines should fit but need to be rerouted.) So I would really like some help with that. We aren't all professionals.
Old 08-23-2008, 02:38 AM   #23
xkamikazestormx
for s13s use the z32 2+2 cable and it bolts right in. my friend did it.
on the s14, use r33 ebrale cables and it bolts right in. ive done it on my car.
Old 08-24-2008, 12:50 PM   #24
rocksteady_racer
Sweet that's what I have the 2+2 Cables.
