wideband reading
ok I've searched around but haven't found the answer I'm looking for so once again I turn to zilvia....
ok so basically I was just curiouse about my wideband readings its an autometer wideband. The car runs great with no issues but I just wanna make sure there isn't gonna be a issue down the road.. while driving it stays around 15.0-14.9 but after driving a little its drops to like 10.5 the kinda bounces back and forth from around 15-10 but most of the time its is at around 15 wich from what I gather is good. I'm just wondering if it jumping around like that is normal ? is there a way to fix it? or is it no big deal since it doesn't stay rich? its an s15 Sr it has an aftermarket fpr and the bov is vented to atmosphere wich I was told can cause this.. it also has a Jim wolf ecu for my setup. any insite would be awesome... Posted from Zilvia.net App for Android |
Your getting rich readings due to the BOV venting to atmosphere. Your AFRs while driving around are good as they are pretty close to stoich (14.7:1). It could also mean your o2 sensor is starting to fail, but more than likely that's not the case and almost certainly it's from being vented to atmosphere.
that's what I figured. I was looking under the car and the wire from the o2 was hanging so I'm gonna get that strapped back up and see if that does anything cause it might be coming loose or something
What's actually happening is that the MAF & o2 are working in conjunction with each other telling the ECU the amount of air being metered and what the fuel to air ratio looks like. What's happening in your case with the rich AFRs is that the MAF is telling the ECU that there is so much air being metered so it then tells the ECU to administer x amount of fuel for the specific amount of air (it wants to be as close to stoich 14.7:1 as possible). Now, since the ECU has already gotten the signal from the MAF and administered the proper amount of fuel, you are then actually releasing all the air that was metered and supposed to be going into the engine out into the atmosphere; pretty much the raw fuel that was administered is not being burned up, the o2 senses this super rich mixture and now tries to compensate and get back to 14.7:1
![]() Join Date: Jul 2005
way over complicated.
The maf sends a voltage to the ecu regarding how much MASS of air is entering the engine. Before injecting fuel based on that voltage, the ecu checks with the O2 sensor and makes small limited adjustments based on what it remembers. b. Your problem MIGHT be due to that atmospheric bypass. It could also be due to any number of other things such as a boost leak. |
I was thinking maybe boost leak but my boost gauge reads fine and it idles perfect so I ruled that out cause I figured it would idle rough if it had a boost leak.
#8 | |
![]() Join Date: Aug 2011
This usually solves all boost leak issues, when they are not coming from defective IC core, 1 way valves or badly set beathers. They do, esp. when there is a bov involved. Bov leaks at idle because there is a strong vacuum that pulls the piston. You can go from 15 to 11 / 12 AFR with a leaky bov at idle. Lower readings are usually the result of a bigger leak though. |
#9 | |
ok so I'm gonna bump this because I'm getting a little worried... I've been reading other threads about what the wideband is supposed to read at different times ( cruse, wot ,ect. ) well mine stays at 14.7-15.1 all the time besides when I'm just driving around normal then it goes rich and bounces around like I said before but when I'm in wot it stays at normal wich isn't right... it should at least move I would think.
It is a s15 Sr with...... tubular mani tomie rocker arm stoppers turbo xs bov z32 maf aftermarket fpr forget what brand fmic Jim wolf tuned ecu on 10psi fuel pressure is at 40 car idles fine no smoke pulls hard boost good doesn't do anything weird just the weird wideband readings... Posted from Zilvia.net App for Android |
![]() Join Date: Sep 2005
Definitely not JWT's fault, although they will help, just like we will. You should do a free air calibration on that wide band or get a second opinion on the AFR reading. There's also a testing procedure that has been known too indicate failing WB sensors
Read the plugs Or do things that you know would richen up the afr. just to test out the wide band. Power balance or create a boost leak, if the afr doesn't change then I'd assume faulty or uncalibrated wide band. Your tune can't be off if you boosted 10psi and was stoich, I'd think with pump gas you'd be running in the knock map with a 10afr for sure or have fried pistons and or plugs Comment for the boost leak talk previously: If your idle is high, it can mask a vacuum/boost leak on your boost gauge!
that's what I'm saying but if it is 15 at wot then when I'm cruising it shouldn't be 15 still plus I feel like ide be having other issues if it was that off
ok so I created a boost leak and it still read the same just bounced around from 14.7 down to 10 and everything in between so I dunno what's going on.. would my spark plugs show any signes? white lean black rich right? also my bov was making a squeaking sound so maybe bov?
I don't trust it lol but they aren't cheap so ide hate to spend 300 on a new one just to have to go get a 6-700 dollar tune
#17 |
300 would get you a complete new system, with a brand new gauge and sensor.
BTW are you sure you have a wideband sensor ? Not just an autometer gauge fitted the standard narrowband sensor ? |
#21 |
I just wanna add that over the weekend I checked some things out
first thing the bov was sticking open and making a whistling sound also where my air filter connects to the maf there is a little gap because the filter has the wrong adaptor so its not flush are these reasons I could be getting bad readings? Posted from Zilvia.net App for Android |
#22 |
The first one spells "MAJOR BOOST LEAK", which is a cause (if not THE cause) of your problems.
The second one spells "unfiltered air", and will sand down your MAF sensor, your turbo compressor wheel, and your cylinders /pistons in the long run. |
