does it matter where I put my lower injector seals? the ones that go into the intake mani.
I have sard 800cc injectors, there's a rubber seal up around section A. My oem side feed injector seals fit this part of my sard injectors. The top mount fuel rail i purchased came with those metal adapter discs that many top mount SR20det fuel rails come with. These discs cause the injector to seal around the narrower part B of the sard injectors. My issue with using these is they dont seal very well, but my oem ones do. Lastly will the act that the injector is now sitting further out of the fair flow stream cause any serious issues?
