Old 06-02-2010, 09:39 PM   #1
!Zar!
!Zar!'s Avatar
Help me bro. Trucks and tow stuff.
I am looking around for a beater truck/vehicle that I can use to haul my car around to events and such.
Right now I have no idea. Maybe something like a 1990~ toyota pickup like a t100.
I heard those little 22re's are workhorses and will get me to where I'm going (eventually) and still yield good gas mileage. Maybe the v6 version?
Ideally it would be around $3k.
Or throw down more for a v6 96+ 4runner?
I know nothing about trucks. I just need something to get my car around.
Also, feel free to post up your trucks and whatever tickles your inner bro.
Old 06-03-2010, 01:50 AM   #2
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
The little 22RE will NOT be able to pull your car around from what I know. I had a 1994 Toyota Pickup, which is basically like a little t100 type truck, and just the weight to pull a car is too much for it. Yes they are workhorses and are the most reliable motor I've ever seen, but not so sure about towing things with it. I would grab something with at least a 6 cylinder
DataXUnknown is offline   Reply With Quote
Old 06-03-2010, 04:24 AM   #3
lou's40sx
Trader Rating: (54)
lou's40sx is an unknown quantity at this point
Feedback Score: 54 reviews
22R's and RE's are great. My friend's friend is selling an 85" or 84" and it's a 4x4, repainted, the car has like 70,000k or so original miles on it. Clean, lifted a bit, I believe original owner. Wants $3,000 ish.
It's a fair price, but I am a sub-baller so it was pricey for me.
**Sub-baller = Under Low-baller.
lou's40sx is offline   Reply With Quote
Old 06-03-2010, 05:14 AM   #4
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
i dont have a truck but i use the folk's 05 odyssey with a hitch i installed to tow my 240 around.
got the hitch at thehitchstore.com. great product and customer service
おれのシルビア大好きだよ!!!
aoiken3 is offline   Reply With Quote
Old 06-03-2010, 05:14 AM   #5
TheWolf
TheWolf's Avatar
a 96 4 runner has a max tow capacity of 3500lbs.
That's not enough to tow a car. It may work for like local events but the brakes, suspension etc on the truck are not upto spec and your average open car trailer weighs about 1300-2000 lbs depending on what the deck is made out of. An aluminum one is nice but usually double the price. 2400lb 240.. + 1500lb of trailer is gonna put you in 4000lb range.
Best bang for your buck in your budget range was something we got. Old ford work vans. We bought a 2001 E350 Ford work van with like 178k on it. They've got long wheel base, the beefy 1 ton HD transmission, real brakes.. and the rear bumper tow hitch is rated to 7500lbs. Prewired for trailer for 3k. Hard to beat and makes a perfect car hauler vehicle.
Other than that, an old chevy pickup is your next bet. Most v6 vehicles won't get you 4000lbs. I mean they may do it.. a couple of times... but they won't do it forever.. and last thing you need is your tow vehicle breaking down on you.
Eye on the Prize
Old 06-03-2010, 05:58 AM   #6
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
You gotta V8 bro.
Old 06-03-2010, 06:00 AM   #7
Drifto95
Drifto95 is an unknown quantity at this point
I would probably get ford explorer, they are cheap.
Drifto95 is offline   Reply With Quote
Old 06-03-2010, 06:07 AM   #8
altalti
altalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura about
Can you say blown up transmission. Those things have crappy transmissions and rear ends wouldn't last 3 months towing a 240 100+ miles a week.
altalti is offline   Reply With Quote
Old 06-03-2010, 07:32 AM   #9
stevenwhite1989
stevenwhite1989's Avatar
stevenwhite1989 is an unknown quantity at this point
I wouldnt do the toyota unless it is a V6, but if i was you and all you are doing is hauling, find an old F150, or jeeps with the straight 6, may not be good on gas but its going to be reliable, and tow whatever you need. Plus you could prob find one for pretty cheap
Girlfriend: "Why isnt yours (240) as pretty as his (240)?"
stevenwhite1989 is offline   Reply With Quote
Old 06-03-2010, 08:20 AM   #10
sub9lulu
sub9lulu's Avatar
sub9lulu is making his/her stupidity well-knownsub9lulu is making his/her stupidity well-knownsub9lulu is making his/her stupidity well-knownsub9lulu is making his/her stupidity well-known
the rear diff is fine
ford 8.8 last forever
tranny on the other hand
sub9lulu is offline   Reply With Quote
Old 06-03-2010, 09:56 AM   #11
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
A few things to look at
1. Are you towing with a car dolley, open deck trailer, or enclosed
2. Make SURE you know the capacity of the above, and it's weight. If you have an open deck trailer, they obviously make good/bad/mid range types, and weights very between them all.
3. How far are you towing/how often?
Ultimately speaking, your best best would be to find (at least) an 1/2 ton (f150/1500 truck, or similar capacity vehicles, like Expeditions, or Suburbans. This way you have a decent vehicle to tow with, but also a vehicle that has brakes to support the towing, as well as the actual usability of it them. Sure the fuel milage will be a little worse than a v6 oriented truck, but when towing you'll have the good power to pull, instead of ruining that small engine.
Now there is also another option
If you don't tow much, check local borough auctions and similar type things. YOu can often find old 3/4 ton trucks/vans or even emergency vehicles (old ambulances are great tow rigs, tons of room!) for almost nothing.
Sorry for being long winded, but with a truck(and trailer) safety is key. A v6 small pickup is not ideal for towing anything this side of a lawn trailer
Old 06-03-2010, 10:34 AM   #12
D.Adams
D.Adams's Avatar
Do not get a 22r / RE to tow with.. My dad has a 89 yota with a 22re turbo and it was a pain in the ass to tow my car up Banning pass. If your looking for a tow truck you got to go V8 gas is going to suck but its a tow truck.
You can get a early 90's f150 HD with a 351 for less then $3k or a 90's chevy silverado with a 350 for $3k-$4k.
Find out your over all tongue weight and go from there. Most small trucks cant tow over 1600lbs
I dont know your location but some links to help
http://losangeles.craigslist.org/lac...772114241.html
http://losangeles.craigslist.org/wst...772102054.html
just for the lol's
http://losangeles.craigslist.org/lgb...766286568.html
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
Owner of NVS Fabrications
Old 06-03-2010, 12:31 PM   #13
!Zar!
!Zar!'s Avatar
Thanks for the input bro's.
Cody, a Ford Expedition was another possibility on my list, with the 5.4 triton v8 or whatever. Only thing that scared me was the amount of people who had replaced the transmissions by 70~100k miles.
So that would also put the Dodge Durango into play. They have like a 5.9 Magnum v8. That seems cool enough. I would like to get an astro rape van, but that seems too ghetto to daily around for me.
That's what appeals to me about the Expedition/Durango. They are just like a F150/Ram, but able to carry more like one passenger comfortably.
The hardest part of towing would be going through the Grapevine.
Sucks to hear the 4runner can't do a good job. Would be nice to not go completely broke on fuel. hahahah
Old 06-03-2010, 12:36 PM   #14
silviaguy240
silviaguy240's Avatar
if you dont want to go broke on fuel dont go durango haha. i'd try to find an old 3500 work van or something similar that you can put tools and stuff inside/sleep in and have it locked up.
Old 06-03-2010, 12:55 PM   #15
sub9lulu
sub9lulu's Avatar
LSx > * gas engine
u can probably find a 2wd v8 for under 4k
anything newer than 2000 will work
2001 GMC Sierra / Chevy Silverado Super Cab SLE Z71 +Bedcover
Old 06-03-2010, 01:09 PM   #16
silviaguy240
thats a good fucking deal
Old 06-03-2010, 02:01 PM   #17
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
I use a Ram 1500. Can tow just about anything except for a full size enclosed trailer.
g6civcx is offline   Reply With Quote
Old 06-06-2010, 01:59 AM   #18
0100
0100's Avatar
0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute
Not sure what they are going for now, but I have a 97 E350 with a powerstroke. Got it for $9k like 5 years ago so they must be a lot cheaper now. The thing pulls like a rapped ape! Holds a ton of stuff. Plus you can sleep in the back at the track!
TougeHero.com l SilviaV8forums.com
0100 is offline   Reply With Quote
Old 06-06-2010, 02:08 AM   #19
0100
0100's Avatar
Ford Bus
Dually, diesel, runs on vegetable oil, party tow rig. Buy it!!
Old 06-06-2010, 03:23 AM   #20
!Zar!
!Zar!'s Avatar
Yeah, those rape vans are pretty cool.
This one is tits.
I was going to buy a 00` f250xl Super duty with the extended cab, but the banks closed too early. So now I have to wait till Monday and hope dude doesn't sell it.
RAGE
Anyways, I would like to raise it up, but then once I do that I have to get one of those hitch drop things, and that murders my tow rating from like 6000 or whatever to like 900. hahahah
Old 06-06-2010, 12:51 PM   #21
Motoskin
Motoskin is an unknown quantity at this point
i believe to tow a car on an auto transport you'd at least need a 1 ton truck.. anything else is insufficient
Motoskin is offline   Reply With Quote
Old 06-06-2010, 12:59 PM   #22
TheWolf
TheWolf's Avatar
I believe you're wrong... weight is weight... look up half ton tow ratings..
Eye on the Prize
Old 06-06-2010, 01:04 PM   #23
coww-cho!!!!!
coww-cho!!!!!'s Avatar
coww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the rough
Send a message via AIM to coww-cho!!!!!
there was already a thread on this, i forgot what the verdict was but it was generally in your money range. also, my dad had a t-100 yea there ok trucks. the timing chain and i think head gaskets went out on them often, and people usually do swaps into them for more reliablilty, but they are hard to find since most use them as work trucks like doing landscapes and such. if i find the thread ill post it on here to help ya out
edit: found some threads.
#/f/off-topic-chat/2...eed-truck.html
#/f/off-topic-chat/2...g-vehicle.html
#/f/chat/136430-who-...ut-towing.html
#/f/chat/131148-what...-your-car.html
**CoUpe LOve** #3
coww-cho!!!!! is offline   Reply With Quote
Old 06-06-2010, 01:34 PM   #24
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
Feedback Score: 115 reviews
Ford FTW. Mel you may remember my Rape Van I had a few years ago, '86 Ford E350 with a 7.6L V8. Thing was a monster. Gas mileage was SHITTY, but It got me to hella events.
Upgraded to my Excursion last year. Superballer tow vehicle. Nice inside and spacious.
Also my trailer is for sale very very soon if you're lookin for a flatbed trailer modified for lowered cars.
Old 06-06-2010, 04:27 PM   #25
!Zar!
!Zar!'s Avatar
Yeah, I remember that thing; can't forget it being as how it helped save my ass.
Execution would be nice, but a bit too big for the city. So next step down would be an Expedition.
But my inner bro is pushing for a f250 or a silverado/sierra. Something extended cab. Just trying to wait out and see what pops up before I rush into something that needs more attention than the car is it hauling.
Old 06-06-2010, 07:59 PM   #26
DJPimpFlex
DJPimpFlex's Avatar
Lol yea and that was before the trailer mods so we had to get a running start to push your shit onto the trailer. If you ever need a tow, offer is always there.
Old 06-06-2010, 09:50 PM   #27
SinGarage
SinGarage's Avatar
SinGarage is an unknown quantity at this point
Old rapist vans are the best specially if it's diesel. I think ford has the 7.9 liter powerstroke. You can tow your toy and have all the spare rims/tires with tools in the back. You can lock those up and go race.
SinGarage is offline   Reply With Quote
Old 06-06-2010, 09:52 PM   #28
drftwerks
drftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfectiondrftwerks is close to perfection
Send a message via AIM to drftwerks Send a message via MSN to drftwerks
exactly what i told him.
giantroboteyes.wordpress.com/
drftwerks is offline   Reply With Quote
Old 06-07-2010, 12:42 AM   #29
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I use a '99 Ford Expedition with the 4.6L Triton V8. Really has no problems towing uphill on the 5 going to willow, just a little slow. Plenty of torque and it has pretty decent gas mileage. I could make it to willow and back while towing my 240 on a trailer in one tank. 200 mile round trip. I love it so far, only thing is the brakes. They could be better, then again I don't have a brake controller yet for the trailer. I know... it's bad. haha.
Old 06-07-2010, 01:15 PM   #30
!Zar!
!Zar!'s Avatar
That is the original SUV I was looking at, but after reading about how they had transmission issues it made me kind of iffy. How's your mpg?
