![]() Join Date: Feb 2011
starter issue
About a week ago the starter solenoid on my s13 (ka24de) litterally exploaded! Starter itself was alright so i just had it rebuilt. After installing it today it started right up.. the first time and that was it. Could there have been something Im overlooking? Ive got voltage but it sounds like the starter it completely dead again when I turn the key over, nothing, like the battery is unplugged. Any advice greatly appreciated
Just diagnosed my starter today!
1st check the battery terminals and battery voltage (especially if disconnected and sat for a while) Then Starter relay (blue one) and clutch switch could have gone bad some how. Finally the ground for your starter should be cleaned of rust /corrosion Those are the common problems i know of. |
#4 | |
lol im an electrician i def have a meter haha although not cheap.
do you have a harbor and freights nearby? also on the s14 it ended up being the actual cylinder for ignition that caused all my troubles. if you feel confident enough jump the ignition to the starter and have a friend check for voltage to the starter. good luck it was a pain in the ass for me too
12.78V is fine. Hell, my battery is sitting at 12.56V right now, and she fires right up.
A lot of times the starter signal wire from ignition is loose on the prong. If it wiggles around cut off the connector and hard wire in your own using a fuse connector.
#9 | |
There is only two wires you hook up to the starter. The thick 12V+ constant wire from the battery and the starter ignition wire which is black w/yellow stripe. Look for the black w/yellow stripe wire and see if it is on the starter tightly.
#12 | |
1 idk why you know you current voltage on your car considering your sitting at your computer 2 i have starter problems below 13 volts |
#14 | ||
2) You have other issues. You don't know what you're talking about, I mean... you did just buy your first 240sx, didn't you? LOL.
where is the neutral safety switch? right behind clutch pedal? Also I left this out in my little story but the guy at the generator shop put the solenoid in upside down :/ I know right.. anyone thats changed a starter on a ka knows how tight it is and there no possible way to have the 12v constant on the inside of stater without it toching ground. so obviously i turned it back around. In doing this the solenoid switched wire ( black and yellow that is soldered) is now facing down instead of up. I dont know if this will cause issue or not but to be safe i did tape it up to prevent it from grounding to the starter body.
#17 | |
Awfully concerned about it arnt you?
No, I dont have other issues. It would be normal for a starter to not want to turn with a low battery. Quote:
So did switching the solenoid around get it working again? and yea the switch is right behind the clutch pedal, a lil rubber pad pushes it down. |
Yes after turning it around it started once but that was it its not starting now. Pickin up a extra today n gonna see how that works out
#19 | |
Hopefully a new starter fixes the issue.
#20 |
Update: CAR RUNNING
apparently I did just have crap connections needless to say that guy will never touch or get near my car again! Thanks for the help fellas!
