Well yeah true, just a heads up.
btw, your car is bad ass. I want a coupe soo bad! ![]() My car idles like shit also! When i start it it goes straight up to about 1500rpms then falls drastically down to about 200rpms! The whole car shakes and what not. |
#6 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
or while the car is running, unhook it, and if you don't notice the motor run different, then the maf is bad
Slip Gypsies Blog Quote:
![]() Join Date: Jul 2007
Trader Rating: (106)
MAF's are extremely difficult to test. You can hook up a multimeter and read the voltages at certain RPM's. Some cars have voltage specs. But the only real way to see what the sensor is doing is to hook up a lab-scope to it. For those not in the know, a lab scope is a machine that you hook up to an electrical circuit. It has a graphing function and displays the voltage in a graph in real time, so you get an accurate picture of what the sensor is doing. Some MAF sensors send voltage signals, but most send a waveform signal. This means that the way you tell how the sensor is performing is by the heighth of the waves and the distance between the top of the waves.
#12 | |
#13 | |
![]() Join Date: Dec 2007
ooookay so what waveform are u suppose to look into?? and when u unplug the injectors 1 by 1 to check if theyre going bad do you just unplug the connections?? thanks |
