Old 11-28-2011, 05:56 PM   #1
eddieflo
eddieflo's Avatar
eddieflo is an unknown quantity at this point
Send a message via Yahoo to eddieflo
Zenki to Kouki conversion issue
zenki to kouki problem (s14) - YouTube
In the video you'll see that the Zenki Bumper support doesn't extend far enough to the Kouki bumper. I can't bolt anything on as a result of this issue. People have told me that the Zenki Support WILL fit the Kouki bumper, however I can't find any evidence to support this claim. Any help?
Wastelandfresh.tumblr.com & soundcloud.com/eddieflo
eddieflo is offline   Reply With Quote
Old 11-28-2011, 06:17 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I've heard that it can be modified to make it work but never done ti
I've always used the kouki retainer
(at ~$60 it isn't terribly expensive from the dealer)
do you have the crash support there still?
if so, try removing it since it may be preventing the bumper from moving forward
you mentioned the radiator support in the vid
yours looks fine, no need to replace it
the headlight brackets wont match the kouki ones though
those you can EITHER replace with the kouki ones or modify the zenki ones to work
you can use the sidemarker plugs for the corners (cut and splice)
and if you have an SE, the fog plugs can be switched/modified
for the headlamps though, you'll need to source a set of male/female plugs
Old 11-28-2011, 07:59 PM   #3
tqstarburst
tqstarburst's Avatar
tqstarburst is an unknown quantity at this point
Is that Tsi's front end?
tqstarburst is offline   Reply With Quote
Old 11-29-2011, 11:32 AM   #4
eddieflo
eddieflo's Avatar
yessir. i scooped it up in the summer.
Old 11-29-2011, 11:41 AM   #5
eddieflo
eddieflo's Avatar
What I'm going to do to remedy the situation is extend the bumper support using s custom spacer that I'm going to make out of a piece of metal. Then I'm gonna mod the headlight brackets, and wire in my HIDs for the kouki headlights.
Old 11-29-2011, 12:28 PM   #6
3ternal
3ternal's Avatar
3ternal is an unknown quantity at this point
Without the kouki retainer your bumper might sag in the center leaving a big gap between your bumper and your headlights. And for the headlights i just used the zenki brackets and drilled an extra hole for the little nub on the tabs. Maybe this will help.
3ternal is offline   Reply With Quote
Old 11-29-2011, 03:15 PM   #7
eddieflo
eddieflo's Avatar
I just modded the brackets in this way, looks pretty legit.
So the kouki retainer extends to fill the gap?
So far, I have an HID H1 kit and i dont need to rewire anything. It went in flawlessly, shoutout to HIDGUY.
Until i can get that kouki retainer and/or bumper support, I'm gonna have to zip tie this bumper so i can drive to work.
Old 11-29-2011, 03:17 PM   #8
3ternal
3ternal's Avatar
Yeah the retainer should fill the gap, at least mine did to where i could bolt the bumper onto it.
Ran without the retainer for a while and it was fine just sagged, you should be fine until you get one.
Old 11-29-2011, 05:57 PM   #9
tqstarburst
Go to nissanparts.cc. They have good prices, and they're pretty legit. I've gotten all my jdm-oem stuff from them.
Old 11-29-2011, 06:26 PM   #10
eddieflo
eddieflo's Avatar
Thanks bromar ghadafi!
Old 11-29-2011, 06:57 PM   #11
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
i get all my jdm oem stuff there too.. ray hooks it up
and if you want to save some weight and money here is a write up on a kouki bumper support
#/f/s-chassis/412282...nder-10-a.html
hope it helps
gunmetalr32 is offline   Reply With Quote
Old 11-30-2011, 11:53 AM   #12
RussellM
RussellM's Avatar
Trader Rating: (57)
RussellM is an unknown quantity at this point
Feedback Score: 57 reviews
3rd Part down... NissanParts.cc - Your #1 Source for OEM Parts and Accessories
RussellM is offline   Reply With Quote
Old 12-01-2011, 04:52 AM   #13
eddieflo
eddieflo's Avatar
Originally Posted by RussellM View Post
Bookmarked!
Old 12-02-2011, 03:29 PM   #14
eddieflo
eddieflo's Avatar
Old 12-02-2011, 05:27 PM   #15
tqstarburst
She doesn't look to bad.
Old 01-01-2012, 08:21 PM   #16
Mile6453
Mile6453 is an unknown quantity at this point
is the zenkito kouki conversion pretty easy to DIY or what?
Mile6453 is offline   Reply With Quote
Old 01-02-2012, 06:53 PM   #17
nujabe
nujabe's Avatar
Yes if your doing the jdm kouki bumper the lighting take a little bit of work to get the blinkers working but everything is a bolt on. Get a kouki retainer it makes life so much more easier
Old 09-03-2012, 02:14 AM   #18
Zenkeyfreak
Zenkeyfreak is an unknown quantity at this point
Hey Eddieflo, did the Zenki corner light harness work for the kouki corners or did you have to modify anything?
Zenkeyfreak is offline   Reply With Quote
