![]() Join Date: Oct 2001
Q45 brake install
I don't have install pics but I just finished this project yesterday. I bought the Calipers from Ebay and rebuilt them myself after I had them powder coated "black chrome" I had a shop put the pistons into the cylinders and boots but I did the rest. The install was absolutely easy other than the cutting of the Brake shields. I just snipped them off completely down to the hub. ( I know I know, no dust shield, water gets on the rotors yadayadayada). I ran into a snag when the back right caliper bleeder stripped out. I have to replace the rear caliper or at least take it off and see if I can get out the bleeder valve. I love the upgrade because it is a subtle look but there is definately better brakeing power without messing up the brake bias. I would recomend this to anyone that wants a performance upgrade without the bling and the jackedd up brake bias of some of the other swaps. If anyone has questions I would gladly help them out.
Oh yeah, If anyone is interested in some black S14 SE front calipers, used rotors, and used pads, let me know
![]() Join Date: May 2002
yeah q brakes are great stuff
good job on the instal its easy as pie i installed my friends. took 1/2 hour in and out done and done speed bleeders save time |
Yeah, It took all day for me because of the fact that I stripped the bleeder valve. Other than that it was a piece of cake. Just so you rookie's out there know,....That was the first time I ever did my own brakes by myself too. It really is the easiest brake upgrade for our cars.
![]() Join Date: Oct 2006
u gotta spend that 5$ on the speed bleeders - and use line wrenches
![]() what pads you using? the pad selection isn't as wide as the z32/r32 or the stock brakes - i know endless makes a pad for them |
I did my q45's this week also, couldn't be happier. |
![]() Join Date: Jan 2005
Q45s are awesome. I have them on my 13 and couldn't be happer. Ran some Endless SS-S pads on them and they were great. The only pain was the dust shield.
![]() Join Date: Mar 2004
what year q brakes are yall running... from what I read there are some differences between the years... but my resource can be incorrect (or my memory).
Mine are 96.....I am running akebono pads for now. I don't need speed bleeders because I have a hydrolic bleeder but the F-ing valves stripped. I 've tried all the tools mentioned above as well. I will be buying a new caliper/ replacing the whole thing unless I am able to get the bleeder out once the caliper is removed?
yes they are exactly same style as z32
a bolt on job z32 is just as easy to put on as q45 both u would have to redrill to 4 lug if u need 4 lug for 5 lug, its a bolt on affair but q45 u can use the stock q45 lines where as z32 you need conversion lines unless you get z32 from a s14 jdm car because they can retain stock lines and are teh same as z32 the info is all over the net this isnt a new swap/conversion/upgrade. people been doing it for like 5 years now. |
#17 | |
Yeah, that was already stated a few times in this thread. q45 = use 240sx or q45 lines *same thing z32 = conversion lines |
#18 | |
#20 |
![]() Join Date: Jun 2004
Trader Rating: (73)
I upgraded to Q brakes recently, and I noticed that I experienced more pedal travel. It goes to the FLOOR.
The brakes lock up and work fine, but the pedal softness is kinda lame. I have a manual S13. I heard from a friend I can use an auto S13 BMC to correct, does anyone know if this is true?
#21 | |
![]() Join Date: Apr 2004
#24 | |
Trader Rating: (73)
#26 | |
Inactive Admin
![]() Join Date: Mar 2002
Take the BMC off and extend the little rod a few 1/4 turns. 6 or 8mm wrench does the job. |
#27 | |
Trader Rating: (73)
#30 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
i just swapped j30 front calipers onto my s13 they are slightly smaller than q45's but the rotor size is the same...it was a very easy and cheap swap...50 for 2 calipers from the junk yard...and for both q and j30 swap 95 altima rotors are the correct size so you dont need to redrill the 5 lugs
