![]() Join Date: Aug 2006
Hello,
I dont usually post up things like this, but everything that I am finding from searching has not helped, yet. I really appreciate it if you read through all my over explaining and have any ideas! I have a rb25det S2 into a 95 s14. no hvac/stereo etc, wiring specialities harnesses with stock chassis harness, stock rb25 s2 ecu, no solenoid(read online to plug that in, but I dont see any spot on my harness for it?) also have my AAC valve capped if that matters fmic, 3" turbo back, turbosmart raceport bov, walbro, aeromotive afpr set @42-44psi, mishi rad, other misc mods. fresh oil change, fresh plugs, coolant etc(swapped over winter) I drove it around without giving her over 1/2 throttle and seemed fine, would boost and hold it and sounded great and had enough power for daily driving that I didnt need to give her really any more power while making sure it was safe.. well after about 120 miles of just casual driving over a couple days to make sure it ran great etc, I decided to floor it.. to my suprise, this car seems slower then my n/a daily forester with bolt ons...maybe just as fast at best? but it sure does sound better!!! Anyway, it went smoothly through the revs with no feeling of being put in my seat even downhill, doesnt sputter or bog, doesnt sound lke a boost leak or sound like its having any issues at all at any time driving it..but its not fun in the least, I would get walked by the wifes 4cyl newer accord guaranteed.. this sucks So in case you didnt read earlier, Im not running the boost solenoid, explaining the 5psi cap, but I dont have a place on my harness to plug in the solenoid? I have a manual boost controller I can install if that will help. I also have a mines ECU that I purchased on here months ago that is tuned for the same mods as I have.. will installing that help? I havnt tried them myself because I am afraid it could be making a simple problem, into a bigger one.. if that is not the case, then I am all for it as I am tired of having such a slow "track built" car Thank you!
Im back on here just to buy wheels |
![]() Join Date: Nov 2010
Sounds like timing? but also, 5psi is bad, put that MBC on there and crank it to stock PSI.
(which for an rb25 is????? I have no idea sorry)
update: did a boost leak test and found one.. solved it and went for a test drive right now and it just bogged as soon as I gave it gas. It does not want to drive.. It then felt like it was missing or something then would want to take off but I didnt want to let it..
Any ideas?
Boost leak still, u forgot to hook something back up
Also check some of the other things Flip mentioned. These can all be impacting your motor and causing it to run slow
Ill drive it tomorrow and I assume the Maf being plugged in will help. I'm going to reset the Ecu and install the mbc and ill post what the result is
Stock rb25 is slow even if running correctly. You really need a tune to get the full potential. At 9psi its ok but nothing special and anything above 9psi hits a wall because the stock ecu pulls timing or does something else to prevent it from blowing up. Lol
I have a mines Ecu going in whenever this snow/rain stops... Also the mbc and my plugs are gapped properly according to whatever spec I was told for the mines Ecu to prevent it from blowing out the spark or whatever.
Ill post results when it's nice enough to drive again, thanks again!
Reset the stock Ecu, didn't add the mbc, and went for a drive.. Slightly wet out but there is 0 traction to be had and she pulls much harder!!
Ill have an actual update when it's dry again..
Yeah the torque doesnt help at all in the rain. If its raining out i can literally spin my tires all the through 4th (never tried in 5th) but in the dry it only spins first lol. And even then its only when the weather is colder and the engine can breathe easier lol. The stock ecu is just garbage from what i hear, just changing over to different ecu and doing a minor tune on the stock engine it will come alive.
Well I'll toss in the mines Ecu and mbc and see what happens then
once work is done I gotta see how it does on the dry (275 toyo t1r's, welded diff)
bs, i understand stock rb25 ecu's r crap but i wouldnt consider it slow by any means. i recently got my rb on stock ecu running flawless and decided to hit the strip for the first time, my very first time and managed to run 14.1, my rear end would keep bouncing during during launch and i was running on street tires, re11's. Give me a few more trips to the track, hell maybe even just a few runs and i'll be in the 13's. So with a good driver i'd say it can run mid 13's. The thing is the stock ecu is very picky and most guys dont pay attention to details. Running right, even on stock ecu, rb25's r fun as hell for the beginner.
#19 |
Lmao. It might be kinda quick at the strip etc, but not fast enough for me. Like i said, in stock form the rb25 is ok but once you throw in a management system - hold on to your pants!!! Mine has lightweight driveshaft, flywheel, 9psi, neo turbo, ls7 coils, exhaust, ic, q45 tb, freddy mani, few other things. Either way, with each upgrade i noticed a slight increase in power but nothing can match what a tune will do. Hopefully i can get it done soon....
#20 | |
#23 |
mhh weird, must be that freddy intake manifold taking mid rpm hp because i can spin them all the way up to 3rd on a dry day fully warmed up with 255 re11's on my stock ecu on 10 psi stock turbo. Now, i didnt follow on that "neo turbo", did u miss a coma? as in neo afc AND turbo? But anyway, i do plan on upgrading to a z32 ecu or a ve30 ecu when i upgrade my turbo, but for now i have enough and im sure op will be happy once he gets his shit running right.
#24 | |
#25 |
My 4.11 final gear ratio help a lot. Driving normal (not dropping the clutch) i loose traction if i floor it at around 4-5k rpm on 2nd and sometimes 3rd depending on conditions. At wot my 1st gear's merely useless on the street, after taking off normal if i floor it i loose traction almost right away, maybe around 2k.
#27 |
Car still feels slower then it should.. 11psi mines ecu And other mods in op.. Pulls "hard" until it feels like it should pull harder and it just doesn't, just starts to build lots of power and then it feels like it wasn't allowed to throw me back into the seat..
I have 245's on now and I can drift em but it doesn't burn in first if I don't launch and only chirps second on less then half tread all seasons
#28 |
Yeah man that wall ur hitting sounds like it could still be retarded timing.
Some other issues that are hard to diagnose but have caused similar issues: Spark plugs blowing out, Intake pipe collapsing under suction, Knock sensor issues.
#29 |
I have a solid intake pipe but the rest all seem very possible/likely. I'm gonna check em all/gap the plugs and report back
#30 |
It pulls hard till like 3, then hesitates, then pulls meh at like 5500
Im back on here just to buy wheels Last edited by bovaddict; 06-29-2013 at 09:30 PM.. |
