Old 12-19-2010, 04:48 PM   #1
hdz123
hdz123 is an unknown quantity at this point
help with gtir t28, need a retune?
i plan on upgrading my ka-t to a gtir t28, my current setup is a t25/370/n60, and i have an enthalpy ecu tuned for t25/t28/370/n60. Will the tune work for a gtir t28? just asking because it is different for the sr t28. And also will the 370cc injectors be maxed out at 10-12psi? Ive been searching and ive seen one person say they were gunna move to 550 on 12psi, but would like to know the safe boost limit for 370s. thanks
(last post for answers
hdz123 is offline   Reply With Quote
Old 12-19-2010, 05:11 PM   #2
nismoman
nismoman is an unknown quantity at this point
It should run fine with that turbo , however I'm not sure you wanna go 12psi. That has to be dangerously close to maxing 370's. If you had a wideband to keep an eye on the AFR's I'd say try it.
nismoman is offline   Reply With Quote
Old 12-19-2010, 05:13 PM   #3
hdz123
hmm maybe i should stay at 10? should make around 250whp i think. i heard 370s were good to about 280? and i dont have a wideband :\
Old 12-20-2010, 11:46 AM   #4
nismoman
The only way you'll get 280hp out of 370's is to up the fuel pressure and max them out. not really recommended of course. A wideband is the best $200 you'll ever spend on a turbo car.
Old 12-20-2010, 07:24 PM   #5
hdz123
ill look into a wideband
so i think ill stay at 10psi, should i just go ahead and upgrade to 550s and n62 and new tune or stay with 370s? its either get wideband and stay 370 or 550 with n62 no wideband
also whats a good street clutch for ~300tq? exedy stage 2? act street clutch? spec stage 2? thanks
Old 12-21-2010, 05:48 PM   #6
hdz123
bump help
Old 12-21-2010, 07:49 PM   #7
hdz123
okay got the act street clutch
http://www.frsport.com/ACT-NX1-HDG6-...X_p_15449.html
so should i just upgrade to 550/n62?
Old 12-23-2010, 02:07 AM   #8
hdz123
nvm returned that and got southbend stage 3
so for the gtir t28 where can i get the inlet pipe cut and rewelded?
Old 12-23-2010, 06:17 AM   #9
xxoreolovexx
xxoreolovexx is an unknown quantity at this point
you shouldnt need a re-tune. I would only keep it at 9-10 psi mac though. You def need a wideband bro. These KA's are fun but one little thing goes wrong and boom. When i built my KA-T the first thing i bought was an innovate lc-1. Personally i would get some stock STI injectors (yellow top = sidefeed, pink top = top feed.) Then i would get a n62 maf (because IIRC the n60 can only safely read up to about 270hp) Then you get a new set of chips from enthalpy (great choice by the way) install it all and turn it to 12psi.
xxoreolovexx is offline   Reply With Quote
Old 12-23-2010, 09:08 AM   #10
redpotatoes
redpotatoes's Avatar
redpotatoes is on a distinguished road
To be sure, get it retune, the N60 is ok. no need to change it. at 10 psi with a gti-r t28, you should be around 200-220whp. I use to run a GT2560R at 10 psi and these were my numbers. I am still running a N60 and I am now at +300whp but close to be maxed out.
redpotatoes is offline   Reply With Quote
Old 12-23-2010, 10:17 AM   #11
Nick_04K
Nick_04K's Avatar
Nick_04K is an unknown quantity at this point
What these guys said...Get a wideband, drive the car, pay attention and then you'll know if you need a retune.
How was your original t25/370/stock maf tune from Enthalpy? Spot on or any problems/performance issues?
Nick_04K is offline   Reply With Quote
Old 12-23-2010, 11:52 AM   #12
hdz123
it was on n60 maf, and for some reason the n60 didnt work only a j60 worked for some reason, but it worked real nice til the oil pump took a shit. and 200-220whp on 10psi? thats really low i thought it make around 250whp
so the best thing would be get the 550/n62 then get a wideband to be safe?
Old 12-23-2010, 01:23 PM   #13
nismoman
That and a retune, and you are goood to good. With that setup you should be nowhere close to running lean, so it wouldnt be a critical to monitor with a wideband...id still get one though.
Or get the wideband first.. turn the boost up a bit at a time and make sure the afrs stay below 12 at wot, 11.5 to 11.7 is better
Old 12-23-2010, 01:56 PM   #14
hdz123
yeah id get a retune of course, i just sent back my ecu and was deciding on 550/n62 or keeping 370/n60 but im gunna go with 550/n62 just to be safe. then when i get enough money ill get the wideband
Old 12-23-2010, 05:02 PM   #15
nismoman
When go get ready to buy a wideband i highly reccomend one of these two brands. Based on price and accuracy. I currently run an innovate LC1/XD16 setup
MTS Modular Tuning System
14Point7
Old 12-23-2010, 10:55 PM   #16
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
You won't need a returne, but those stock turbo injectors will be 'done' at 7-10 psi at most. Log a run to see duty cycle.
Old 12-24-2010, 06:16 PM   #17
hdz123
alright for sure thanks for all the help
also, do i need an upgraded radiator for t28 at 10psi? or will stock do fine?
Old 12-24-2010, 07:50 PM   #18
nismoman
You'll be fine, I run a stock rad with a GT2860RS no problems. Unless you are tracking the car.
Old 12-24-2010, 11:03 PM   #19
hdz123
Also one more thing I was wondering if it'd be okay to use stock sé smic pipe cod side to use on a one sided intercooler setup?
Old 12-25-2010, 08:09 AM   #20
codyace
codyace's Avatar
Trader Rating: (58)
if you want to stay SMIC, stay stock turbo.
Old 12-25-2010, 10:10 AM   #21
hdz123
u want fmic, but stock looking engine bay, so i was thinking of using rb intercooler with the stock sr piping and making it fit. is the stock sr piping too small for this setup?
Old 12-25-2010, 04:24 PM   #22
codyace
codyace's Avatar
Trader Rating: (58)
It's not to small, but the intercoolers themselves are the weak point
Old 12-25-2010, 05:20 PM   #23
hdz123
why? I mean im not using a sidemount, im using a one-sided front mount (sorry for the confusion)
Old 12-25-2010, 05:21 PM   #24
hdz123
i didnt mean one-sided as in side mount, it has the inlet and outlet on the same side of the front mount intercooler
Old 12-25-2010, 06:15 PM   #25
nismoman
Should be fine unless you plan on putting a huge turbo on there
Old 12-26-2010, 11:54 PM   #26
hdz123
okay cool, also would running piping behind the front mount make response a lot worse then straight from the throttle body down the battery tray to the intercooler? if its not that big of a deal ill just do this
and should i run 2.5 cold side, 2.25 hot side? ill mod the stock sr sidemount piping if needed to be 2.5 all the way
Old 12-27-2010, 07:51 AM   #27
nismoman
Well it does make a difference how long the piping is, but you are talking about a fraction of a second. It's all about the total volume of the piping and intercooler, more volume takes longer to fill up. Those piping sizes are fine either should work. Intercoolers are always a trade off.
Old 12-27-2010, 09:59 AM   #28
hdz123
so if i run a reverse flow intercooler i should run smaller piping then? i just want to retain the smic piping on a front mount, so that makes sense that the more piping the smaller it should be
