![]() Join Date: Oct 2006
what happens to you when you die?
up awake again at 4 in the morning...sometimes i cant sleep because i find myself thinking about death...more than that the fact that i will die someday. It seriously freaks me out more than anything and i get pretty bad anxiety over it...anyway enough about me, im interested in what other peoples thoughts on death are..what do you guys think happens after alll this...do we go somewhere else, is it just blackness forever, do we wake up like we wer in the matrix lol...seriously write what you think and maybe some explination of why you believe that...and try to keep this serious and dont turn it into a religious war
yeah i have seen it...very good movie, i hope for something like that
I think the biggest thing that freaks me out is that i kno its inevitable....so no matter what i do its something that will absolutely happen no matter what. It freaks me out even more to think that once you are dead you are dead forever...theres no coming back at all and you stay dead for all of time for millions and billions of years, and the idea of death doesnt make sense to me...if you think of it like sleep once you fall asleep your not aware you are sleeping..the only way you know you were asleep is when you wake up so if you never wake up then there is no experience at all so it seems impossible...if that makes sense...I wish i could explain it better |
![]() Join Date: Jan 2004
Stage 1: Initial Conditions
The initial conditions for decomposition are determined by the population of flora and fauna in the intestine of the body prior to death. The intestines contain a wide range of bacteria, protozoans, and nematodes. Once the body ceases to keep these fauna in check by normal operation, they will proliferate. Stage 2: Initial Decay Intestinal fauna begins to digest the intestine itself, and soon begin to digest the surrounding internal organs. The body's own digestive enzymes also begin to spread throughout the body, contributing to the breakdown of tissue. When individual cells die, they release enzymes which break down the cell material and connections to other cells, initiating a cascade effect. Within the first 24 hours, blue-green discoloration of the skin around the abdomen becomes apparent. Green-black discoloration develops in the blood as it reacts with hydrogen sulfide. Within 36-48 hours the body begins to bloat, most markedly in areas with loose skin (scrotum, eyelids, penis, etc.). Within 72 hours, the entire body has begun to decompose. The eyes are a good indicator of time of death in this initial stage. Jack Kevorkian found in his landmark 1961 Journal of Forensic Science article that "boxcaring" in the vessels can indicate time of death to within a half-hour. Corneal film forms over the eyes within minutes if the body dies with eyes open, or within several hours if death occurs with the eyes closed. Black spots appear in the sclera within the first few hours. Bulging from gas formation and eventual retraction due to decomposition make the eyes less useful as decomposition advances. Livor mortis occurs as blood settles to parts of the body due to the action of gravity, generally presenting as dark blue or dark purple patches. Lividity becomes visible at one half to four hours, well-developed within 3-4 hours, and acheives maximal coloration at 8-12 hours. Lividity can demonstrate the position of the body at the time of death, and any changes in position following death. Rigor mortis, i.e., the stiffening of the corpse, begins to develop immediately after death. Muscles continue to metabolize for a short time after somatic death, and glycogen continues to be converted into lactic acid. As the pH of the tissue falls, and in the absence of new ATP generation, the actin of the muscle begins to gel and harden. Rigor is perceptible at 1-6 hours after death, at its maximum at 6-24 hours after death, and begins to disappear as the muscles are broken down by decomposition within 12-36 hours, depending on environmental and other factors. The cooling of the body, or "algor mortis," proceeds at 1.5 degrees per hour at room temperature. Environmental factors can influence the rate of cooling (i.e., heat, humidity, immersion in water, etc.). Flies are immediately attracted to the body after death, and lay eggs around the bodily orifices and any available wounds. Blowflies and houseflies are the most common early insect responders. Stage 3: Putrefaction Within 4-10 days after death, the body bloats from the build-up of gases. The pressure of the gas inflates the body and forces fluids from cells into the body cavity. Hydrogen sulfide, methane, cadaverine, and putrescine are by-products of the decomposition process. They are pushed throughout the body by the bloating action, and by the movement of the young maggots which are now populating the body. Their strong odor attracts additional insects, such as beetles, mites, and parasitoid wasps that lay eggs within the bodies of the maggots on which they prey. Stage 4: Black Putrefaction 10-20 days after death, the body begins to collapse. The flattened body which remains has "creamy" flesh under black patches where the body is exposed. There is a very strong smell of decay, and most of the body's fluids have now begun to drain from the body and seep into the surrounding soil. Body temperature now begins to increase as a result of insect activity and heat from the chemical action of the advanced decomposition. The body is very attractive to all kinds of insects at this stage. If the body is protected from insects, adipocere begins to form. Stage 5: Butyric Fermentation 20-50 days after death, the body has become very flattened and is beginning to dry out. The body exudes a "cheesy" smell caused by the prevalence of butyric acid, and this odor attracts new kinds of insects, particularly cheese fly, beetles, and wasps. The surrounding area develops mold as the body begins to ferment. Stage 6: Dry Decay 50-365 days after death, the body is dry and decay proceeds at a slower rate. Eventually all hair and skin is consumed by moths, bacteria, and mites, leaving only bones. |
well i believe that our bodies go through what naturally happens in nature and all that good stuff. but i believe we have souls, lately i've been contemplating if after life we just remain in a state of being be it happiness or sadness. but my main belief still is the whole catholic view that i will go to heaven and be chillin with jesus knockin back some brew kickin it with people i knew throughout my life. it helps me sleep better.
![]() Join Date: Feb 2003
To play devil's advocate, its very possible to just be nothingness when you die. There isn't any evidence that supports this theory, however this is also no evidence that debunks this theory also. However, to put peoples' minds at ease, when you are dead you arn't conscious, so you probably don't realise that you are dead when it happens to you. Rather you just fade into an eternal darkness. But since you don't have a consciousness anymore things like time and emotion have no more relevance.
![]() Join Date: Sep 2005
I believe there is nothing after death, just like going to sleep. Cease to exist.
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
![]() Join Date: Feb 2007
hmmm, being blessed with my semi- beliefs of recreation and heaven/hell stuff, i beleive that after we die, some of us stay behind and try to finish what we couldnt when we were alive, aka ghost, are recreated until the apocalypse, or just go to heaven or hell...other than that, i refuse to read the last few pages of the bible, or worry about death....i kinda want it to be a surprise..like a toy in a cereal box, lol
Juicy slayin aint easy, but dammit somebody has to do it!!! |
![]() Join Date: Jan 2007
this topic confuses me as well... and i am not the smartest person by any means, but i was hoping for something like you die, and the moment another child is conceived, you become that mind... but that mind does not possess our character traits that we do now....it's like being a whole nother person physically and intellectually, but you get to live again without knowing it.... personally, i am a strong agnostic, so maybe to others it would be the "recycling of souls" in a sort of way i guess
death is a confusing thing, as nobody has died and lived to tell about it...i guess i'm just a kind of go with the flow kind of person...what ever happens when i die, happens |
![]() Join Date: Oct 2005
+1 for Heaven.
I think about death too...but it doesn't scare me. I know I am going to a save place when I die so I have nothing to fear then just the part of 'how I am going to die'.
Current: 95 240SX SE - VLSD, S. Tech springs, S14 SR, Walbro pump, Nismo 3" catback, HDI FMIC, Koyo Rad. 95 3000GT base - Stock 94 3000GT VR4 - K&N Filter, Test pipe, Denso fuel pump, HKS EVC IV. 92 Ninja EX500 - Full Muzzy exhaust 82 Ford Courier Full Race Truck - 87 Ranger 2.0 engine with fully rebuilt bottom end, stage 2 post and polished head and race cam, Welded diff., K&N Huge Air Breather. |
#13 | |
![]() Join Date: Sep 2002
If this turns into another "religious argument," I PROMISE to pink EVERY participant in said pissing contest.
"Heaven/hell" vs "you're dumb for having beliefs" is becoming a pain to have to moderate every week, just like "KA vs SR"
So what the heck does a S13 have to do with it?
EastCoast: I am the same way. I develope anxiety from it. I use to think about it 4/7 days a week when trying to sleep. Now I just block it out. I know its inevitable, but I want to hope for something more. I dont like the thought of eternal darkness. Scares me. Slothonalash: Your statement is pretty much exactly how I like to think about it. Innovation: Very good movie. IIRC, Robin Williams and Annabelle Scorsici. Been a while since I have seen it. |
#17 |
This is a very good topic since many people as well as myself have thought the same question.
The answer your question bluntly, you go either to heaven or hell. There is no inbetween and you absolutly dont come back as an animal of some sort. In the bible, Jesus says I am the way, the truth and the life. No one comes to the Father except by me. This means that if you choose to follow the Lord and accept that you are a sinner and in need of a savior and just ask for His forgivness, He is faithful and just to forgive. Also in the same manner knowing and believing that He died for your sins and rose 3 days later, the bible says you will be saved. So to get back on topic, if you are "saved" and you know in your heart where will you will go when you die, that is a very good comfortable feeling. Im sure my other brothers here will agree and say pretty much the same thing. If you would like to chat away from this, PM me and I would love to talk with you. God Bless <///>< |
![]() Join Date: Feb 2002
I just think I will go into a deep sleep and dream of abstract thoughts and how they can intertwine with any of my offspring (that is if I have one).
I'm not afraid to die.....just afraid of HOW I will die..as long as its not by fire or drowning, then I'm good. I like it to be quick or just in my sleep.
Goals are dreams with a deadline. L.H.O.O.Q. |
#19 |
Although no one can prove the existance of Heaven or Hell (or variations of it, elysium, purgatory, Hades, etc..), I think human beings find it easier to believe that such places do exsist rather than not. If someone is dying, that person might be thinking about going to Heaven (or a variation of it depending on religon), the fact that such a place exsists or not isn't the point, rather the belief in something after death, makes the transition into death a lot more smoother and easier. I'm pretty sure its documented somewhere that many people before death turn to religon to make peace with themselves. These people might not be religous at all, but they give themselves to religon and the belief that there is such a place to give way to a smooth transition into death (which is a part of life too).
#20 |
![]() Join Date: Jun 2002
Hm.... I have a question. All these people that believe they are going to hevean; what do you think your gonna be doing there? I dont believe in Hell because the bible doesnt mention it. It mentions sheol/Hades. The final resting place or eternal destruction. Though we share different beliefs of why we die, what happens to us when we die is even more confusing for some.
"For the living are conscious that they will die; but as for the dead, they are conscious of nothing at all, neither do they anymore have wages, because the remembrance of them has been forgotten." - Ecclesiastes 9:5 After raising Lazarus from the dead Jeasus said this, speaking of Armegedon.. "Do not marvel at this, because the hour is coming in which all those in the memorial tombs will hear his voice and come out, those who did good things to a resurrection of life, those who practiced vile things to a resurrection of judgment." - John 5:28-30 Another scrripture making the same point of Gods final day of judgement... "And the sea gave up those dead in it, and death and Ha´des gave up those dead in them, and they were judged individually according to their deeds." - Revelation 20:13 After final judgement of every living and resurrected person has been done. Those unfaithful will be destoryed. And for those faithful the bible says.. "And God himself will be with them. 4 And he will wipe out every tear from their eyes, and death will be no more, neither will mourning nor outcry nor pain be anymore. The former things have passed away.” - Revelation 21:4 |
#21 | |
Both the OP and PHLIP asked that religious debate stay out of this... so I'm not gonna comment on the verses you posted, or post any myself.
#22 | |
#23 |
![]() Join Date: Apr 2006
Location: Riverside, califoolyah...Hittin the beach, lookin for ballsuckers!
Maybe because he put an Apexi liscence plate frame, a 6 inch muffler canister, some 17x7 +100 wheels, what looks like a GT-R badge, and 13,000 horsepower-gaining stickers, he has more of a chance to enter heaven.
#24 |
I personally believe that when you die, you die. I was raised Lutheran. Lutheran grade school, Lutheran high school, Lutheran pastor's daughter girlfriend, so on and so forth. but at some point, i acknowledged that the Bible is just the retelling of a retelling of a story that was passed down word-of-mouth for centuries, translated and written down then translated again. it's like the end result of the "telephone game" you play as a kid. not to mention that the Church picked through and chose what they wanted to keep in, what they wanted to discard, and altered it to fit their own needs.
if you believe in a higher being, fine, sure. but the Bible is NOT a book to base your beliefs on. it's got some good messages, sure. but it's far from factual in any way. a friend of mine once told me "christians can turn agnostic or atheist, but it doesn't work the other way around". think about that. |
#25 |
the only time i really think about death is when someone close and young passes away.. i known a few my age that have past recently.. and the thought is freaky.. When I feel down about things, I just feel that I am still thankful to be here and that Im living for all of them.
anyways, if our souls where recycled into new life, then the population would remain the same, but it increases. so I think that kinda cancels that idea.
Keep it Classy |
#26 |
the OP and some of you others that posted need to grow the hell up! Death is a part of life and it is stupid to dwell on it because what happens when we die is irrelevant! Its like asking what happened before the big bang; who cares, it doesn't matter and has not bearing on you right now! If you spend too much time dwelling on death then you aren't really living are you?
I used to think about this stuff too and it would freak me out but I was eight years old at the time and the concept of death had just entered my mind. Seriously, death isn't that big a deal. Just believe whatever you want about it b/c it is unavoidable so you might as well have fun with it.
#27 | |
Then I guess I'm an impossibility... I'm an athiest turned Christian. What your friend said is completely untrue, there are MANY cases of people coming to believe in a God (not talking just strictly Christianity here) who were athiest, agnostic and everything in between.You're really opening up too turning this thread into what it's NOT supposed to be... a religious debate. If you want to post things like that, post them in the Christians thread. There's a lot of nice, friendly debating on the subject going on in there. ![]()
#28 | |
![]() Join Date: Feb 2006
Trader Rating: (47)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 47 reviews
But then I realize that there's nothing I can do about it. When it comes it comes. I will try and enjoy my life and cherish the moments I have with the ones that I love and care about. That's what really matters in my opinion. Thanks OP now I'm emo for about a minute now. Oh well.... |
#29 | |
Well its nearly impossible to express why we die from my stand point without discussing religion. Everyone has their own view. However I really feel pitty for those who dont believe in God or think this 80-90 years of life we live full of pain and suffering is all there is to our existance. I hope these ones find happiness in their years of life because to them thats all they have. I guess we will all find out soon enough. |
#30 |
^^ Santacruisin I think its just the opposite, In my opinion if you believe that there is something after this and that after death you will be with your friends and family then it is easier to become complacent in your life. Whereas if you believe that there is nothingness for eternity you may be in more of a hurry to experience all that you can. Thats just the way I feel about it...I think it important that you always remember you are going to die because it reminds you not to waste your life
silivianinja- thats kind of what i was talking about, but my thing is how is it possible being unconsious in death is like if youve ever been in surgery...you go under and your unconcious and then you wake up...but your unconciosness is only validated by your conciosness if that makes sense...I guess I just dont see how I can cease to exist for the rest of eternity |
