![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
no spark and possible no fuel please help
First of all Happy Thanksgiving. But seriously I have a problem. I just got done putting in my s13 blacktop sr20det and tried to start it up but nothing. I can hear my fuel pump coming on and i got oil pressure. Its just when I pulled the spark plugs out they were clean. It had a faint smell of fuel though. It turned over once when i sprayed carb cleaner in there but only that one time. The only idea I have is it is my ignitor. Does anyone know how to test it? And i did do my own wiring but i dont see anywhere where i would have messed with spark. Please help
I used heavy throttle mostly for the wiring and i got the fuel filter line going to the front of the engine and the other line going to the back. and about the grounding the spark plug inside the coil. Is there any easy way to do this? Thanks a lot guys. And i just tried the thing that duffman1278 did with grounding the thin red/black wire and it still diddnt work.
![]() Join Date: Sep 2005
which line goes to the fuel pressure regulator. the reason i ask is because i have an after market intake manifold (greddy knockoff) and the lines are in different spots.
back of what? the engine? FPR is in the back.
looking at the intake manifold, which line is hooked to the left hardline and which is hook to the right hardline? iirc the feedlline (one with fuel filter on it) should be the right hardline and the return on left. DONT QUOTE ME. |
The hard lines are taken out. on the front side fuel rail you can see the fpr and that one is hooked up to the fuel filter. and the retern line is hooked up to the one on back of fuel line.
#9 | |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
No no, you put the spark plug in the coil pack, so take it out of the block and than shove it in the coil, move the coil over and have the threads of the spark plug touch the metal from the block or the letters on the valve cover, after that, have someone crank the engine, you should be able to see spark, it'll be really obvious, you can't miss the light. just DON'T touch the spark plug as its being cranked, and remove the fuel pump fuse so it wont start up. I suggest grabbing the coilpack from the top, so you don't hurt yourself
About the fuel lines in this pic he has the fuel pump hooked in the back and the other fuel line going to the front of the engine. Do you know if that is right? I got mine going the other way. How bad is it if it is hooked up backwards?
im new at this and i dont know how to put pics up. this is the website http://forums.nicoclub.com/zerothread/228716. it is in the middle of the page. there talkin about something totally different but it has a pic of his fuel lines.
![]() Join Date: Apr 2004
Look at the pix. The supply line goes from the filter into the fuel raile like you see there. The fuel pressure regulator is the cylindrical looking thing on the fuel rail towards the front of the car. The return line goes from the FPR to the return line on the chassis. If you mix up these 2 lines it will not run. http://www.srswap.com/faq/index.asp Scroll down to Fuel System for more info. |
ok i just switched the fuel lines and still nothing, but i still cant smell fuel on the spark plugs. Also i tested to see if the spark plugs were sparking and nothing. so now i have no clue what to do. i need to find out how to check the ignitor. any ideas
now i dont know if this is good news or not but i just checked all the spark plugs for spark and it turns out #3 had spark. i dont know what this means or if i can rule out anything? does anyone have any ideas? and i still cant smell any fuel on the spark plugs
#22 |
![]() Join Date: Jul 2007
ok so you said cylinder # 3 has spark. so you know the coilpack, wiring, and pug is good for cyl # 3. now it is a process of elimination. try this:
1. take the coilpack from cyl # 3 and plug it into cyl # 1 and test for spark. repeat the same steps for cyl # 2 and 4. this will determine if your ignitor is working SOMEWHAT properly. so if you do this, and you see that you have spark on cyl's # 1, 2, and 4 using the coilpack that is in good working order, your ignitor is fine, and perhaps your coilpacks, and/or coilpack wiring have gone bad. SO, if this test shows you have spark on ALL packs, perhaps your timing is off and you can follow the CAS timing procedure found on frsport.com and heavythrottle.com (aka srswap.com). also, make sure the wiring for your CAS is okay. the CAS tells the coils when to fire, so again, make sure your CAS wiring is ok and the CAS itself is alright. EDIT: oh shit, i missed the post where you said it wasn't even really cranking. yeah, make sure your battery is good, make sure your battery terminals have a good connection, make sure your grounds are ok (clean where grounds contact chassis/engine), and make sure your lower engine harness is not shorting out anywhere.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
#23 |
ok so i think i miss lead you guys. it is cranking. what i meant was it is not firing up. but did what unicoladron said to do about moving the coilpacks around and i got spark also in #1, but not in #2 and #4. it was a weak spark but my battery is dying after all these tries. im going to go get it charged but what does that mean now?
#25 |
c mon guys i need some help. does any one know if all the black wires by the battery need to be grounded. i diddnt because none of the websites said to. And when i turn my key to the on position my ecu doesnt flash when i turn that little screw. what does all this mean? please help!!!
#26 |
alright dude:
1. you can use photobucket.com or imageshack.com to host photos on-line. you load them from your digi cam to your PC, then from your PC to one of those photo hosting websites, i prefer photobucket.com, very simple to use. there is no way to directly copy files from your PC to zilvia.net. 2. you really want to perform this test with a nicely charged battery so try the test i told you to again and report back. 3. yes the negative terminal of your battery needs to be grounded to your chassis and your engine. like i stated previously, you def want to clean those contacts so a nice healthy current flows through your wiring and you have a clean ground. 4. MAKE SURE your connectors that connect to the injectors from the wiring harness are seated all the way and are secure (this happened to me once), make sure the coilpack wiring is not frayed or broken anywhere, follow them back behind your cyl head between the firewall, they lead to another connector, make sure that is secure. but it now appears that MAYBE your ignightor is not firing on two cylinders which is a decent hypothesis at this point but i'm not to sure since you said your battery was dying, OR it's a wiring problem. did ANYONE fuck with your harness? who rewired it for the swap?
#27 |
also did you do what i said to check the CAS wiring, make sure the CAS wiring harness connector is properly seated and making contact, and while your at it verify ALL wiring harness connections are secure and not corroded or anything.
#28 |
again, you can basically ground anywhere that is metal on the chassis, make sure you clean all crap/paint away so you get a nice metal on metal contact. below is a picture of the OEM grounding location. the OEM 240sx s13 ground goes from the negative battery terminal > battery tray > intake mani (i used MSPAINT to indicate the intake manifold grounding location with a red box, i hope you're not color blind lol)
#29 |
ok i was chraging one battery and i used the other almost dead one to check where i was getting power to in my ecu and guess what i found out. i was looking the E5 pinout and for some reason the wire colors werent matching up and there were some missing where it wasnt suppose to. so i go looking around online to see if anyone eles had a ecu pinout that would work with my harness. And come to kind out that my harness matches up with a J4/J5 ECU which is a 97-98 S13 blacktop. i diddnt know they made s13s in 97-98. so do you think that i should get a different ecu or harness? Is there any was to see what year engine i have by looking at it? hopefully the company that sold me it will just give me the right ecu. This sucks. thanks for everyones help. it will be a while before i get the ecu in and hopefully it starts right up but if not, ill be back here.
#30 | |
If you want I can walk you through a repin of the ecu harness.
