![]() Join Date: Aug 2002
i have a box for 2 12" subwoofers, it currently has 12" kicker comps in them and i don't like em. so any suggestions of cheap but clean accurate bass for under $80 each?
btw it being powered by a 600watt JBL amp and my head unit is a Alpine 7892. any info would help thanks.![]()
![]() Join Date: Jan 2003
well under 80$ would be
Crunch 12' vdrive fatboy( ihave those they kick hard) or used JL audio of ebay or Even better - Crossfire audio. that definately wont be below 80$ ![]()
I must break you. |
![]() Join Date: Sep 2002
Was the box built to have the right internal volume for those subs?(Was it built to Kickers specs) My friend has some OLD Kicker 5' midbass and the enclosure for them is perfect. It sounds INCREDIBLE. Not to loud but all the SQ is there. (Although he has gotten pulled over for noise ordinance because of them
). If you want some subs with better SQ Alpine would be a good choice. Infinity Kappa Perfects would be good too for cheaper SQ subs. DO NOT BUY THEM FROM CRUTCHFIELD. They are WAAAAAYYY overpriced. I would suggest Ikesound to buy from. Their prices are pretty low and they have free shipping. Just don't buy from them with a check....I ordered by check and it took a month to get here... I ordered buy credit card and it's takin about a week.(Damn UPS:hammer: ) Good luck on finding what you want.(I would say if you haven't already make a ported box to Kickers Reccomendations. It should be loud and clean.)
My 240 vBgarage |
oh i forgot to mention that it needs to be very accurate because i listen to fast punk music. not the long extended bass like in hiphop/rap/rnb.
Well if you want a REALLY good sub that would replace BOTH with just one and would be cheap(at least for what you get).....then go to Elemental Designs The A series subs (from what I've heard from reviews) is comparable to a JL Audio W7. Not quite as good in SQ but for the price.....who cares!
Also it will get louder than the W7. If you have the space build the ported enclosure to their specs. ![]()
My 240 vBgarage |
Honstly, I'd just sell the box and the subs together and get what you really want. For fast accurate bass, I'd look for a single 10" or 12" driver in a sealed box. Otherwise you're stuck trying to find speakers designed for the volume of the box you already have (which may be part of the problem to begin with) as opposed to getting what you want and tailoring it to your needs.
Plus while 2 cheap 12's *may* hit harder than a single, one quality sub in a sealed box will sound better.
Steve 93 240sx FB currently very clean and for sale |
![]() Join Date: Apr 2002
Ever looked into the Infinity Basslink? I've heard great things about it. Plus, if your like me and want to be able to remove the extra weight easily...it's all one piece. Just a thought.
89 S13 hatch/////98 Subaru 2.5RS |
![]() Join Date: Jan 2002
Punk & bandpass? Yikes
That would sound like yea... umm... I run two 8 8W3v2-D2 in my 1998 S14 SE in a sealed boxed. I listen to punk/ska/jazz so I'm probably after the same thing as you as far as sound goes. I absolutely love the sound for punk&ska... more questions?
1998 240SX SE 5-Speed |
#13 | |
![]() Join Date: May 2002
i listen to punk, alternative, etc too.. all i have is one 12" rockford power HX2 with a 2000watt Koiler amp and it is very accurate... and sounds really clean... and hits harder than 2 12's if i want it to...
Good SQ can be had from 15" subs too. It depends mostly on the install and the motor strength of the driver. If the motor is the same one used on the company's 12" driver then it will most likely not sound as good. If the 15" has a sufficient motor structure then it would be able to be as accurate as a 12" in a good install. (It would require more power though)Also, it would be able to play lower frequencys. So if you want you could get one 15" and get a good box for it. Also, is it 2 cubic ft. total? How do you have them wired? It would probably sound a LOT better ported. I had a JL 12" W3v2 in a 1 cubic foot box and the hits seemed to lag a little. I built a ported box to their specs and it sounded sooooooo much better. Sealed can sound better in SQ but going with a larger sealed box would be better. One the Crutchfield site it says they 12" Comp VR's should be in a 1.0-4.6 cubic foot box. 1ft cubed is pretty small. You also have to take in account the driver displacement. You could try to make a different box with more internal volume or try to make a ported box. Buying prefabbed boxes sucks unless you reseach what you're gettin into first.
My 240 vBgarage |
#17 |
Yeah, but for the budget he's talking, a 15" is going to be on the low end compared to some decent single 10's or 12's and very underdriven.
Go give a listen to some good, well designed single subs, I think you'll be impressed. It may not hit quite as hard, but that doesn't seem like your primary concern. Regardless I think you would be shocked at what a small, though well designed speaker is capable of. I have a set of nice bookshelf 6.5" speakers (paradigm mini monitors running on on a yamaha integrated amp) and I'm constantly being asked what sub I run. I don't, in fact my amp is usually running flat too. Sure they don't hit like a 12" sub would, but they're plenty well rounded, especially for their modest dimensions and compare well with much cheaper 8" speakers in terms of bass output and blow them away for detail. Plus the single driver in a smaller box will free up a lot of trunk space.
#18 | |
#19 |
![]() Join Date: Jul 2001
okay, I think a lot of you aren't helping his specific wants/needs. He's said he wants 12s under $80, he had a box already, and he doesn't care about super bassy music, cuz he likes punk. I can relate, I listen to punk and alt.rock more than anything, and I agree, a sealed box is definitely the way to go.
What i did to keep costs down was scout out top of the line, but older, drivers. I ended up with a couple 10" MTX Blue Thunder (not the crappy thunders, there's a couple differnt BT series). I wanted the same thing. Accuracy over volume. Bandpass is for forcing more air around, and more volume but you lose accuracy, I don't know what your ear meter tells u, VU meters don't lie. Just another route you might think about. If cost is an issue, think about scouting used gear (just make sure u test it out first!). Kinda like buying a 911 turbo porshe... definitely can't afford a new one, but a late 70's one could be doable ![]() |
#21 |
Crutchfield will STILL be more expensive than other online retailers. Just cough up a couple more dollars and get a Alpine TypeR.
My 240 vBgarage |
#22 | |
yup I got one in y trunk now.. It'll be in the pit somewhere at convention dont steal it!! I'll cut ya
Keeping it Godzira bishes. So I murdered another turbo |
