rough idling after 5 speed swap complete
i finally finished my s14 auto to 5speed swap but now i'm getting a rough idle when i start the car. it dies below 1k rpm in neutral
this is after a test drive i'm running an auto ecu. crankshaft sensor is broken. could it be on my intake somewhere, IACV? could it be because of any of the sensors on the tranny? |
![]() Join Date: Apr 2003
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
im not sure but i dont have any sensors connected from the tranny besides the speed and reverse, also i ran with an auto ecu with no problem. i have a s14 with s13 tranny. no problems i dont think it have anything to do with setup you might have hit something during the swap.
![]() Join Date: Feb 2005
it's the Auto ECU. Rev the car a bit once you start it up. That happens because you took out the Automatic Tranny control unit when you put the clutch pedal in.
edit: getting 5spd. ecu would solve that problem ![]() |
