![]() Join Date: Nov 2007
RB25 Knock Sensor question
I need some help/advice diagnosing the knock sensor system on my RB25.
I've got the FSM and to check the sensors it says to check the voltage between the plug on the ECU & ground. It should be approximately 4V for a good sensor. One sensor I replaced with a used one (broke the stock one), and the other is original. The replacement reads about 2.5V....while the other plug reads 0V. I know the wiring is good (no breaks...) The sensor that reads 0V...do you think it could be the sensor that's bad? Possibly the ECU? It seems like there should be SOME kind of voltage across that terminal. I've heard of people checking the resistance values of the sensors to see if they're within spec, but my FSM doesn't show anything like that. Only the voltage check. What do you guys think? Bad ECU or bad sensor(s) |
If the ECU is on/powered, and that sensor isn't showing any voltage, you most likely have a wiring problem. I'm trying to look through my notes to see if they both connect to the same power wire, but worst case, just hook the second sensor into the first's power lead. Shouldn't pwn the ECU.
If there's continuity between the +12V and ground leads of the sensor, though, might be a bad sensor.
![]() Join Date: Apr 2005
It's a single wire sensor, no power/ground.
Is the ecu faulting the sensors? You can try ohming out the sensors, it usually reads around 500k ohms. But its very common of the connector socket to be pushed back and that can cause the ecu to throw a code. |
How does one go about "ohming out the sensors" when i try reading the resistance from the single pin on the sensor across the body of the sensor i get discontinuity (inf. resistance) How does the ECU fault the sensors? I unplugged the subharness and checked the voltage across each pin and got about 4.85V for each. This would lead me to believe that the ECU is good since there is no discrepancy between the two. I took apart my subharness though, I think there might have been some of the shielding wire digging into the sensor wire. I'm about to plug it back in and check. I'll letcha know thanks for the help so far
If there's no continuity between the sensor and the ground, you should see voltage on that pin. I'm interested now lol... keep us updated.
code 34...
and i still haven't gotten around to plugging everything back in and trying again. Like i said, i think that maybe some of the shielding might have been making contact with the sensor wire which would definitely cause problems... but how do you check the resistance of the sensor? I've got 3 of them and i get discontinuity between the single plug in the middle & the body of the plug on all of them... |
Yeah I think he's using the continuity tester (not an actual resistance reading) on the multimeter. Change it to 1M ohms, and you should see '.5'.
I was using the resistance reading on my MM, but in the wrong range. I tried it on the 200k setting and wasn't getting anything. But once I put it on the 20M setting I got .56, .57, and .8 something for the 3 sensors. (.8 and .57 for the ones that are actually on the engine as the other one has a broken plug).
But I think it might have just been some bad wiring and the ground shielding was shorting it out. I just put everything back together and drove it to the end of my street and back and I'm getting code 55. I'm gonna go take it for a serious test run right now. I'll let you know how it goes ![]() |
#12 | |
