![]() Join Date: Apr 2013
Show off Your Oil Cooler Setup !
I'm planning on doing an oil relocation/ cooler setup. I plan on autocrossing and tracking my S13 every now and then, but I cant find any threads or many pictures of setups or tips or anything of that nature. So for the other fellow members who would like to know more and/ or just want show off your setup, post it up in here. And yes, I will post up my setup once its said and done. Thanks for chimming in !
My +700hp RS13 |
Believe me, I've searched different titles using different search engines and same shit, just random oil cooler setup parts but not really everything assembled together. I made this thread hoping that some Zilvia guys could help me and possibly others with the same stuff.
![]() Join Date: Jun 2010
Are you trying to figure out where people put theirs?
Mine was in front of my passenger side tire up by the radiator and I left the oil filter where it was because I had no reason to move it...
S14 KA NA two cylinders, 75whp limper |
Thats where I wanted to place mine, that or on the outside of the bumper in that same area like how alot of 240zs are setup. Where exactly did you mount your oil cooler ?
putting it on the outside of the bumper is stupid on an s13
when i had one i out it on the passenger side between the fender and the enginebay, under the battery tray. add some ducting and you really wont get much better flow, unless your bumper doesnt have an opening there in front of the radiator isnt a bad spot too. in front of the bumper, not only will it get clogged up with pebbles, but tap the front a bit and you arent making it home with oil in the motor
street dancer. |
#8 | |
you didnt know? you arent allowed to start new threads on zilvia. you will also 80% of the time get nothing constructive or helpful from these dickish ass people.
Full 2014 build progress www.handicapmafia.wordpress.com |
Thats where the cooler went. The filter itself stayed in its oem place and I just had the cooler mounted under where the battery goes, behind the bumper.
#12 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Here is my setup
s13 sr20det in s14 Tomei Oil Block Adapeter B&M Cooler Filter Relocation Bracket Earls Thermostat Earls Lines and Fittings -10
DLG - DIRTYLOVE |
#17 | |
Not that difficult when the hvac stuff is out, extremely difficult when its in.
DLG - DIRTYLOVE |
#19 | |
My SR20VET |
#21 | |
Just curious, I have my cooler sitting with the taps on top so that it doesn't drain back and my car doesn't have to try to fill all the empty space at every start up. Also nice ducting.
DLG - DIRTYLOVE |
#23 | |
#24 |
![]() Join Date: Dec 2004
Trader Rating: (58)
For a street car I'd suggest a thermostat. For a track only car, not so much as it's just one more point of failure (and most track cars get brought up to temp properly)
#25 |
Also if there was confusion my question of do you run a thermostat was directed at jr_ss and not a general question.
Just interested in if there is a benefit in whether or not a drain back cooler or one that does not. I would think a cooler that does not drain back would keep the time the lines are empty down to a minimum, allowing better start up flow.
DLG - DIRTYLOVE |
