KA24de Knock
Hey guys, I recently got an s13 and was hoping to start building her up and maybe make a thread on here of it but I came into a bit of a problem. I've got a pretty brutal rod knock, I took the car to a shop in town and one of the mechanics said I'd need a new rod and crank. I don't have a lot of money and I know not to always trust an auto shop so I was wondering if anyone could give some insight on what might have caused this or if anyone's had the same problem.
Thanks! |
Post a video of it.
What causes rod knock? Bad rod bearing. Usually a result of something going wrong with the lubrication system. Low oil, bad oil pump, clearances too tight or too loose. Or it might have just been seriously ragged on. It's one of those things that common sense will usually prevent. If it is rod knock you'd likely be better off just dropping a junkyard engine in it. |
The mechanic's right.
Before getting an engine, you might get a quote from the mechanic on doing the rod and crank from below, with the engine in the car. I assume since you're dealing with him, you're not the one who would be fixing it or swapping motors - I'd guess the price of a motor AND his labor to swap it would be considerably more than just his labor and the parts to do the rod. |
#4 | |
Extra info, it's a ka with nearly 300k miles that's been bored .5 over on cyl 1, 3, and 4. Cyl 2 is .6 over and I've had problems with it before, also the mechanic that looked at it when I had the head cleaned up said cyl 2 has has problems before. It also has cams, not sure of the size as well as a chip. I'm strongly considering throwing in a stock KA from an s14. My only reservations with that is the head it clean as a whistle I spent $1800 on it getting all cleaned up already I really don't want to scrap the engine as a whole.
![]() Join Date: Jul 2005
oh my god. Get another engine- complete with around 100-150k miles should cost you $300-$500 max. Get one thats never been opened.
I just saw a local KA24 from a 1998 go for $300 complete with automatic trans, all accessories and wiring and ecu. It had 98,000 miles. |
#8 | |
#9 | |
Well what problems have those cylinders had, specifically? If your motor has bad compression or something, get a new one, but if it's all good, that may not make sense, especially with your money into that one. |
I'm not completely sure but when I had to have my head cleaned up it was due to the amount of fuel that the chip was telling my injectors to send, ended up frying the piston rings and clogging my injectors. The mechanic told me that wasn't the first time that cyl 2 has had issues, he said he could tell it had been worked on multiple times before.
I'd be extremely hesitant to just replace a single rod and a crank. Extremely. Like you said, pison two has had issues before, and it sounds like the current setup has been less than reliable before. In order to replace the rod and crank you'll have to replace the bearings on the other ones. If chunks of bearing didn't get embedded into the other bearing surfaces, they'll at least need to be matched to the crank properly, being that OEMs make bearings of very slightly different sizes to make up for slight variences in the manufacturing process, and to allow for machining.
Also, small bits of bearing might have gotten carried up to the head. You'd be gambling a bit if you don't get the head cleaned, as that could score cams or make it's way back to the sump, and as a worst case scenario, it could make it's way back to the bearings again, which could result in yet another wrecked rod bearing and eventually rod knock. Last edited by curo72; 01-12-2014 at 04:06 PM.. Reason: Wall o' text |
#12 | |
So... I realized this morning that I've been getting a few things mixed up here. I think it's usually the crank bearings that have to be sized matched. I'm not sure about the rod bearings. I imagine they would have to, but I'm really not too sure. And most bearing material *should* either stay at the bottom of the sump, or get caught by the oil filter. Only time it would make it to the rest of the engine is if some of the oil would get by-passed the filter, which isn't terribly uncommon, but... I just don't know.
Regardless, it is becoming apparent to me that I don't know enough to really help you out, and worse, may be spreading false information. I'll humbly bow out of this conversation and wish you the best. |
#14 | |
#17 |
I have a spare KA24DE in my backyard with 145,000 original miles. Runs great doesnt burn a drop of oil. has a 5-speed still on it. PM for more details and price if anyone is interested. I am capable of shipping it as well, it will go on a pallet, wrapped up and strapped down.
I would never have a KA rebuilt. Not worth it. An SR20DET engine by itself, S14 with around 60,000 miles can be had for around $1500. There is one local to me right now for that price in fact I was looking at. |
| ka24, rod knock |
