sr20det idle problems *****not your normal easy fix though!***
Ok. Here's the details.
My car was fine, so naturally I had to 'Modify' it more than it already was. old mod list: 550 densos z32 maf t517z turbo freddy intake I added: apexi HG and arp studs procams and BC head package(valves, springs, retainers, 5 angle valve grind) Now it won't idle with the maf plugged in. Things I've checked: boost leaks - none. holds psi. timing - 15 degrees TPS - 0.46v at idle Checked maf voltages - 1V key on engine off - 1.42v at idle with 5v ref wire disconnected so it'll idle I also double checked both grounds on the maf and they are good as well. 12V wire on maf is good too. It idles and starts perfect, but it won't idle with the maf plugged in. I can get it to run with maf plugged in if I fuck with the throttle. I should add. It ran fine with this setup before the head swap. Anyone have anything else I can check? |
![]() Join Date: Jul 2005
Does the engine die as if you cut the ignition suddenly? As if all the fuel is being pulled out at once?
Do you have a wideband? Try making a boost leak on purpose to increase the maf voltage- see if that will get it to idle. |
No. it seams to just trail off. and I can keep it running if I feather the throttle sometimes.
I don't have a wideband. Workin on it. I'll try the boost leak to increase the maf voltage and see if that helps...what would that tell me though? |
What EMS are you running Power FC?
Either way I can probably help you figure this out via tech support sessions remotely. Sounds like a wiring issue on the MAF if it's not a problem with the ECU / EMS setup. Just make sure to email me because I so busy with remote tunes for various builds and drifting teams that I am rarely on Zilvia haha - I try though [email protected] or direct message me on my fb page: https://www.facebook.com/shadowerks Thanks
Like Me on FaceBook !
#8 | |
to the op. have you tried a different maf or checked continuity of the wires to the maf? i see your in alberta i can recommend a shop in the north, central or southern part of the province depending on your location that you can take your car too if you feel the need to pay someone to fix this. they all have experience with sr20 engines. |
I have checked the maf wiring. Grounds are good, and shows 1v with engine off and 1.42v at idle. 12v was good too. Tried a different maf too. I'm running a stock ecu with daughter board. Tuned to z32 maf and 550cc.
provided everything else is right, (timing etc) when you changed your head gasket you maybe changed the cr of the engine by using a different thickness? maybe your ve has changed and you need a retune. the head work and cams would also changed the ve of the engine.
do you get a stable maf voltage at idle or does it fluctuate?
ve refers to the efficiency of the cylinder; how much output (power) per volume written as a %. more/less efficient flow threw the engine will change the ve. if your tuning for power you always try to achieve max ve in every cell. maf or map doesent matter here. changing the compression (difference thickness headgasket) of the engine will change the ve at idle. anything that improves the air flow in the engine will theoretically change ve, whether its enough to put the tune off so it wont idle is a guess without a wideband. adding forced induction will change the ve when the turbo is forcing air into the engine with boost. you tune ve at idle for afr (14.7-16afr) and timing to give a steady idle. ve of an engine changes from altering how air flows through the engine. |
#19 |
![]() Join Date: Jun 2013
I agree with inopsy.
Considering the changes you've done to your head, you've probably significantly altered the ve of your head, resulting in your tune being too harsh for the engine. When you unplug the MAF, the ecu goes into safety mode, running a much more conservative tune. This would explain why you can idle without the MAF. My suggestions are to try to retard the timing, or if you have an adjustable FPR, increase fuel pressure. See if it will idle with the MAF under those conditions. Sent from my SCH-I545 using Tapatalk |
#20 |
I see what you are saying, but really, the head was decked about 0.007" and the head gasket is approx 0.015" thicker than stock...really not much difference. And the 5 angle valve grind shouldn't change anything(I'm and engine rebuilder, and I've done a few heads that didn't need a retune.
Regarding the cams, It still idles smooth with a steady maf signal. 1.42v at idle, which is what most people have when idling with a z32 maf. Maybe I'm wrong here? |
#21 | |
Can you describe exactly how it dies? Also, a valve grind does affect VE since the gasses flow around them. It's a pretty subtle change though. |
#24 | |
Did you do a compression test to make sure your head is airtight? Do you have a consult port? Try to advance or retard the timing and see if you can get it to idle that way. |
#25 |
I don't have a consult port on this car unfortunately. I am quite certain on the mechanical timing. I'll do a comp test tonight, but I wonder what it should be with my cams...I've seen as much as 50psi lost with cams.
I have messed with the timing to no avail... |
#26 | |
Also, are you trying to mess with the timing alone? Because the way I do it is, I have a friend start the car with my right hand on the CAS and my left on the light, and I rotate it as it starts dying to keep it alive. If you're just rotating it a bit and starting, you won't be able to keep it alive. |
#28 |
Oh boooooooo. I just happened to check the resistance of the coolant temp sensor tonight. No continuity. I guess I should fix that before attempting anything further!! On a side note, I sure wish my ecu still had a working led so I could check codes.
Last edited by se7en_; 03-31-2014 at 11:58 PM.. Reason: stupid autocorrect on my phone. |
#30 | |
This is a far far overcomplication of this issue. The problem is much more subtle. I asked you to create a boost leak and determine if the engine would idle. I assume you never tried that. I suppose you want reasons. 1. If the engine did idle with a boost leak it would tell us the maf output voltage is too low (engine starving for fuel) 2. if the engine did NOT idle with a boost leak increasing in size we would next test to determine that the maf voltage is too high (too much fuel) MAf voltage is parabolic so this will not hold at any RPM above idle. Clearly if the engine is able to idle with no maf connected the problem is a communication issue involving the fuel/fuel map and associated variables (any sensor altering fuel) |
