s13 popping noises when turning
So when I got my car it had cut springs and rode like hell. it popped really loud when turn left or right. I put actual lowering springs on it and it doesn't pop near as bad still coming from left side when I turn left and right side when I turn right. so my question is if the rack and pinion is bad or what.
Posted from Zilvia.net App for Android |
#3 | |
![]() Join Date: Jun 2007
A ball joint will cause more of a "clunk"
Check your inner/outer tie rods... MUCH more prevalent on 4x4's, but depending on how bad it is, it could be the issue... Cut springs could definitely have done a number on them... not to mention wreak havoc on the front struts.
