![]() Join Date: Nov 2005
NEW Product Debut! WSRD complete power steering kit!
I installed the official prototype WSRD power steering kit on my car today. We'll have it up on the site soon, along with more detailed pictures! If you'd like to order immediately, shoot me a PM. These include the high pressure line, low pressure return, -10 pump feed, reservoir, and all necessary hardware, adapter, and brackets for install.
![]() ![]() We recommend Redline power steering fluid, it's good for any power steering system! ![]() ![]() ![]() ![]() Keep in mind this is the prototype, there will be some small differences and better fit and finish on the production version! Last edited by PoorMans180SX; 01-06-2015 at 03:29 PM.. |
A little of topic but the picture under the one with you pouring the fluid into the reservoir why does it look like there's a tube/skinny cylinder of fluid on top/or as if the p/s line was shooting fluid out perfectly??
Instagram username:angelmkiv |
#8 | |
![]() Join Date: Mar 2012
Trader Rating: (68)
![]() ![]() ![]() ![]() Feedback Score: 68 reviews
2) I can tell that the kit doesn't really come close to the intake side, other than the lines. If so just bracket it under the intake. Luckily both the lines and accordion are bendable so you can play with it
Straight Outta The Slums of Shaolin |
![]() Join Date: Dec 2007
![]() ![]() Feedback Score: 1 reviews
Sent you a payment for the power steering kit, will have a thorough review of the parts and ease of installation and fitment. Thanks WSRD for making this kit as an alternative to other kits.
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
Well we will see when I receive mines because I have a fmic
#16 | ||||
Unforunately not at this time, we don't have a RHD car to prototype on, so this makes it hard to get things like line lengths right!
Although it is close, the reservoir can also be mounted wherever the lines reach. This gives it a somewhat "universal" design and freedom for the user to change the mounting to suit their needs. |
[/IMG]Just kinda curious what you guys use for a feed fitting? This is my custom setup which I did because chasebays still uses a rubber hose and a clamp. I just used a krc 10an fitting on mine. |
#22 |
Feel free to correct me if I am wrong but the WSRD bracket seems to be laser cut out of 3-6mm AL? If your doing laser cut see if you can find a shop with a solid state (disk preferably) resonator. Will be a much easier for the shop to process due to the difference in absorption between the CO2 and NeYd wave length. I used to work for a major machine tool manufacturer and solid state resonators made everything a breeze Especially with AL, while being cheaper to run, thus cheaper for you as well.
I wish you had released these earlier. Waiting on my chase bays to come in.... ![]()
Project S14 Begins... |
#25 | |
Hah, that is just a universal one I'm using. We may or may not depending on the success of this kit, really.
It is not. The lid has an o-ring seal and I haven't had problems with either of my non-baffled cans puking fluid. Quote:
It is not. I haven't had any issues with the can design, is your fluid boiling? |
#30 | |
Its to do with the jz pump having a different banjo compared to the s body. the guy in question modified the fitting coming off the pump to reduce flow slightly. |
