Blown Turbo?
So my turbo spools a normal noise untill around 4000 rpms and then it just makes this high pitch whining noise + spooling,
my boost gauge is not hooked up but i know i am still getting boost, i still get regualr gas milage 350 - 500 kms a tank dependinghow i drive. 93 nissan silvia sr20det. thanks guys. |
![]() Join Date: May 2007
i actually just made a thread about this (should've search eh?)..dnomyar, was the leak on the outlet of the compressor on the turbo? searching said it could be the exhaust manifold to turbo gasket being blown out?
maybe thats where mine is as well..i pulled it off many times but never replaced the gasket. would a permatex gasket maker work or should i get something better? i just ask because i have some laying around..
btw, wouldn't it cause a boost leak symptoms like bucking/sputtering, or is it because the leaks are too small or something? |
i believe the gaskets are like $15 or something like that? i used RTV silicone but can't say if it held up or not as i still have the whining. go to last post and watch video and confirm if it sounds like that.
turbo death whine...? - Supraforums.com |
Banned from the Marketplace
I doubt the compressor wheel would've touched the housings, but just to check, take the inlet elbow off and see if there's any contact between the wheel and the comp. housing.
eliminate problems one by one. |
all my exhaust bolts are tight on the manifold, O2 housing, and downpipe..replaced the compressor outlet gasket, and there is minimal shaft play. maybe some sort of small leak in the IC piping somewhere?
