![]() Join Date: Dec 2002
Clutch Fan CFM
Anyone know what the stock clutch fan puts out CFM wise?
KA clutch fan preferably, although I don't think there's much difference.
Electric fans are good for stop and go traffic or drag racing. If your running your car in road racing conditions the clutch fan is a much better source of cooling. Stock OEM clutch fans can produce nearly 4000 CFM of air. Big gains in the stock unit.
I hate you too...
![]() Join Date: Jul 2001
You can only measure CFM of a clutch fan at certain rpm points. It's determined by size, blade length, width, pitch, and rpm. Seeing as a cluch fan is variable rpm, they aren't spec'd out like e-fans, which run at constant cfm, so all variables are constant.
Hope it helped. Since you're an art major, I'll re-explain in english if you'd like. -Jeff
Whatup? |
