Old 08-27-2009, 04:49 PM   #1
Kenji001
Kenji001 is making a name for him/her selfKenji001 is making a name for him/her selfKenji001 is making a name for him/her self
KA-T S15 GT28R Turbo Setup Complete List
I have my S13 Hatchback for about a year and I want to turbo my car now. I did suspension and brake upgrade already. My S13 is mainly for drifting. Since this is my first turbo car and first time to do this, please let me know if you have any suggestions/tips.
My goal for this S13: I want to have around 250-280WHP with responsive acceleration. I am interested in good response and low-end torque for drifting. I just want a typical good setup. Since I don't plan on rebuilding my KA24DE, I will run 8-10 psi boost. I did a compression test on my engine. The result is 180 psi for all 4 cylinders.
Reliability > Performance > Cost
Here is my setup:
Nissan JDM T28R Turbocharger
The Nismo Shop : West Covina Nissan
NISSAN SR20 Turbo Inlet
MyNismo.com - NISSAN SR20 Turbo Inlet
Nissan OEM SR20DET Turbo Gaskets G. 2-bolt turbo inlet tube gasket
The Nismo Shop : West Covina Nissan : Nissan OEM SR20DET Turbo Gaskets
NISSAN SR20 Turbo Outlet
https://www.mynismo.com/products/?ID=5973
TURBO OUTLET TUBE GASKET 3 BOLT SR20DET S13 S14 S15 OEM
http://cgi.ebay.com/ebaymotors/TURBO...Q5fAccessories
Nissan 240SX Silvia S14 S15 SR20DET Air Intake Systems
Nissan 240SX Silvia S14 S15 SR20DET Air Intake Systems:eBay Motors (item 390034206425 end time Sep-25-09 18:44:49 PDT)
NISSAN MAXIMA MAF AIR FLOW SENSOR N60 SR20DET KA24DE NR
http://cgi.ebay.com/ebaymotors/NISSA...4506.m20.l1116
Nissan 240sx KA24det Turbo Manifold - T25/T28 S13 S14
eBay Store: Search results for TURBO KIT.
Megan Racing 3" SS Stainless Steel Downpipe SR20DET w/ Flex Section
Megan Racing KYO SR20DET Exhaust Turbo Outlet Elbow
Megan Racing 3 in. Test Pipe Nissan 240SX
FMIC INTERCOOLER PIPING KIT BOV 240SX S13 SR20DET 89-94
FMIC INTERCOOLER PIPING KIT BOV 240SX S13 SR20DET 89-94:eBay Motors (item 120438896633 end time Jun-29-09 23:02:27 PDT)
SHURiKEN SK-BT35 BATTERY
SHURiKEN SK-BT35 (skbt35) Batteries and Battery Isolators Batteries & Battery Isolators Car Accessories and Installation Car Audio, Video, & GPS Navigation - Sonic Electronix
HKS SSQV BOV SQV
HKS SSQV BOV SQV BLOW OFF VALVE S13 Evo SRT-4 WRX STI:eBay Motors (item 260423733963 end time Sep-03-09 20:53:46 PDT)
HKS SSQV Recirculation Fitting
MyNismo.com - HKS SSQV Recirculation Fitting
JDM S15 SILVIA 480CC INJECTORS SR20DET S13 S14 180SX
JDM S15 SILVIA 480CC INJECTORS SR20DET S13 S14 180SX:eBay Motors (item 220430109914 end time Jul-25-09 20:31:03 PDT)
INJECTOR SEALS SET S13 240SX SR20DET GENUINE NISSAN OEM
INJECTOR SEALS SET S13 240SX SR20DET GENUINE NISSAN OEM:eBay Motors (item 170226347816 end time Jul-22-09 13:14:15 PDT)
NGK Iridium IX Spark Plugs Nissan 240SX KA24DE Turbocharged Colder
AEM GAUGE TYPE 6-IN-1 WIDEBAND UEGO CONTROLLER 30-4100
AEM GAUGE TYPE 6-IN-1 WIDEBAND UEGO CONTROLLER 30-4100:eBay Motors (item 150355644156 end time Jul-09-09 09:40:52 PDT)
AEM Tru-Boost Electronic GAUGE Type CONTROLLER 30-4350
AEM Tru-Boost Electronic GAUGE Type CONTROLLER 30-4350:eBay Motors (item 150355645472 end time Jul-09-09 09:46:07 PDT)
ATI EZ POD DASH GAUGE HOLDER NISSAN 240SX S13 89-94 52M
ATI EZ POD DASH GAUGE HOLDER NISSAN 240SX S13 89-94 52M:eBay Motors (item 350099703694 end time Sep-12-09 21:31:58 PDT)
JGS Vacuum Blocks
http://jgsturbo.com/kamain.html#anchor415357
EXEDY RACING STAGE 2 CLUTCH KIT 91-98 240SX KA24DE
EXEDY RACING STAGE 2 CLUTCH KIT 91-98 240SX KA24DE:eBay Motors (item 350203568059 end time Sep-15-09 11:17:35 PDT)
KA24DE Lightweight flywheel 12lbs
Nissan KA24DE Lightweight Flywheel Clutches And Flywheels
Nistune Type 3 Package
ISIS Dual N1 Exhaust - Nissan 240sx 89-98
http://enjukuracing.com/product_info.php?products_id=8588{3}41
NISSAN OEM KA24DE ENGINE OIL PAN 240SX 1991-98 S13 S14 (for welding the bung for turbo oil return)
NISSAN OEM KA24DE ENGINE OIL PAN 240SX 1991-98 S13 S14:eBay Motors (item 300259703825 end time Jul-01-09 15:42:54 PDT)
White 7 Color Water Temperature Gauge
White 7 Color Oil Pressure Gauge
White 7 Color 105 PSI Oil Pressure Gauge
White 7 Color Oil Temperature Gauge
Universal Triple Gauge Single Din Radio Face Pod
KOYO 53MM 2-ROW ALUMINUM RADIATOR: 240SX S13 KA 89-94 Item#: R1276
KOYO RACING RADIATOR+CAP R1276 89-94 240SX S13 KA24DE:eBay Motors (item 350099700730 end time Sep-12-09 21:17:33 PDT)
Oil Feed:
NISsport Oil Pressure Adapter for 240SX 1/8 BSPT (male & female) & 3 1/8 NPT
Steel -3 AN to 1/8 NPT 961603
AN PLUMBING.COM Earls performance products, Hose ends Hose,Adapters, fittings
36" -3AN Line 63010136
0.03 Oil Restriction Inlet Fitting Turbo Restrictor GT28/GT28RS/GT30R/GT35R. Output is -3 AN male OILRESTAK2
Taka Motorsports
Reference:
Oil/Coolant Feed/Return line For Ka24det: 240SX Technical Forum: Nissan Forums / Infiniti Forums - NICOclub
Installing an Oil Pressure Sender: 240sx Articles: Nissan Forums / Infiniti Forums - NICOclub
Oil Return:
Swivel-Seal 90 deg. Tube Hose End -10AN 809110
Swivel-Seal Straight Hose End -10AN 800110
981610 Straight, Pipe Thread To A.N. Adapter 1/2 to -10AN
967110 Steel Weld Fitting -10AN
400100 Premium Racing Hose. THE BEST! Use Swivel Seal or Auto-Fit Hose Ends -10AN 1-foot
GT Turbo Oil Return Flange w/ -10 AN Fitting
GT Turbo Oil Return Flange w/ -10 AN Fitting [019] - $28.00 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake
Reference:
Pics Oil Pressure and Return Bung: KA24ET / KA24DET Forum: Nissan Forums / Infiniti Forums - NICOclub
https://www.dwperformance.com/kommer...=163&start=100
Turbo coolant lines:
Banjo Fitting Kit for coolant lines - 14mm Machined Alum to 1/4" NPT
Banjo Fitting Kit for coolant lines - 14mm Machined Alum to 1/4" NPT: atpturbo.com
Fitting, 1/4" NPT Male to 5/16" Hose Barb
Zex: Fitting, 1/4" NPT Male to 5/16" Hose Barb
Goodyear Replacement Belts and Hoses 65127 5/16 in ID. Hose 25ft
Goodyear Replacement Belts and Hoses 65127 - Goodyear Hysunite Fuel Line/Emission Control Hose-Overview - SummitRacing.com
Reference:
Oil/Coolant Feed/Return line For Ka24det - SR20 Community Forum - The Dash
AN Fitting Thread Size Chart
Water temp Adapter:
NISsport Water Temperature Adapter for 240SX
Reference:
SG-WT INSTALLATION
Oil cooler:
GReddy Oil Cooler Adaptor W/Thermostat 12401123
"-10 AN Male to 1/2 in. NPT Male adapter fittings RUS-660500 (Quantity: 2) $3.95 each"
Russell Performance 660500 - Russell AN to NPT Adapter Fittings-Overview - SummitRacing.com
"-10 AN Hose to Female -10 AN straight hose ends RUS-610040 (Quantity: 2) $9.95 each"
Russell Performance 610040 - Russell Full Flow Hose Ends-Overview - SummitRacing.com
"-10 AN Hose to Female -10 AN 90 Degree hose ends RUS-610180 (Quantity: 2) $21.95 each"
Russell Performance 610180 - Russell Full Flow Hose Ends-Overview - SummitRacing.com
"Hose, ProFlex, Braided Stainless Steel, -10 AN, 10 ft. Length RUS-632170"
Russell Performance 632170 - Russell ProFlex Hose-Overview - SummitRacing.com
"1/2 in. NPT,5 3/4 in. x 11 in. x 1 1/2 in. fluid cooler B&M 70273"
B&M 70273 - B&M SuperCooler Oil Coolers-Overview - SummitRacing.com
Summit® Fluid Cooler Mounting Kits
Summit SUM-G4990 - Summit® Fluid Cooler Mounting Kits-Overview - SummitRacing.com
Reference:
How-to: Build Your Own Oil Cooler: 240sx Articles: Nissan Forums / Infiniti Forums - NICOclub
Build Your Own Oil Cooler - 240SX Forums
NISSAN EGR BLOCK OFF PLATE TURBO 240 SX KA24
NISSAN EGR BLOCK OFF PLATE TURBO 240 SX KA24:eBay Motors (item 280373587976 end time Jul-24-09 19:34:09 PDT)
Oil Catch Can Setup/PCV setup:
TBD
Reference:
Positive Crankcase Evacuation Explained: KA24ET / KA24DET Forum: Nissan Forums / Infiniti Forums - NICOclub
www.ka-t.org :: View topic - HOW TO: *Properly* disconnect your PCV ...
Originally, I want to get Garrett GT2860RS turbo. However, it seems like S15 OEM turbo will be cheaper and easier to setup (can use SR20DET bolt-ons).
There are my original threads:
#/f/engine-tech/2617...0rs-setup.html
KA24DET Garrett GT2860RS setup: KA24ET / KA24DET Forum: Nissan Forums / Infiniti Forums - NICOclub
www.ka-t.org :: View topic - KA24DET Garrett GT2860RS setup
KA24DE: KA24DET Garrett GT2860RS setup - 240SX Forums
1) Will my setup work? Am I missing anything? I am looking for a complete list.
2) What are other suggestions? Please no engine swaps. I just want to build my KA-T.
All the work will be done by me and my friend. The only thing I need from a welder is to drill/weld the bung for turbo oil return on the oil pan. I will road tune my car with Nistune myself, and I am still reading a lot of things for ECU tuning.
Please contribute. I think this will help alot of new people who wants to turbo their 240SX.
Thank you!
Kenji001 is offline   Reply With Quote
Old 08-28-2009, 08:14 PM   #2
supra33202
supra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choices
Do I really need JGS Vacuum Block? How do you guys run the vacuum lines? I know I need vacuum for BOV and boost gauge. I am confused now.
supra33202 is offline   Reply With Quote
Old 08-31-2009, 01:24 PM   #3
supra33202
Do you guys think getting a TurboXS Knocklite is agood idea? Some said it's unless because the knock light is too sensitive, and can't tell if they have true engine knock or not.
Old 08-31-2009, 01:42 PM   #4
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
Dude, No ones posted because you have a really long list of things. I didn't go through it, but it looks like your familiar with the parts, not familiar with the install, and pessimistic about the outcome once you're dedicated... There are billions of people describing their setups, so spend less time searching parts, and more time searching the Turbo FAQs and FSMs (both KA and SR). Doing this answers your first and second post. And, don't waste your money on your last post (my opinion).
Once you read more into others' setups, you need to decide for yourself. We aren't going to decide for you.
Not sure about the Megan products (another personal opinion), but skimming over the rest, your parts list looks [expensive and] good.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 08-31-2009, 03:15 PM   #5
S14_Kouki
S14_Kouki's Avatar
Yes once u read alot of other ppl's builds u will see different things u like and dont like. It just takes time and research, but of curse u need to know what u are reading and looking at.
S14_Kouki is offline   Reply With Quote
Old 08-31-2009, 08:23 PM   #6
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
ya thats a long ass list man. gl with the build
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 08-31-2009, 08:24 PM   #7
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
200 bucks for s15 injectors? not bad, although the 2nd injector looks like it has black stuff on it...maybe they're used? also, there's a zilvia vendor who's got a special on the t28's running...i think it's a little over 700 for the turbo and elbow(?) piping. i just bought a spare ka that i'm gonna boost so i'll be researching just like the OP
upsdude is offline   Reply With Quote
Old 08-31-2009, 10:38 PM   #8
supra33202
"you have a really long list of things."
Dude, this is the whole point of this thread. Instead of just focusing on some big parts like everyone else does, I want to show the whole package. You and I knew that turboing a car is not just slapping a turbo and call it done. This will help other new people who wants to turbo their cars. If you read my thread entirely, you would know that I spent alot of time on researching already. And you are right about that I have never turboing a car before, so I have no experience on installing at all. That's another reason to make this thread.
I just want to clarify things. Please don't flame me.
Old 08-31-2009, 11:49 PM   #9
upsdude
upsdude's Avatar
Trader Rating: (46)
i don't think ppl are flaming you *shrug* but yeah that's an extensive list of parts. with the amount of thought you've put into it...you're not going to do some kind of work on the engine? maybe some machine work? just curious...and gl i'll be referencing your post for my build up for ideas
Old 09-01-2009, 12:16 AM   #10
lflkajfj12123
long ass list
jesus christ just buy an sr20det with a t28 and get it tuned
Old 09-01-2009, 02:12 AM   #11
upsdude
upsdude's Avatar
Trader Rating: (46)
yeah that too huh? lol
Old 09-01-2009, 04:38 AM   #12
xpertsnowcarver
Trader Rating: (44)
I completely understand what you're doing because... well.. I did the same exact thing three years ago. Luck with your build.
My YouTube Channel
Old 09-07-2009, 01:48 PM   #13
Kenji001
Do you have a build thread?
Thanks!
Old 09-08-2009, 06:46 AM   #14
Spring Break '92
Spring Break '92's Avatar
Spring Break '92 can only hope to improve
As you go about your research you will discover little things that you need to change, like the PCV system. Since its an S13 you are going to want to upgrade the ignition coil. Other than that you have your bases covered but I am inclined to say that you are over-thinking it.
Spring Break '92 is offline   Reply With Quote
Old 09-08-2009, 08:03 AM   #15
ballinnmiami240sx
ballinnmiami240sx's Avatar
ballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura about
long ass list
hahaha same thing I was thinking. I did the Ka thing and it was awesome. 300hp but at a price tag of $5000. I eventually traded when the HG blew and got an s14 SR.
Now im tired of Sr's and Im looking for an I6 or V8
1994 FD3S Drift // 945garage // sumospeed.com
ballinnmiami240sx is offline   Reply With Quote
Old 09-08-2009, 12:06 PM   #16
Kenji001
For the oil feed/return, I think I'll do this:
NISsport Oil Pressure Adapter for 240SX 1/8 BSPT (male & female) & 3 1/8 NPT (One 1/8NPT for oil feed; One 1/8NPT for oil pressure sender unit; One 1/8NPT for oil temp sender unit)
KA24(D)E T25/T28 Oil Line Kit
http://www.jgstools.com/turbo/ka24et.html#anchor398149
0.063" Oil Pressure Orifice
Garrett GT25 GT28 GT30 GT35 Turbo Oil Drain Flange Kit
Garrett GT25 GT28 GT30 GT35 Turbo Oil Drain Flange Kit:eBay Motors (item 280387081859 end time Sep-18-09 02:06:29 PDT)
This setup will be cheaper and simpler (no need to cut stainless steel lines).
Old 09-08-2009, 12:57 PM   #17
projectRDM
projectRDM's Avatar
I didn't read any of that top list, but you don't need the above oil fitting adapter. You're not going to reuse the OE sender, and the oil filter bracket has two ports, one for oil feed, one for a true pressure gauge (if you choose to use one. $49 so you can hang the leaky, shitty OE sender back on is stupid.
FORMERLY R240NA
Old 09-08-2009, 02:50 PM   #18
Kenji001
1) Is it true that the stock oil pressure switch on S13 is only for oil pressure check? I just checked FSM (LC-3 & LC-4). It seems like the oil pressure switch is for plugging the hole only, and it doesn't connect to the ECU.
2) For the oil fitting adapter, are you talking about GReddy Oil Cooler Adaptor W/Thermostat 12401123? I know it has two extra -10AN fittings and I can buy 2 1/8npt GAUGE ADAPTOR for oil temp and oil pressure sending units.
Thanks!
