![]() Join Date: Jun 2008
can a resistor replace a knock sensor
redtop sr20det swapped s13
my ecu is still throwing a 34 (knock sensor) and thought instead of trying to spends hours taking off my intake manifold and spending 100+ on a new knock sensor i would just use a resistor so i went to radio shack and the highest ohm there was 470 and cut the knock wires and ran the resistor it almost seemed like it helped but i could be retarded but the engine still isnt working good its still running very rich, poor idling and its missing and bucking after 3k when i get on it could it be the timing or somthing i've ran out of idea's whats the deal |
Check all the wiring for the harness.. exposed wires can cause many problems and the ECu wont know exactly what it is...
and yes check timing as well...
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
LAID OUT
![]() Join Date: Mar 2004
1) yes it can replace. I used a 1Megohm but I think a 470k will work also.
2) Usually a code 34 means one of two things: Either the sensor itself is bad or the wire going to the sensor is shorted out (very common!). If you have a DMM you could track down the short in the sensor wire and save yourself $100 or w/e it cost for a new sensor. Wouldn't you be pissed to replace the sensor only to still see code 34 from a shorted wire hehe 3) Make sure when you installed the resistor you put it on the right wire (duh) and that the other side of the resistor is connected to a GOOD GROUND (very important). If the other side isn't a good ground, it's the same as a short/bad sensor = code 34. Use your DMM to check it out! 4) You will be able to tell if it's working or not, because after you do all this and clear codes the code 34 will go away for good. You'll either have a code 55, or some other shit to battle, but not a 34... If it comes right back then you didn't wire it up right. Search my threads and/or for 'code 34' and you'll find more info on this code and the resistor thing. I don't think it's that great of an idea on a turbo car due to the risk involved with knock on poor gas, high temperatures, etc. But it's your ride! |
![]() Join Date: Jun 2007
I think he meant DSM. What you need to do is go get a DSM, and blow the 4g63. It'll make you feel better.
lol. Nah, I've heard alot about shorted wires to knock sensors lately. Just take your time, go through, and look for any obvious cuts, splits, etc. And blow up a DSM
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
Um wrong;
Code 34 can and will be set off for plenty more reasons than the KS itself. Wiring short; KS unit cracked or defective; Inproper octane Drive/valve train rattle or slight vibraitions. Hell even a stuck caliper could cause some ping to set off code 34. Coolant Temp sensor. In proper timing Anything that could affect A/F adn engine operation such as; EGR system or Evap/Carbon canister. Code 34 is a bitch and chances are unlikely its the KS itself, unlses you have overheated and cracked the sensor, but then you have much bigger issues. |
#8 | |
![]() Join Date: Dec 2002
Man w/ CTSV & a Car Seat
Why dont you try to fix it properly so you wont make shit worst in the long run. Besides, cant you get to the knock sensor from under the car. I know in my SR, I've gotten to it from underneat after I forgot to put it back on the block.
