I want to relocate my battery to the back of my car. Any advice or helpful tips on what i would need and where to get it would be helpful.
![]() Join Date: Sep 2008
items youll need
zero gauge wire (a shit load of it) you can get this a audio shops 2 gauge wire (again a shit load) again local audio shop connectors and battery tie downs first thing u do is cut the terminal from the positive cable and remove the negative completely run the zero and the 2 gauge wire from your trunk all the way to the engine bay using a connector connect the zero gauge to the old positive then do the same with the 2 gauge just connect to the engine bay the just connect the 2 wires to your battery and your set but remember to strap it down somehow |
![]() Join Date: Jun 2009
summit racing sells a really nice kit if you have any shops near you.. you can also order it from their website. 80$ but it has absolutely everything you need
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
no need for relocate kit just buy a batter box from the good old autozone,2 guage wire from lowes , and your good its pretty simple remember to wrap the hell out of the hot wire if its going near to rubbing on the body
#6 | |
![]() Join Date: Oct 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
![]() Join Date: Dec 2002
Secondly, the ground should be bolted to the chassis by the battery. Running it back to the engine bay creates a shit load of extra resistance that's not required. The engine will be grounded to the chassis already and you're not going to see a ground loop as long as both grounds are good and clean.
![]() Join Date: Jul 2006
i suggest connecting the positive wire to the starter and making a hole through the main ECU harness grommet to feed the 0 gauge through. Get audio 0 gauge cable since it's more flexible. Run inside cabin and you should be able to get it through to the trunk behind the rear passenger side trim panel.
At the rear passenger side corner of the trunk are a few bolts that you can use to clamp down a battery tray. 1 of these bolts won't line up to the standard battery tray holes. sand the body down here and you can use that for the ground. there: no holes drilled in metal and wire safe from dangers of bottoming out just be cafeful when drilling the grommet to not hit any ecu harness wires.
![]() Club Spirited Drive - for all who enjoy the thrill of driving - clubSDx.com |
#9 | |
Sure. The OE harness lays there fine. With the carpet sitting over it it's not moving around at all, even if it did the amount of insulation plus the sound deadening on the floorpan are both thick enough it'd take forever to rub through and short out. You just want a grommet or a big glob of taillight sealant where it passes through the firewall.
#14 | |
Explain your point here.
The chassis is a solid unit. A ground to the chassis under the hood and one in the trunk will see very little if any voltage differential. The engine is grounded to the chassis, then the battery. So if the engine is grounded to the chassis in one place and the battery another, you're doing the same thing. The extra length of wire you're using is just a huge amount of resistance. Does it work? Sure. But is it correct, no. Could it be done better? Absolutely. Just because your way of halfassing shit works doesn't mean it's the right way to do it. I bet you're also the guy who uses crimp caps to connect wires instead of solder/heatshrink. Sure it makes a connection, but it looks like shit and causes a point where resistance and corrosion can occur. But hey, it's your car. You like rigging it, cool.
![]() Join Date: Nov 2005
zero guage wire with a large fuse near the battery. ground the battery to the trunk. put it in a box or secure it really well. not that complicated.
#17 | |
/thread. |
#19 |
![]() Join Date: Apr 2008
don't you also have to allow some way for the battery fumes to escape, could someone drop some knowledge?
i don't want my car burning down on the freeway like that little 510 i saw a while back (r.i.p) |
#20 | |
![]() Join Date: Mar 2003
yes. it's to prevent build up of hydrogen gas. the battery box should be airtight and a hose should be run from the box to the exterior of the car. very easy to do this. seal the lid with any appropriate lining and do the same for any holes running in and out of the box (cable holes, venting tube hole) with an appropriate grommet.
some people say you don't need venting if you run an optima because they never outgas. this is technically incorrect, but it's not as necessary as with a regular battery. Quote:
#21 |
Trader Rating: (92)
as for venting the the hydro gas from the batteries i have no AC in my car and no i didnt take it off for hp gain!! it never came with it!! so with no ac i have to have the windows down all the time is that a sufficient way to vent the gas???
i see no point into sealing the box and making some piping to route gas out the car lol if i seal the box..how am i suppose to replace the battery?? |
#22 |
You can seal the box with weatherstripping. Nowhere does it say the seal must be permanent. Obviously that would be stupid, and assuming that is also stupid.
