Old 02-25-2002, 11:46 PM   #1
azboy
azboy is an unknown quantity at this point
from what i've found so far the center-to-center length of the OE KA24(D) connecting rod is 165mm and the stroke is 96.0mm which gives a ratio of 1.718.
can anyone else confirm these numbers?  if this is correct i'd rather buy a turbo for the ka24 instead of doing the sr20det swap.
azboy is offline   Reply With Quote
Old 02-26-2002, 02:08 AM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Even if you are correct, what the #### does that have to do with anything?  Including why you'd want a turbo Ka rather than an Sr...
I just dont see the relevance of your math to anything or either engine...
Could you please elaborate is what I am trying to ask <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
-Jeff
Jeff240sx is offline   Reply With Quote
Old 02-26-2002, 03:09 AM   #3
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Isn't there supposed to be some kind of &quot;ideal rod ratio&quot; or something like that.
DuffMan is offline   Reply With Quote
Old 02-26-2002, 07:12 AM   #4
crazycuban
crazycuban is an unknown quantity at this point
Yeah, ideal is 1.7
EDIT - The ideal rod ratio only means that it would rev higher and better, however...the KA is not built for that, and would need a LOT of work to take advantage of that rod ratio. &nbsp;Basically, although it does have a 1.7 ratio, that's useless. &nbsp;If you get the KA, get it for the low end torque, because to make it a high end monster you would need an entirely new valvetrain.
(Edited by crazycuban at 7:14 am on Feb. 26, 2002)
crazycuban is offline   Reply With Quote
Old 02-26-2002, 07:29 AM   #5
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
I don't know my high end feels and pulls just fine <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'>
uuninja is offline   Reply With Quote
Old 02-26-2002, 09:31 AM   #6
97S14
97S14 is an unknown quantity at this point
The ideal rod/stroke ratio is just a fraction of what makes a good high revving engine. &nbsp;There is a lot more to it then that.
And isn't the ideal rod/stroke ratio 1.65?
97S14 is offline   Reply With Quote
Old 02-26-2002, 10:25 AM   #7
azboy
Here is some info I've found:
&quot;Several things are directly effected by rod/stroke ratio, piston speed, piston acceleration and decelleration, piston dwell time at TDC and BDC, piston side loads, cylinder loading, and bearing loads. Almost everything mentioned as &quot;effected&quot; plays a major role in the way the engine breathes(piston speed, acc., dec.), the combustion characteristics(again piston speed, etc. and dwell time), and friction / wear characteristics(piston side loads, cylinder loads, and bearing loads).
There are many opinions on this subject, but it's generally felt that the lower the ratio numerically, the worse the geometry. As far as I'm concerned 1.75 to 1 is the ideal rod length to stroke ratio, regardless of application, and any number going down numerically is not favorable. If you lengthen the rod relative to the crank and the ratio grows larger, the wear goes down as does the piston speed, but this will contribute to an engine having a very narrow useful torque range. If the number is between 1.8 and 1.7, it's workable.&quot;
The reason for this is because of $$$$$ I don't have much of it and turboing the ka24 is a #### of a lot cheaper then doing the sr20 swap. although my dream is to drop in the sr20, I just don't have the finance. I wanted to make sure I understood the matrix of the ka24 engine before adding a major modification like a turbo. That's why I posted about the rod/stroke ratio in the first place.
(Edited by azboy at 10:29 am on Feb. 26, 2002)
Old 02-26-2002, 02:33 PM   #8
9591
9591 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from azboy on 11:46 pm on Feb. 25, 2002
can anyone else confirm these numbers?</td></tr></table><span id='postcolor'>
Yes, those are the correct numbers.
9591 is offline   Reply With Quote
Old 02-26-2002, 03:20 PM   #9
azboy
THANKS 9591
That's all I wanted to know <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 02-26-2002, 04:38 PM   #10
'91 D21 beater
Guest
Posts: n/a
Underpsi, Psi240, and my future engine is using the 171mm length rod. 6.75&quot; vs 6.5&quot; stock length. Try that for the rod to length ratio...
Old 02-26-2002, 04:59 PM   #11
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
Is that gonna effect you compression ratio?? &nbsp;What pistons are you going with? &nbsp;that ratio is a 1.781
sykikchimp is offline   Reply With Quote
Old 02-26-2002, 09:30 PM   #12
azboy
whats the max and min length on ka24 engines anyway? &nbsp;6mm above stock sounds kinda long to me but hey if it works.....
