Push Button Question
Hi guys, I couldn't find a forum for things involving the electrical part of cars so I figured to come here. To start off I wanted to know if there is a place online that makes push buttons that are square, rubber coated and you could push more than once for a high/ low setting? I like the look of the buttons on a CAN keypad and I wanted to see if there are buttons like that in which I could just wire say lights to. I will try to insert a pic of the button things I am talking about. Thanks
![]() Join Date: May 2011
not exactly what your looking for but this thing is fucking sweet
http://www.altronicsinc.com/switch-p...erquest-1.html I don't know of anyone that makes switch panels with multi use buttons, usually I see them with a low on one switch and high on another switch |
#3 | |
no the one I posted is a totally stand alone self contained unit, you can run only fans, and amp turn on and other completely unrelated stuff if you want, you just wire everything to the control box then its a usb plug up to the touch screen
probably good quality though so it's probably worth it |
#9 | ||
https://www.google.com/url?sa=i&rct=...72602100694934 |
#10 | |
No it's great, and it comes with it's own wired compact relay/fuse block. It's as simple as add power and wire outputs, also all of the switches can be configured from constant to momentary. As for the ribbon cable it is long but it's a race engineered part that was designed with rollcage mounting in mind so it has enough cable to comfortably run to the top of the windshield if I wanted. The excess will be easily ziptied.
#14 | |
| wiring problem |
